Old 01-27-2004, 07:08 PM
I got started on this and petered out. It's been pretty easy but I just can't do much of anything for very long these days. I'll post the rest of the pics when I finish (who knows when that will be). Here is a pic of the package from hummersolutions.
Old 01-27-2004, 07:09 PM
This is the rig before I got started:
Old 01-27-2004, 07:10 PM
This is the rig with the metal valance and DRL bumper off:
Old 01-27-2004, 07:13 PM
Back of the valance and DRL bumper:
Old 01-27-2004, 07:14 PM
Close up of the back of the DRL housing:
Old 01-27-2004, 07:16 PM
About to separate the DRL's from the bumper and the DRL bumper from the metal valance so I can use a dremel to "adjust" the back of the DRL buckets:
Old 01-29-2004, 02:49 PM
DRL's are out, what the light housing's look like from the back
Old 01-29-2004, 02:52 PM
Cut the back of the DRL bumper using dremel and cut the bottom of the plastic insert.
Old 01-29-2004, 02:53 PM
Same thing on the other side, but you also have to cut out the little tab at the top.
Old 01-29-2004, 08:13 PM
Ok, I got a little too excited with the dremel. The previous 2 pictures are incorrect. I made the cuts on the top instead of the bottom of the DRL bumpers.
I had to go back and cut again and now the top and the bottom is cut off. OOPS
Old 01-29-2004, 09:08 PM
Spike Spike is offline
Oh ****, now you tell me........Just Kidding
S&B Member
Old 02-05-2004, 04:47 PM
It's been nearly 2 weeks and I haven't made much progress on this. My rig hasn't moved and the front end is still in pieces. I promise to finish it before the end of the year and post the final pictures.
Old 02-05-2004, 05:49 PM
frank6150's Avatar
Is that hole big enough to fit the PIAA 520's Paragon? Looks like you have the entire backing cut out.
S&B Member since '03
Old 02-05-2004, 06:02 PM
You can make it big enough, I think. The front of the bumper where the DRL's come through would be the main problem, making the cut into the plastic look OK. As is now, the Cut is on the recessed portion of the bumper and the PIAA's would require you to cut the whole recessed portion completely out.
Old 02-05-2004, 06:12 PM
frank6150's Avatar
Yes that would be a bit difficult to get the front cut. I can't even cut a piece of wood straight so that takes me out of the running of trying it myself.
I think I am going to order a set and go to a couple places to see if they can make the proper cuts without destroying the bumper. If nobody can pull it off I will see if I can just flip them upside down and mount them where the wings are now. Thanks Paragon!
Old 02-05-2004, 06:37 PM
Frank,
I thought about seeing how much it was to replace the DRL bumper and the plastic inserts in the back and go ahead and try to make it work for the PIAA's.
Remember, there are 3 pieces (besides the wings) There is the plastic bumper that you see and there there are inserts for each side that goes inside of the plastic bumper for extra support. This is not illustrated very well in my pictures.
Old 03-21-2004, 10:20 PM
Ok, they're done. I've had them mounted for a few weeks but finished the wiring this past week. I haven't driven with them at night yet but they light all around the front end very well. Here is a pic with lights off.
Old 03-21-2004, 10:21 PM
Here is a pic with the lights on
Old 03-23-2004, 02:49 AM
SOCRATES SOCRATES is offline
SOCRATES is off the scale
Paragon,
How did you go about wiring the lamps? Did you wire them into the daytime running lamp wires, or?
Thanks!
-Justyn
05\' Black SUT
