12-13-2002, 07:07 AM
Does anyone else's Hummer set slightly higher in the back than in the front?
When I park on what I beleive to be level ground, it appears my Hummer sits slightly higher in the back. I would perfer the front and back of the Hummer to be level. Would look nicer I think.
Any thoughts or am I getting a contact high from Steve's crack smoke? [img]/infopop/emoticons/icon_razz.gif[/img]
HeeeeeeeeeeeeeeeHawwwwwwwwwwwwwwwww [img]/infopop/emoticons/icon_eek.gif[/img]
HeeeeeeeeHawwwwwwwwwww
12-13-2002, 10:27 AM
Steve's crack smokes??? A doctor could probably give him something for that... [img]/infopop/emoticons/icon_razz.gif[/img]
12-13-2002, 11:15 AM
Hey Hee Haw,
If you just want to level the truck out, just adjust the torsion bars some. It will alter the front end alignment somewhat, but you should have to adjust them much to level the truck, then take it to the alignment shop and have the amber corrected, or you will wear the outside edge of the front tires prematurely.
~Scott T.
'95 D-90 (JEEPETR)
'96 Discovery (Not Stock)
~Scott T.
'95 D-90 ST
"If you're not living on the edge, you're taking up too much space!"
http://www.putfile.com/lrnad90
12-13-2002, 12:49 PM
Mine is also slightly higher in the back, but I have yet to see a GM vehicle that isn't set up that way.
12-13-2002, 02:53 PM
Adjusting the torsion bars will do the trick. I did it on the H2 and it looks way better. You do have to go get the frontend aligned relatively soon. I found this out the hard way on my pick-up, when after 6000 miles my tires where trashed. But overall the adjustment really helps out the look and only it takes 15 min to get done.
12-13-2002, 03:02 PM
That's why I like this forum. Now, do I have someone do this or this something I can do?
Thanks in advance
We should all hold hands and sing for Steve, our beloved crackhead buddy............. [img]/infopop/emoticons/icon_biggrin.gif[/img] [img]/infopop/emoticons/icon_biggrin.gif[/img]
12-13-2002, 04:52 PM
do you really wanna get me started? Cause I can dig in tighter then an Alabama tick!
12-13-2002, 05:29 PM
IF AND WHEN YOU DO THIS YOU MIGHT HAVE TO ADJUST YOUR HEADLIGHTS, DEPENDING ON HOW MUCH YOU ADJUST THE TORSION BARS. [img]/infopop/emoticons/icon_eek.gif[/img]
