09-14-2005, 07:56 PM
Make sure your dealer has performed the prescribed additional fill of your transfer case fluid. Mine didn't, so it is going back in for the additional fill.
09-14-2005, 08:11 PM
Do you have a service bulliten number or something that I can provide to the dealer for reference?
2006 H3, Adventure Package, Sunroof, Brush Guard, Tube Steps, XM Radio, Shadow Green Metallic
09-14-2005, 08:41 PM
Ok f5fstop....I don't know how to read the number...I can tell you numerically speaking it is a definitely lower (smaller) than the one posted.
help
09-14-2005, 09:03 PM
is it related to the whining noise in the powertrain? need to check my number ... i got my H3 three monthe ago
anyway thanks for the update f5fstop
2006 Black SUT
09-14-2005, 10:05 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummBeebe:
help  </div></BLOCKQUOTE>
Just the last five digits are all that is required, that is actually the VIN sequence number.
This is a VIN breakdown for GM light trucks, different than used for Cars or Medium Duty Trucks.
5 Country of Build (1,4,5 denote USA)
G World Make Modifier G = Hummer
T H3
D GVWR/Brake System D = 5001-6000 GVWR Range (lbs) Hydraulic brakes
N Line Chassis N = Hummer
1 Series 1 - 4x4
3 Body Type 3 = Four-door cab/utility
6 Engine Type 6 = L52, 3.5L L5, MFI
9 Check digit (randomly generated)
6 Model Year 6 = 2006
8 Manufacturing Plant 8 = Shreveport, LA
105387 VIN Sequence number. First digit (1) is not used on this vehicle for VIN range and may change from year-to-year. For example, one year it might be 1, the following year 5. If the plant will produce greater than 99,999 vehicles it will be used and wil be zero until the 100,000 vehicle is produced. In this case, this vehicle was the 5,387 H3 to be issued a VIN.
09-14-2005, 10:27 PM
Phew!!! not me
09-14-2005, 11:20 PM
105835 here...guess I'm OK.
Traded 4-1-06: 2006 Black Hummer H3 Adventure Series - Vortec 3.5L Inline 5
Offroad Suspension Package, 33" Tires, Electronic Fully Locking Differential, 4.03:1 2-speed Transfer Case, Ebony Cloth Trim, Automatic Transmission, Sunroof, Roof Marker Lamps, Fog Lamps, XM Satellite Radio, CD/MP3 Player, Trailering Package, Black Tube Nerf Bars
09-14-2005, 11:36 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">In this case, this vehicle was the 5,387 H3 to </div></BLOCKQUOTE>Mine is in the 4,000s but I don't have any probs with my H3 whatsoever (2,500 miles so far). Am I supposed to have my transfer case fluid checked now? There's no official HUMMER dealer here in Germany... so if I want my garage to check the transfer case fluid, will they know how to do it (i.e. is it an easy procedure?).
09-14-2005, 11:52 PM
28108 here (assigned end of July), wow...quite a few built so far.
09-14-2005, 11:59 PM
wow I got a young un 0249 here
09-15-2005, 12:04 AM
Mine is 2010, but I haven't had any issues with the trans.. called the dealer and they said they don't know anything about this... what else can I tell them, is there going to be a recall or..??
\'06 Boulder Gray H3 / Loaded
09-15-2005, 12:14 AM
Mine is 11864, so I guess I'm safe.
\"In the poker game of life, women are the rake man. They are the f$#@%n\' rake.\"
__________________________________________________ _____________________
\'06 H3 - Birch White, Auto, Lux Pack (with Homelink), Chrome Pack (with Crossbows), Chrom
09-15-2005, 12:58 AM
uh what the heck is this about?
09-15-2005, 06:44 AM
103259 guess i better check it out
(with insurance)
09-15-2005, 07:44 AM
All required have received private topic emails.
09-20-2005, 01:25 AM
Owners manual supplement, "Filling the transfer case to the drain fill plug is no longer adequate. You need to add 0.25L (8.5 ounces) after you fill to fill plug. Install fill plug and add 0.25L through speed sensor hole per instructions on bottom of transfer case.
Another way I used is to jack up the drivers side and air down to 12 lb on passenger side of vehicle. This raises the fill plug in relation to the drain plug, I was able to add 0.25L ATF.
Since the transfer case only holds 1.6 qt, I changed it to Mobil 1 Synthetic ATF, approved for H Specification. Since I do it myself, only the best for the H3.
09-20-2005, 07:40 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hi-Cap Hummer:
Since the transfer case only holds 1.6 qt, I changed it to Mobil 1 Synthetic ATF, approved for H Specification. Since I do it myself, only the best for the H3. </div></BLOCKQUOTE>
5 minutes to remove speed sensor, add fluid and re-install versus how long to jack up vehicle, deflate/inflate tires?
09-20-2005, 12:20 PM
All required have received private topic emails. </div></BLOCKQUOTE>
Mine is 2247.
09-20-2005, 02:03 PM
Wow, H3'er you might be low VIN man. Got mine in June and it's 0389. After my water adventures, I have already changed all my fluids, except for the transmission.
