Old 02-10-2003, 11:20 PM
1 bad h2 1 bad h2 is offline
1 bad h2 is off the scale
this just started this afternoon my drl's wont turn off even while my headlights are on.
and when i use my left signal the drl's flash with my signal light.Does anybody know how i can turn them off not to run down the battery?there staying on even after i lock the h2.
please help
please help
Old 02-11-2003, 12:27 AM
TG TG is offline
TG is off the scale
Wow, sounds like you need a visit to your local Hummer Dealer to get your electrical system checked out. The H2 has an auto shut-off system that prevents battery drain, this feature will kick in after about 30 min. If you have not been in your Hummer lately, go out and see if power shut-off system has activated.
Old 02-11-2003, 01:36 PM
oc192 oc192 is offline
oc192 is off the scale
1badh2,
Have you added any accessories to the electrical system like lights, dvd, nav, screens???
03 H2
02 Viper GTS
02 Z71 Suburban
98 Harley Davidson FLSTF
03 H2
02 Viper GTS
02 Z71 Suburban
Old 02-11-2003, 02:03 PM
Klaus's Avatar
Klaus Klaus is offline
Could be a stuck relay in the underhood fuse box. You can swap out the relays to test it. The DRL, low beam headight, and high beam headlight relays are the same. They can be interchanged.
My high beam relay was bad from the factory. At night, I switched on my high beams, and lost my headlights! I swapped the relays and found the bad one. The relays are standard GM. Chevy dealers stock them.
Klaus
Old 02-11-2003, 03:02 PM
Klaus's Avatar
After re-reading the post, it sounds more like a bad ground. At any rate, a dealer visit is in order!
Old 02-11-2003, 05:19 PM
buddy buddy is offline
buddy is off the scale
It could be a stuck relay. I had one stick on high beam once and had to out of traffic to remove it.
