Old 01-23-2006, 07:57 PM
#06-08-44-001 Ticking Noise From Radio Speakers (Check for DTCs and Replace Radio, If necessary) - (Jan 4, 2006)
#05-08-46-001A OnStar Generation-6 (Digital) System Inoperative/Has No Power, LED Light Not On (Remove/Reinstall OnStar Fuse and Replace VCIM or Follow SI Diagnostics) - (Jan 4, 2006)
#05-03-10-003A Low Tire Pressure Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) - (Dec 19, 2005)
#05-08-64-002A Door Latch Freezing In Cold Temperatures (Apply Super Lube) - (Dec 19, 2005)
#05-08-51-008 Bumps or Rust Colored Spots in Paint Due to Rail or Iron Dust (Remove Rail Dust) - (Nov 22, 2005)
#05-08-42-017 Tail Lamp Housing Separates from Tail Lamp Retainers (Replace Tail Lamp Housing Retainers) - (Nov 11, 2005)
#01-07-30-038C Diagnostic Trouble Code (DTC) P0757 Set, Service Engine (SES) Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (Oct 12, 2005)
#05-08-66-006 Door Ajar Lamp On, Chimes Sound or Door Locks Cycle While Driving (Adjust Swing Gate Striker) - (Oct 11, 2005)
#01-07-30-002E Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative (Verify and Repair Source of Voltage Loss in Transmission Solenoid Power Supply Circuit) - (Sep 23, 2005)
#05-08-51-005 Cloudy Spot in Paint After Protective Covering is Removed (Heat Area) - (Sep 21, 2005)
#05-04-21-006 Service Four Wheel Drive (4WD) Light On, Diagnostic Trouble Codes (DTC) B0790, B2725, C0359 (Reprogram Transfer Case Control Module (TCCM)) - (Sep 14, 2005)
#05-06-04-055 Service Engine Soon (SES) Light On, Diagnostic Trouble Code(s) (DTC) P0442 Small Evaporative Emissions (EVAP) Leak and/or P0455 Large EVAP Leak (Reposition Fuel Filler Housing Seal) - (Sep 2, 2005)
#05-08-42-012 Trailer Park Lamps, Turn Signal, Stop Lamps or Trailer Brakes Inoperative (Tie Strap Trailer Wiring Harness to Trailer Hitch) - (Aug 31, 2005)
#05-06-04-053 Engine Rough Idle During Initial Warm-Up After Cold Start and Diagnostic Enhancements for DTC P0507 (Reprogram PCM) - (Aug 25, 2005)
#05-08-111-004A Window Outer Belt Strip Ends are Glossy (Wash Molding) - (Jun 16, 2005)
Old 01-23-2006, 08:05 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
nothing to serious really. The last one is kinda funny.
____________________________
Old 01-23-2006, 08:50 PM
HummerB HummerB is offline
HummerB is off the scale
yea that last one is pretty dumb!
Birch wht (black accents/anti-bling), auto lux, oem flat side steps, oem brush guard, silver crossbars, SMA exhaust, PIAA 520 offroad lights, Valentine One.
Old 01-23-2006, 08:58 PM
wannabeH3's Avatar
interesting.. i have this one
and perhaps this one
(with insurance)
Old 01-23-2006, 09:12 PM
I hope everyone understands that not every bulletin will affect every vehicle.
Bulletins are issued on problems found in the field on a limited number of vehicles. One of the problems is the automatic replacement of parts by technicians when not necessary (last bulletin is a good example).
Old 01-23-2006, 09:29 PM
Do they have one for when your four week old truck looses 2nd and 4th gears?
Old 01-23-2006, 09:56 PM
Do they have one for when your four week old truck looses 2nd and 4th gears? </div></BLOCKQUOTE>
Did you get it to the dealer yet? Any word?
Old 01-23-2006, 10:04 PM
Did you get it to the dealer yet? Any word? </div></BLOCKQUOTE>
Hi Kids, today's word is: SUCK!
Can you say SUCK? I should know more on Tuesday I hope.
Old 01-23-2006, 10:50 PM
Where did you loose them? Could it be a solenoid(s)? Those 4T transmissions have been around for years. Tell 'em you want a replacement, I would never trust a technician to rebuild a trans, unless he/she knows what they are doing. Too many checks (mechanical and air) for most to understand. A replacement trans is an easy in/out for almost any tech.
Old 01-23-2006, 11:13 PM
partsguy partsguy is offline
Did you get it to the dealer yet? Any word? </div></BLOCKQUOTE>Is It a automatic or a "can't drink """ coffee"""and drive"transmission I have info on the later.If you need to call me.
Can you say SUCK? I should know more on Tuesday I hope. </div></BLOCKQUOTE>
Old 01-23-2006, 11:15 PM
H3HUMVEE's Avatar
H3HUMVEE H3HUMVEE is offline
H3HUMVEE is off the scale
Hey f5fstop ... thanks for the updated bulletins, great info.
_. __________
H /__________\
3[O][][][][][][O]
Old 01-23-2006, 11:18 PM
DarthKarl's Avatar
DarthKarl is off the scale
X2
Thanks for keeping us all updated.
Old 01-23-2006, 11:22 PM
Kid Shyleen Kid Shyleen is offline
Kid Shyleen is off the scale
fstop, you're an asset to this forum, and I thank you for all your efforts and help!
Old 01-23-2006, 11:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by partsguy:
It's the auto.
Old 01-23-2006, 11:36 PM
FishnMan's Avatar
FishnMan FishnMan is offline
FishnMan is off the scale
Thanks for the update f5fstop. It's been cold up here.... will be negative -30-40 F all week. My doors have not been closing and funny...there is a bulletin about it! Go figure. Also have been having beaucoup problems with STAB SYS FAILED, SERV 4WD, TRACTION CONTROL FAILED warnings! I take it in next week for first oil change and I will have them take care of these issues (that apply). I will love the looks on their faces when I hand them my list of info (only because they are a GM dealer, not a Hummer dealer. They might be a little challenged at first as they see only a few Hummers up here in Fairbanks. It's actually kinda scarey to think they will actually do a good job as they couldn't even align my head/fog lights properly! Luckiliy it's all under warranty!!! Anyway, thanks again.
Fishin is the Mission!
Old 01-24-2006, 12:09 AM
SDH3 SDH3 is offline
SDH3 is off the scale
N/A on all of the above bulletins! Wow, how come I feel like I won something?
Old 01-24-2006, 01:18 AM
Nick Danger Nick Danger is offline
Nick Danger is off the scale
I think I've got the "no power light for On Star" Picked up the truck on Friday and no light still. Thought On Star was just slow to activate.
Old 01-24-2006, 03:01 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
I think there might be a couple new ones for my rig:
#07-09-62-001 Glass breaking sound from rear window (don't back into a tree) - (Dec 31, 2005)
#37-08-31-001 Loud ringing sounds, headache, and sore throat (Go to the NFC championship game and watch the Seahawks kick the Panther's a$$) - (Jan 22, 2006)
#06-08-44-002 Groaning sounds coming from rear interior of vehicle at rest stop on I-5 (happens AFTER the game and your girl friend wants to celebrate the 1st superbowl in Seahawks history!) - (Jan 22, 2006)
