Old 08-08-2005, 12:27 PM
tVan tVan is offline
tVan is off the scale
I've been lingering on this site for a while...but never have posted before.
Anyways, I've had my 2003 H2 for about 6 months now and I love it. But a few issues have come up. First off, after a bit of driving my RPM's will start to jump around a bit, but just for a second or 2. (changed fuel filter & had the cats replaced because they were clogged)
Also last night it rained really hard, and it was leaking water from the box that has the dome lights and the garage door buttons.
Any ideas what these problems could be????
Old 08-08-2005, 12:31 PM
VTSTOMPER is off the scale
search on leaks...there has been much talk on that.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 08-08-2005, 01:17 PM
any idea on why my RPM's are jumping around??
Old 08-08-2005, 01:26 PM
no, I havent had the injectors looked at. I will check into it though
thanks
Old 08-08-2005, 10:35 PM
gorton gorton is offline
gorton is off the scale
no, TVAn you must be lying. These vehicles are impecable. Nothing like you have described could have ever happened to a Hummer.
\"It\'s all about prestige,\" Marty Bernstein
Old 08-09-2005, 01:53 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by gorton:
no, TVAn you must be lying. These vehicles are impecable. Nothing like you have described could have ever happened to a Hummer. </div></BLOCKQUOTE>Don't you have some gay porn sites that are looking for you.
Old 08-09-2005, 02:20 AM
Snake II Snake II is offline
Snake II is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">gorton
Posted Aug 08, 17:35
"It's all about prestige," Marty Bernstein </div></BLOCKQUOTE>
05 SUT Lux
Old 08-09-2005, 09:01 AM
Dan Dan is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by tVan:
Any ideas what these problems could be???? </div></BLOCKQUOTE>
Mine leaked in the same area. The seal on one of the roof lights had a split in it. New light assembly and siliconed them all. Hasn't leaked since.
FYI, watch out for your radio. The water dripped and ran right into the DVD slot on mine and messed up the touch screen for a while. It was fine after it dried.
Old 08-09-2005, 11:29 AM
alright...thanks a lot...I'm definately gonna get it fixed as soon as I can so I dont jack something up
Old 08-10-2005, 12:15 PM
alright, maybe I'm a dumbass, but I have been searching, where can I find a new seal to replace it with, or new light assembly
Old 08-10-2005, 12:33 PM
Use RVT sealer...you can pick it up at the auto parts place. Do not get the clear stuff...
Old 08-10-2005, 12:53 PM
Do not get the clear stuff... </div></BLOCKQUOTE>
The clear won't work? Good to know, I would have probably gone with the clear.
Old 08-10-2005, 01:31 PM
awesome, thanks alot for everybody's help
Old 08-10-2005, 06:46 PM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
The clear won't work? Good to know, I would have probably gone with the clear. </div></BLOCKQUOTE>Clear works perfectly fine. Regardless of the color get a good silicone designed for automotive application. Good luck.
Old 08-10-2005, 06:53 PM
yeah, the clear does not last nearly as long. I am not kidding...
Old 08-10-2005, 09:17 PM
H2BRUTE H2BRUTE is offline
Location: GAIN INFORMATION AND EDUCATION RELATING TO HUMMER H2\'S
H2BRUTE is off the scale
I've had the same problem. It seems the dealer identified that leak to my PIAA light bar on the roof and fixed that particular one and then it started to leak out the passenger side sun visor. Still leaks after 4 attempts at the dealers. They have been terrific though in trying to accommodate me. My leak isn't consistent though. It hasn't leaked in rain storms or in my driveway which has a slight pitch to it. It only seems to leak if it rains and I am parked in an open area..The dealer has said it is a problem and they are trying to figure out where the darn thing is coming from..Good luck
