Old 08-15-2005, 10:58 AM
md_sailor's Avatar
md_sailor is off the scale
Greetings, I have run a myriad of searches for previous threads pertaining to moving the Onstar buttons. There are many threads from 02 and 03 saying that they failed. Is there a OnStar mirror that is compatable? Has anyone suceeded in moving the controls?
Thanks again you are my Hero
md_sailor's Avatar
Old 08-16-2005, 03:42 AM
There have been many success's to moving Onstar buttons.
Where are You thinking about wanting to move them?
You can go in the front of the overhead console or go on the bottom side of the overhead. Both of these require lengthing the wiring so solder is manditory.
You can go to driver side of center console on the side of the center dash piece without lenghtening the wiring sometimes.
If Your handy move the cig plugs to each side of the center dash and cut hole where they are and move it to the bottom of the center console.
If You want You can move it to the inside of Your shifter console inside the storage compartment. Again requires lengthing wires.
You can go in the glove box sense it is a more rarely used device but, again lengthing the wiring.
I hope this gives you some ideas and maybe help You to event someplace to share with us also.
TAZ
Old 08-16-2005, 04:36 PM
md_sailor's Avatar
Taz,
Thanks for the reply. I want to change to a Onstar equiped Rear View Mirror such as the Taho and Yukon have. Is there a model which will retrofit easily?
md_sailor's Avatar
.....Tahoe
Old 08-16-2005, 06:45 PM
CBR_Raven's Avatar
CBR_Raven CBR_Raven is offline
CBR_Raven is off the scale
I'm sure it can be done with the rear-view mirror with the onstar setup...it's just a matter of extending the wires and soldering. This could be time consuming if you don't have any experience doing this type of work so you may want to have a car audio shop do it for you.
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
Old 08-16-2005, 06:53 PM
VTSTOMPER is off the scale
Are 06's on the mirror again?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
