12-15-2005, 08:36 AM
If you notice your keys banging into dash while accelerating or braking, I found an easy fix. Purchase a sticky pad by Handstands @ brookstone. Cut pad into small square an place on dash @ impact area. This material is spongy with a tacky non-adhesive backing. Check out http://www.handstands.com for pads or gadget grips(pre-cut squares).
12-15-2005, 12:00 PM
There is an even easier one, just have your key on the very small keyring that comes with the remote and don't use the larger key ring. Problem solved. </div></BLOCKQUOTE>
That only works if you carry the H2 key separate from any other keys you have. While I'm not a key hound (I only have a few other keys on the ring), I like to keep all my keys together...if nothing more than to occasionally give me a sharp jab to the g'nads when I sit down, not
'03 pewter base H2
12-15-2005, 01:14 PM
is the problem the noise or possible scratches to the dash? scratches add character, and the volume buttons on the steering wheel or stereo eliminate the noise. i recommend Motorhead to completely eliminate all squeaks and rattles.
12-15-2005, 02:24 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by shorterbus:
is the problem the noise or possible scratches to the dash? scratches add character, and the volume buttons on the steering wheel or stereo eliminate the noise. i recommend Motorhead to completely eliminate all squeaks and rattles. </div></BLOCKQUOTE>
The noise. My keys band the dash incessantly. Being moderately OCD, it drives me nuts. My wife doesn't notice.
Volume control would be an option...when I drive by myself, but if kiddo or wife are in the truck, that's not an option.
The padding on the dash mostly cures the problem. Instead of a loud clack, clack, clack, you get a much quieter thud, thud, thud that has fewer high frequencies to it and is easier for me to tune out.
BTW, it's not just during accel/decel for me. It's any time driving on uneven road, which is pretty much anywhere.
'03 pewter base H2
12-15-2005, 02:25 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ree:
... padding ... </div></BLOCKQUOTE>
'03 pewter base H2
12-15-2005, 02:32 PM
It's been a long time since this subject has come up and the fixes are always the same.
Did I read something about a pad?
12-15-2005, 03:06 PM
Being moderately OCD, it drives me nuts. </div></BLOCKQUOTE>
This truck will be drving you nuts if you keep it for more than a couple of years then  </div></BLOCKQUOTE>
 yeah I know. At 2 1/2 years old it already has plenty of noises.
I haven't owned any car that didn't drive me nuts, though.
I've managed to learn a coping technique called "enjoy being nuts."
At the risk of appearing to be a French wank sympathizer, cest la vie.
'03 pewter base H2
12-15-2005, 03:10 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> but if kiddo or wife are in the truck, that's not an option </div></BLOCKQUOTE>
yeah, my wife doesn't like Motorhead either . .
12-15-2005, 03:13 PM
yeah, my wife doesn't like Motorhead either . . </div></BLOCKQUOTE>
I don't like Motorhead either. But we all like a lot of other 80's rock and metal.
It's the volume the wife and kiddo don't approve of.
'03 pewter base H2
12-15-2005, 03:18 PM
i found that Motorhead, while not being to everyone's taste, is the best at drowning out all clunks, rattles, squeaks and wind noise on a far more consistent basis. no chance of a quiet ballad coming up and allowing distracting noises to make it to your ear. and it leaves your ears ringing for a while, keeping you sane between tracks
12-15-2005, 03:21 PM
... and it leaves your ears ringing for a while, keeping you sane between tracks </div></BLOCKQUOTE>
Ah. You need to pick up some progressive rock stuff (Dream theater is my recommendation) where they do a lot of 10-20 minute tracks.
'03 pewter base H2
12-15-2005, 05:11 PM
Just keep trading. That's my solution.
12-15-2005, 06:48 PM
I think I can hear someones bushings squeaking. Hmmm. Yep, I can hear it.
12-15-2005, 06:53 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> I think I can hear someones bushings squeaking. </div></BLOCKQUOTE>
those would be mine, they're ready to disintegrate again.
12-15-2005, 07:27 PM
I also have a fix for the remote banging....I superglued the key remote to the steering column and now it doesn't bang anymore....of course I have to leave the truck running constantly, but hey it was worth it!
