Old 04-21-2006, 04:58 AM
As you know, we're having issues with our truck.... again in Moab. This time we couldn't exit 4-low to 4-high, or anything else for that matter. The T-case was stuck in 4-low.
Here's a quick remedy until you can find out and repair the real problem:
On the back of the t-case, start by removing the 4 10mm bolts from the actuator and remove actuator from truck. Chock wheels, start truck, engage parking brake, put truck into neutral.
Then using a vice grip, clamp on the "A" shaped pin and turn CLOCKWISE to go from 4-low to 4-high. COUNTERCLOCKWISE to go from 4-high to 4-low. You'll hear it engage just like it normally would.
Turn off truck.
Now the "A" pin doesn't line up with the actuator so install actuator on pin and rotate actuator into position and bolt back into place.
Restart truck.
Your dash lights should indicate you're in the correct gear now. If not, remove actuator and throw in the back seat.
You are in the correct mode now, so drive away and get whatever is wrong repaired as soon as you can.
That's a simple trail fix anyone can do.
Old 04-21-2006, 10:13 AM
NewHummerGuy's Avatar
Now i will just print this out and throw in the glove box for future reference ...Thanks Ken. When you all heading back?
Turn off truck.
Restart truck.
I'm Gonna crazy you my body
Old 04-21-2006, 10:53 AM
Cool!
Old 04-21-2006, 11:23 AM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Thanks for posting that Ken. This one is definitely going in my bag of quick fix trail tricks.
Shame to cut a trip short, but atleast your not stuck 2K miles from home with a broke T-case again.
Old 04-24-2006, 06:16 AM
Thanks. Sometimes you have a problem that the simple fix will help many people. I hope this does. ( I doubt it judging by the views... But I did my part. )
Old 04-26-2006, 10:50 AM
Racer-X's Avatar
Racer-X Racer-X is offline
Racer-X is off the scale
Cool Ken, I'm starting a binder for trail fixes to keep in the rig. This will be a good addition. Thanks
Old 04-26-2006, 01:11 PM
Maybe RAAAARRR11 just wanted to stay in LOW and stay in Moab. It new it was almost time to go home and you needed 4HI to do so.
Old 04-26-2006, 01:24 PM
I know I wish it did. Now, I'm a little pissed that it could have been "manually" eased into 4lo.
Raarr!1 is still getting a good spanking when he gets home, he has been a bad truck. Letting that mean ole Kenny-Daddy turn his knobs like that.
Old 04-26-2006, 08:06 PM
Alan06SUT's Avatar
Thanks for the useful info! I got stuck in 4 low once and found a big stick jammed underneath my truck by the t case. I pulled it out and was able to switch back into 4 HI. Maybee it was jamming that lever. I'll definatley print this out.
Old 04-26-2006, 09:10 PM
bjc's Avatar
bjc bjc is offline
bjc is off the scale
Think this would apply to H3's as well?
Birch White H3 Manual, Adventure Package, Sunroof, Trailering Package, Off-Road Lamps, Splashguards, Black Tubular Assist Steps, Black Crossbows, Mudder Mats, Ski Rack, Warn XD9000 w/ DOI Hawse Winch Bumper, DOI Prototype Skid Plates, M101A1 3/4 ton trailer.
Old 04-26-2006, 09:50 PM
If my service CD included H3s I could tell you.
Maybe someone with an updated GMSPO SI that contains the H3 can see how the t-case works. I don't even know what t-case is used. But, likely it's very similar, just the actuator might be located somewhere else or look different.
Old 04-29-2006, 05:43 PM
cestwick's Avatar
cestwick cestwick is offline
cestwick is off the scale
Assuming there is no internal T-case damage it is almost the same...there are 3 bolts that attach the encoder to the T-case. If you remove motor you would be able to turn shaft(truck should be running and in neutral).
'06 H3 Shadow Green, Adventure, 6 disk Monsoon, SMA brush guard w/PIAA lights, Rocky Road extreme rocker protection, roof lights(off road), lower grill lights(off road), Helo Maxx8 Black Wheels, 35" Cooper STT, Garmin I-Que M4 to get home.
