Old 09-19-2005, 03:55 AM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
I'm weighting my options on the exhaust issue. Fist I thought Borla was the way to go, but they stick waaayyy too much out of there. Then I looked into the other different options. Can't really make my mind which way to go now...
Does the dealer installed after market exhaust with off road tips8 pipes provide the same hp and sound increase as the ones with dual stick out pipes? Has anybody seen any others provide similiar duals that Borla offers? And those with "no show" off road tips?
W1N's Avatar
W1N W1N is offline
Old 09-19-2005, 09:42 PM
Fubar's Avatar
Fubar Fubar is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by W1N:
Does the dealer installed after market exhaust with off road tips8 pipes provide the same hp and sound increase as the ones with dual stick out pipes? Has anybody seen any others provide similiar duals that Borla offers? And those with "no show" off road tips? </div></BLOCKQUOTE>
I would suspect that you could get an off-road tip for any manufactures exhaust system.
It's just the tip or end of the exhaust it's not going to change any hp gain.
From pershonal experience I konw Corsa has an off-road tip that exits where your stock one does, you could purchase the tip and have any mufferler shop weld it on, it wouldn't matter if you had Borla,Corsa,or any other manufactures cat back system.
Old 09-19-2005, 10:13 PM
4churchill is off the scale
I have flowmaster series 50 or 40 installed (cant remember) dual tip just to the right of the trailer hitch...looks great sounds great wors great and hasn't broken off yet!!
www.HUMMERNut.net
Old 09-19-2005, 10:17 PM
Big Jag's Avatar
Big Jag Big Jag is offline
Big Jag is an unknown quantity at this point
Re: BORLA EXHAUST - I'm not sure what you mean by stick out, but they do not stick at all IMO. They are recessed in about 3 to 4 inches from the end of the bumper and hang just below the bumper. They look and sound great in my opinion.
Big Jag
05 H2 (sold)
Old 09-20-2005, 12:15 AM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Big Jag:
Re: BORLA EXHAUST - I'm not sure what you mean by stick out, but they do not stick at all IMO. They are recessed in about 3 to 4 inches from the end of the bumper and hang just below the bumper. They look and sound great in my opinion. </div></BLOCKQUOTE>According to your picture they clearly reduce the rear bumper clearance by 3-4". And I guess the reduction in departure angle would be in excess of 15 degrees. On the plus side they do look good.
Old 09-20-2005, 11:18 AM
VTSTOMPER is off the scale
I am checking out the magnaflow, and it looks like it does not hang any lower.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-21-2005, 05:37 AM
W1N's Avatar
W1N W1N is offline
I am checking out the magnaflow, and it looks like it does not hang any lower. </div></BLOCKQUOTE>
As the OEM exhaust is actually behind the bumper, so that the tip is pretty much on the same level as the lowest part of the bumper. My idea was to find a true dual which would do the same. Not to exit under bumper as most do. The best thing would be to find a exhaust tech that would do this on both side (like Borla does). That is, have one pipe on both sides behind the bumper as OEM is and still provde the sound, hp and mpg benefits if there are any...
Old 09-21-2005, 05:02 PM
mattyg50's Avatar
mattyg50 mattyg50 is offline
mattyg50 is off the scale
i installed the magnaflow kit, sounds great and the 2 tips are in the same area as the stock tip
Old 09-21-2005, 06:26 PM
We just talked about this a couple of days ago. Here's a pic of the B&B exhaust. It's tucked up and away. It's 3.5" with a 4.5" tip.
BTW, shpbldr hit his Borla exhaust on some rocks at Paragon.
Old 09-21-2005, 06:28 PM
From behind you can't even see it. Just like stock.
Old 09-21-2005, 06:59 PM
W1N's Avatar
W1N W1N is offline
From behind you can't even see it. Just like stock. </div></BLOCKQUOTE>
Thanks Ken! How is it?
Old 09-25-2005, 01:36 PM
W1N's Avatar
W1N W1N is offline
Can you provide me the product number. All I can find on their website is a true dual directly outputting below the bumper. They have the optional stealth tips that look like off road tips, but if the tail piping arrives fron the mufler horizontaly (that's how it looks in their pircture, differently than in your picture) I really don't see how location of the tip would be the same than the stock.
Thanks!
Old 09-25-2005, 02:57 PM
The top one is what I have:
http://www.bbexhaust.com/New/auto-fl...p?page=h2.html
I thought it was 4.5".
Old 09-25-2005, 06:23 PM
shipbldr shipbldr is offline
shipbldr is off the scale
FWIW...
I have the borla exhast.
Though they didn't intend it. I can remove my exhaust tips at the muffler exit in 3 minutes or less. Re-install is about 4 minutes.
I wheel with mine on. And with the exception of my first time up Vodoo... they have been fine.
(NEWFLASH>>>> Yes, there has now been a second time up voodoo... very different from the first. Film at 9:00....)
Old 09-25-2005, 09:20 PM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
FWIW...
(NEWFLASH>>>> Yes, there has now been a second time up voodoo... very different from the first. Film at 9:00....) </div></BLOCKQUOTE>
Did you do any mods (lift, etc) before trying voodoo again?
Old 09-26-2005, 03:56 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by CslRkH2:
FWIW...
Did you do any mods (lift, etc) before trying voodoo again? </div></BLOCKQUOTE>I bet he now has a winch, lift, tires and maybe a supercharger.
Old 10-29-2005, 06:21 PM
W1N's Avatar
W1N W1N is offline
I thought it was 4.5". </div></BLOCKQUOTE>
I kinda remember that you said this being loud. Is it so? You didn't happen to have any clips to prove yourself
