Old 04-13-2007, 10:13 AM
Ernie Italy is off the scale
Default Low gear
Hi,
anyone think that the low gear are "high"...
I try to explain better...
with low gear, also in 1st the truck move too quick...
There is solution to move less without touch the brake ?
Thanks to all
Old 04-13-2007, 03:20 PM
Default Re: Low gear
Hi Phil.
You have the same opinion about "high" low gear or is only my impression?
And what is your opinion about the 2" cognito level kit?
Old 04-13-2007, 03:50 PM
and spacer for the rear are easy to find (or found?? problem with english).
Old 04-13-2007, 04:16 PM
It\'s a Dry Heat's Avatar
4 Low is to dang fast for rock climbing PERIOD!!! I think it's 33 to 1. Rubicon Jeep is I think is 58 to 1. The only way around it is to lower tire preasure and front locker. I only hope the new 2008 6 speed trans will help this.
Old 04-13-2007, 05:37 PM
MarineHawk's Avatar
Originally Posted by PhilD
Yes, new transfer case with better Lo gearing will improve the crawl ratio and will not effect on-road performance, only when in 4Lo.
How much would it cost to install, say, a transfer case with a 4:1 low/hi ratio?
