Old 03-24-2006, 08:52 PM
k9tim
I Just had KodiakZ install an Eclipse NAV into my H3 and noticed in the online version of the manual that you can change the opening screen jpg.
Has anyone tried this and actually had success?
I've went through about 8 cd-r's already and am going down in flames every damn time..
BTW: Kodiakz does some excellent work! Highly recommended!!
Old 03-24-2006, 09:38 PM
fourfourto's Avatar
I have a eclipse avd30d it has 3 wallpaper settings .I looked at manual I didnt see anything about start up screen.
Old 03-24-2006, 11:35 PM
Mark805's Avatar
Mark805 Mark805 is offline
Mark805 is off the scale
I have the Pioneer Avic-d1 (Yes I know completely different nav unit but...) I was able to make a dvd rom that had the opening screen and i changed it but used the same file name. On the pioneer the file is BGOPEN2.JPG
The pioneer unit loads its graphic off the dvd and stores it in memory so after, i loaded it the first time i went back to the factory nav dvd. If this is the same way the eclips works just drop the dvd in your computer and explore the files and see what the opening screen is called.
None of this probably helps but you never know.. and it gives me a chance to show off my custom nav screen
08 H3 ALPHA Carbon Black
Dear GM: PLEASE SELL ME AN HX
Old 03-24-2006, 11:54 PM
X2! He put one in ours also. I'm not sure on the screen change other than the 3 wallpapers.
BTW- There are a bunch of us wheeling on Sunday. Send me a PM if you are interested and I'll get you the times and meeting place. nothing to hardcore but fun.
Old 03-24-2006, 11:57 PM
AZH3  AZH3  is offline
AZH3  is off the scale
You guys are soo cool. I'm gay and a loser.
please wipe your drool before entering my vehicle.
Old 03-25-2006, 12:04 AM
kodiakz kodiakz is offline
kodiakz is off the scale
Tim, I will call Eclipse tech on Mon and see if they have any suggestions. What exaxtly happens when you try and what format (jpg, tiff, bitmap) are you using?
Old 03-25-2006, 01:37 PM
k9tim
@442- I just checked the online version of your manual and it looks like they didnt include the feature in the 30d.
30D Manual
On the 50D and 5500 it says you can do it if you use the following settings:
Disc format: ISO9660 Mode 1
File Size: less than 100kb
File name: ISO9660 Level 2 (up to 31 bytes)
File ext (type): .jpg (non jpg-2000)
Write method: Single Session
Image size: 416x240 or smaller
and you need to add a blank file called CSM.txt also.
Its all on page 33 of the 50d and 5500 manuals- online only though) 50D manual
@ Kodiakz- I should have all the right formats going, i've used three diff disc mfg's and it does absolutely nothing. Almost like it was a mistake in the manual.
Not a big deal either way, I just wanted to have the NAV boot up with the H3 logo
Thanks in advance for any efforts!
@Timgco- man thanks for the invite. I would be all over that but I run a Scenario Paintball team and we have to practice this Sunday... Sounds like a kick though- thanks again!
Old 03-25-2006, 05:06 PM
fourfourto's Avatar
Old 03-25-2006, 05:51 PM
Make sure that you have a little filler text in that file. When you go through the setup, does it follow along like the steps in the guide and then not work, or does it fail before that?
Old 03-25-2006, 06:03 PM
k9tim
It does nada. Not even display the "Change Opening Screen" test ..
And yep, had some misc text in the CSM file.
I'm going to play with it more later. Installing a compressor in the truck now
Old 03-27-2006, 11:32 PM
k9tim
So Kodiakz calls me tonight and goes over the formats and everything, then he asks me if I had tried to put the cd with pics into the DVD slot instead of the CD slot.
uhhhh, no. I haven't.
I run out and try it and Shazam! New opening screen on the Eclipse!
Very cool- thanks much Kodiakz! Too bad Eclipse didnt put out a Eclipse NAV for Dummies manual. I would have been ok at that point!
Thanks again bro, I appreciate you looking into it and thinking "outside the box".
Old 03-29-2006, 11:03 PM
fourfourto's Avatar
Can I use any image ?.Im going to see if it works with mine.
Old 03-29-2006, 11:20 PM
Any .jpg that is not larger than the maximum size constraints (I can't remember exactly what they were, but can look them up if you need).
Old 03-30-2006, 01:37 AM
fourfourto's Avatar
There listed above .Ill give it a try this weekend.
Is there a way to get rid of the I AGREE screen that comes up for the navigation?
Old 03-30-2006, 01:11 PM
k9tim
They have to be smaller than 100k.
Old 03-30-2006, 01:28 PM
fourfourto's Avatar
Anyone have the image of h3 that is used on the factory dvd players?
also
Old 03-30-2006, 10:47 PM
fourfourto's Avatar
Im dont know if I should get a graffic or a pic I was thinking this one its the right size.
any ideas ?.
Old 03-31-2006, 02:14 PM
fourfourto's Avatar
k9tim What did you use for your start up screen.
List a pic maybee ill use same.
Mark805 your looks good too ,list a pic
Old 04-01-2006, 12:36 AM
Not unless you are daddyo hacker and can dump the firmware and rewrite your own version!!
Old 04-01-2006, 05:37 PM
Rick's Avatar
Rick Rick is offline
Rick is off the scale
Hi all..
I'm a long-time lurker, first-time poster. I've been reading a lot of threads and ran across this one.
I've followed (what I think) are the directions given here and also in the manual supplied in the link above. I've created a JPG image @ 32k simply called 1.jpg along with a CSM.txt file with a few words written in as filler. I popped the CD into the DVD slot and nothing happened.
Can someone tell me what I did wrong here?
EDIT - BTW... I have the 30D version.
Thanks,
Rick
2006 H3 - Luxury - Superior Blue - Sunroof - Chrome Pkg. - Chrome Step Tubes - AVN30D with rear view camera and iPod connection - Volant CAI - MagnaFlow dual exhaust - Throttle Body Spacer - Train Air Horn (to be installed) - More adds to come (New shoes & supercharger!)
1990 Porsche C2 (911) - Highly modified and very, very fast!
