02-28-2006, 03:06 PM
ok, dumb question. but, does anyone know how to adjust the headlights? mine are pointing too high and need to come down some. they are pretty high, to the point of that they are pointing in the rear mirrors of other h2's. i checked the owners manual but was unable to find anything on headlight adjustment. thanks.
H2 for life!
H2 for life!
02-28-2006, 03:36 PM
thanks phil. guess i'll fix it when i change out my grill this week.
H2 for life!
02-28-2006, 04:50 PM
well, even better then. guess i'll go fix em now! thanks again phil, you're a huge help.
H2 for life!
02-28-2006, 05:27 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by saleen779:
Posted 02-28-06 10:50 AM
well, even better then. guess i'll go fix em now! thanks again phil, you're a huge help. </div></BLOCKQUOTE>I'd wait 'til dark.
02-28-2006, 06:42 PM
Phil............. quit advertising
02-28-2006, 06:48 PM
Phil, would there be any way you could accurately measure the location of this hole, so we could drill it without removing grill?
02-28-2006, 08:00 PM
Well if I end up with headlight bezels that resemble the drilled-out OEM mini grill, who else can I blame but you Phil
07-05-2006, 01:51 PM
Re: headlight adjustment?
Phil,
Did you ever measure the location to drill?
'03 pewter base H2
07-05-2006, 02:37 PM
Originally Posted by PhilD
You're going to make me do it aren't you?
I'll do it this morning...
I'm afraid that while unhooking my grill lights while removing the brushguard and grille, I might get my hand stuck in the grille like Paragon did. I figured I wouldn't risk that if at all possible
'03 pewter base H2
07-06-2006, 05:18 PM
Excellent. Thanks Phil.
'03 pewter base H2
12-06-2006, 03:19 AM
Phil, you took a bit to both holes? or was one there and you drilled the other. I don't have wither and couldn't find the adjustment screw. Did they change from 03/04 to 06/07?
Since the lift was put on, the headlights need to come down for sure.
NEver mind, I found it. I'm just not sure how far down to bring them yet.
09-16-2007, 12:06 AM
I finally did this mod to adjust the headlight. Now all I need to do is wait until it's dark.
09-17-2007, 12:07 AM
By vertical adjustment I mean up and down, and by horizontal I mean side to side.
Is there another definition?
