05-01-2003, 08:00 PM
Are the K and N type air filters worth getting? I am interested in anyone's experiences with these rather than the manufacturers "hype".
Support the 2nd Amendment.
05-01-2003, 11:49 PM
I have yet to find one...do they make them for the H2 yet?
05-03-2003, 04:36 PM
OUSUCKS , I just check the K & n website and there no air filter for the H2.
05-04-2003, 03:26 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by OUSUCKS:
I have yet to find one...do they make them for the H2 yet?<HR></BLOCKQUOTE>
I contacted K&N and was advised that don't make one YET, but hopefully they will soon have a replacement filter for use with the Hummer H2.
Contrary to the information that PhilD offered, I have previously done extensive research into the qualities and benefits of using K&N filters, and was quite impressed. Reports by highly qualified experts, well-known professional racing authorities and many satisfied customers convinced me to buy one for my GMC Denali. The air filter had a 10-year/million mile warranty and only required "servicing" (cleaning and re-oiling) every 50,000 miles. The information I gathered indicated that the filters have scientifically been proven to filter much smaller particles of dirt and dust than stock, disposable air filters --- and they ALSO allow higher air flow rates while doing so.
Even with a minimal amount of research, it was quickly apparent that K&N is, if not the best name if filtration --- then definitely ranked at the top of companies making filters.
I think that if you ask most mechanics, they will have similar opinions... or you might check out:
http://www.knfilters.com/facts.htm
if you want to learn more about K&N filters. Of course you might think that is all hype?
I also use K&N oil filters exclusively because they are reportedly far superior to those made by Fram, etc. After re-reading this post, maybe I should get a PR job working for K&N???
Ed
05-04-2003, 12:20 PM
K & N filters have always worked for me...at least in my head. I always liked to think the k&n did make a differnce in performance. Its takes a lot more than just air filter swap to get a SOTP feel though.
I read performance magazine's test article on a Vette once where the filter was entirly removed and trap times improved as well as speed. The K & N is supposed to flow more air. More air ...more power. More power sells.
For now, I'm going to leave to stock filter and airbox alone. I doubt if I would ever tell a diffence.
I can tell what will kill the performance though, 37" MT/R's. The higher gearing from the tire swap is like throwing the anchor out, causing the transmission to seach back and forth. Second thoughts now..
buddy
05-04-2003, 03:20 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by buddy:
K & N filters have always worked for me...at least in my head. (clip) For now, I'm going to leave to stock filter and airbox alone. I doubt if I would ever tell a diffence.<HR></BLOCKQUOTE>
With all the wildly exaggerating hype we get from every direction, it is difficult to sort out the facts. Judging only by the 90+ percent of entries racing in Baja-type events using K&N filters tends to convince me. I thought that it was an acknowledged fact that K&N filters ruled... Maybe I am a victim of hype?
As PhilD said though, it is a moot point until K&N makes a filter to replace the stock element on our H2's. However, I don't think I will buy into the hype from the aftermarket folks marketing the cold air intake units for the H2. Cost hundreds of dollars with very questionable real-life results. Maybe if they get better at hype they'll get my money?  Until then, I'll just wait for the K&N replacement for the stock air filter.
Ed
05-04-2003, 06:51 PM
TheGoodHummerMan,
This may be of some interest.
air filter
Hope this link works.
Buddy
05-04-2003, 07:42 PM
Buddy,
Oh great, now even more factors to further complicate matters.
The press release isn't totally clear to me, and I wonder if the Donaldson filter for the H2 is a re-useable/cleanable filter like the K&N filters? I wonder when GM will make them available and if GM will be the sole source for them...
It sounds like the filter will be a big improvement over currently used filters. If that isn't just "hype". The fact that GM is directly involved gives Donaldson added respectability for sure.
Plus, current availability, is a major PLUS factor.
Thanks a lot for the additional info!
Ed
05-04-2003, 07:54 PM
Ed,
I understand completely.
Decisions, Decisions, Decisions
buddy
