12-01-2005, 02:29 PM
I have decided the best option for functionality and looks is to have two sets. I am going o keep my OEM wheels and put BFG Mud Terrains on them. Not sure what to get for the other set yet.
12-01-2005, 05:48 PM
12-01-2005, 06:04 PM
WOW, I do like those AT tires! Nice job on the setup. Any websites that carry a good selection of those tires so I can see what sizes they come in?
12-01-2005, 08:25 PM
you can do a search for Pro Comp Extreme allterrain, not to be confused with another tire made by procomp called xtreme _____? I bought my tires from a site called http://www.wheelsandspinners.com but they dont really have much info on the tires unless you call them directly. This tire is fairly new to the market so there is not alot of information on the web yet. I will tell you another pretty good looking a/t and its the mickey thompsaon atz. It comes in a 35x13.50-20 as well. I think the next size up is a 36x15.50 which i think would be too wide for a non lifted truck(buti could be wrong).
12-01-2005, 11:58 PM
I found the specs here: http://www.procomptires.com/xtatapps.htm
Looks like you need a 10" wide wheel for all of the ones available. Counts me out...
12-02-2005, 03:05 AM
Looks like you need a 10" wide wheel for all of the ones available. Counts me out... </div></BLOCKQUOTE>
Im not sure what your seeing, but on that chart the rim range for all sizes listed is 8in-12in so it looks like you can run this with basicly any rim you select.
12-02-2005, 05:25 AM
Ahhh, I was looking at tread width
12-04-2005, 09:43 PM
Hey BH, does your whell/tire combo rub anywhere? If not, what are the specs on your rims? I want to do 20" wheels with 35s, but need help determining the widest wheel I should get and what the offset and backspacing should be. Thanks Bro...
12-04-2005, 10:17 PM
Hey BH, does your whell/tire combo rub anywhere? If not, what are the specs on your rims? I want to do 20" wheels with 35s, but need help determining the widest wheel I should get and what the offset and backspacing should be. Thanks Bro... </div></BLOCKQUOTE>
It rubs very slightly only when the steering wheels is completely turned to the right while backing up...this is very slight.
Im not positive on the backspacing but i think its -4.5 and the rim is a 20x10. I made sure i had a 10in wide rim as the wider rim will make the tire seem wider than a smaller width rim. MKW makes a rim that looks very similar and it is a 20x11.
12-04-2005, 10:18 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Humm This:
BH, What's that SM emblem on your door? </div></BLOCKQUOTE>
Size Matters....i just had to do it when i got my 20's. I cant think of any other truck it would fit better than a Hummer.
12-05-2005, 12:28 AM
Can you please help me find the backspacing on your wheels? Web provides no help when I searched. Found lots of wheels like yours but no specs.
I am considering 20"x10"3 wheels with 4.25" backspacing. Do you think this extra 1/4 sticking out will cause rubbing on outside of tire?
12-05-2005, 12:47 AM
Found it: http://www.bigwheels.net/?location=wheels&view_mode=&ac...NT1&model_vehicle =H2
So yours have a 4.25" backspacing. I was kind hoping that yours were 4.5, so that a 4.25" would cure the rubbing. Oh well, yours looks good!
Would you mind getting a clear pic from the rear and side of your H2 so we can see how far they stick out? It's kinda hard to tell from the pics above.
12-05-2005, 01:16 AM
The rubbing is MINIMAL. They do stick out a bit, but i like the look:
12-05-2005, 08:17 PM
I am finding out how expensive these darn 20" tires are today! Crap, any good online places to get them at DEEP discount?
