  #41
Old 11-13-2003, 10:57 AM
drouke drouke is offline
drouke is off the scale
This may have well been the solution i've been looking for. Do you guy's think I could use this to run the audio for my DVD and Playstation 2? I'm usuing an RF modulator right now and i hate it. Also is there any of the hummmm i get with acceleration? Or is that eliminated because it connected directly to the head unit?
Old 11-13-2003, 07:30 PM
Klaus's Avatar
Klaus Klaus is offline
I received this from Rob Putman at Soundgate today:
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>From: Rob Putman [mailto:r_putman@soundgate.com]
Sent: Thursday, November 13, 2003 2:43 PM
To: Klaus
Subject: PIOGM1V2
Hello Klaus,
Testing of the PIOGM1V2 was finished yesterday and it passed all tests
splendidly. We should be shipping these parts in a week and a half or two
weeks.
With regard to the text display using the 910... the factory radio will show
the first 8 characters of the text - the text will not scroll on the screen.
You can push the display button on the radio to show channel number first,
then push again for artist, then push again for song title. With each of
these categories the first 8 characters of each display. We hope this won't
be a serious detraction, for it is our only remedy at this time.
Thank you for your patience and patronage.
Best Regards,
Rob Putman
President, SoundGate
ph: 307-674-4707 (ext 206)
fx: 866-674-4819
www.soundgate.com
m-f 8am - 5pm mst<HR></BLOCKQUOTE>
Klaus
Old 11-14-2003, 08:09 AM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
Klaus,
Thanks for the updates. If he happens to e-mail you when shipping starts will you please post so we can all share in on the wealth. Thanks in advance.
Craig
04 H2- Lux,nav, air suspension
Craig
04 Pewter H2- Lux,nav, air suspension
Old 11-14-2003, 12:01 PM
Klaus's Avatar
If I get anything else from Rob, I'll pass it along.
I went ahead and placed an order for the adapter with Log Jam:
http://store.yahoo.com/logjam/soundpiogm1.html
Klaus
Old 11-21-2003, 05:28 PM
Klaus's Avatar
Just an update... I received and email from Log Jam that my adapter shipped today.
Klaus
Old 11-22-2003, 04:44 AM
I have ordered mine and a 12 disc changer. XM is coming for Christmas this year. I will let everyone know how well it works with the 04 Nav units. Hopefully it does work like Soundgate said it would. Should have it installed in time for Thanksgiving
Craig
Craig
Old 11-22-2003, 07:59 AM
H2Dude H2Dude is offline
H2Dude is off the scale
Klaus,
Thanks for all the research on the DVD/XM hook up through the radio. I also ordered the adapter and cable from log jam and it shipped today.
Now I need to go out and get the XM tuner. Any suggestions on the best XM Pioneer tuner(model #) or DVD system?
The way I understand the adapter is I should be able to hook up the XM and one additional device (DVD) via the 2nd aux input.
Old 11-22-2003, 11:20 AM
Patriot Patriot is offline
Patriot is off the scale
H2 Dude,
Klaus can correct me here but the adapter has only one input with the ability to pass thru two inputs. I called Soundgate to confirm. There won't be two IP-bus connections...only one....BUT...
On the Pioneer XM tuners of CD changers there is an IP-bus "pass thru". Kinda like a daisy chain. You can hook up the device and then use the pass thru jack on them to add another. You can add an IP-bus to RCA jack adapter to the IP-Bus pass thru on the XM tuner to get your second input.
Another option is to buy some of the IP-bus configuration adapters Klaus has posted here on this thread to use with the PIOGM1V2 to get two seperate inputs (non Pioneer).
Soundgate also said that with any Non-Pioneer input, they cannot promise proper operation because there are just too many configurations and gagets that can be added (their standard disclaimer)...but I'm sure most will work OK.
Oh...and I think I'm gonna try the Pioneer 910 for an XM tuner.
Old 11-22-2003, 06:40 PM
Thanks for the info guys. I will order the Pioneer 910 also. Anyone know if I will get the 8 character or 16 character display on our factory radio.
Cant wait to get that satellite radio rollin.
Old 11-22-2003, 07:02 PM
Klaus's Avatar
Patriot is right on.
The Pioneer GEX-P910XM:
http://www.crutchfield.com/S-dU6gFom...sp?i=130P910XM
Here's a $20 off link for Crutchfield if you use a Mastercard:
http://www.crutchfield.com/I-rmc1cagb/index.html
Don't forget you will need an antenna!
Klaus
Old 11-22-2003, 07:05 PM
Klaus's Avatar
H2Dude, we will only get 8 characters... It's a limitation of our GM radio.
Klaus
Old 11-22-2003, 07:28 PM
Thanks Klaus, was just curious.
Antenna? The 910 doesn't come with one?
I guess my next question is what antenna do you guys recommend?
Old 11-22-2003, 08:24 PM
Klaus's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2Dude:
I guess my next question is what antenna do you guys recommend?<HR></BLOCKQUOTE>
Here's where it gets interesting. XM Radios use either a 1 or 2 lead antenna. The newer XM Radios use the 1 or single lead (connector) antenna.
The Pioneer 910 uses the older 2 connector antenna. The root of this is one connector for satellite reception, and one connector for terrestrial reception. As I said, the newer setups have combined the connectors.
Now, you can buy the 2 lead (connector) antenna for your 910 and be through. However, the rage in XM car antennas right now is the Blitzsafe:
http://shop.store.yahoo.com/xmfanstore/blxmmianxm.html
The Blitzsafe is a single lead antenna. To use it with a Pioneer 910, you will need a single to dual connector adapter. Guess what... XM does not have one yet! However, there is a single to dual adapter for Sirius units:
http://www.crutchfield.com/S-hh0gwDI...asp?i=209SIRSP
These adapters have been reported to work fine with XM:
http://www.xmfan.com/viewtopic.php?t=10841&highlight=sirsp&sid=029ddce5 32c111376b27ac281261060e
The official XM single to dual lead adapter is due out any time, so you might want to wait.
In a nutshell:
1. New XM systems use a 1 lead (connector) antenna.
2. The Pioneer XM radio uses a 2 lead (connector) antenna.
3. XM currently does not have an antenna adapter, but one should be released soon.
It is reported that reception is much better with the new, single connector antennas:
http://www.xmfan.com/viewtopic.php?t=10487&highlight=sirsp&sid=029ddce5 32c111376b27ac281261060e
Anyway, something else to think about!
Klaus
Old 11-23-2003, 06:12 AM
Once again I thank you for the good info re the XM hook up. The cost of XM radio in my H2 keeps creeping up. My adapter and aux cable are in the mail. I will order the Pioneer 910, the blitzsafe antenna, and the SIRSP 2 to 1 adapter.
If you hear about a Pioneer 2 to 1 adapter comming out let me know.
Otherwise I am determined to get this thing rolling.
One last question Klaus do you know if the SIRSP 2 to 1 adapter will plug into the pioneer 910 or will I need modification to the connectors.
Old 11-23-2003, 11:15 AM
Klaus,
I noticed the Blitzsafe is much less exspensive than say a Terk-3???
Why??
If you don't mind getting a few scratches on the top of my H2..is this little Blitz AS STRONG an anteena than the other button-magnet types?
I don't mind the scrathes..I just want a good, strong antenna that is rather inconspicuous on top of the H2.
Old 11-23-2003, 01:24 PM
Klaus's Avatar
Patriot,
Good questions... Unfortunately, the parts have not arrived yet.
I went ahead and ordered the Blitzsafe antenna, based on info from the XMFan web site and forum:
The Blitzsafe antenna does come with an adhesive pad to stick it on the roof if you are not happy with the magnetic mount.
The single connector antennas are part of what they are calling "second generation" XM equipment, so that may explain the better performance and lower price.
I'll know more after UPS visits me this week.
Klaus
Old 11-23-2003, 03:44 PM
hummer17 hummer17 is offline
hummer17 is off the scale
LAPD or anyone:
Has anyone figured out or tried using the NAV at the same time as the CD-changer?
Also - LAPD - any progress on getting the nav to accept inputs when travelling above 8MPH?
Thanks Klaus for all of the information...
Old 11-23-2003, 06:19 PM
Klaus's Avatar
One last question Klaus do you know if the SIRSP 2 to 1 adapter will plug into the pioneer 910 or will I need modification to the connectors.<HR></BLOCKQUOTE>
Until the UPS man arrives, this is the best info I can give you:
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>From the XMFan forum:
I used the blitzsafe antenna with the sirius splitter without removing the purple plug. All you have to do is carefully file off one of the raised ridges on the brown connector on the splitter, then it will mate.
I got the SIRSP and the Blitzsafe antenna today; the SIRSP works great with this antenna and my Pioneer GEX-P900XM, I hope it works as well with all the other XM radios out there.
Confirmed. The Splitter in conjunction with the Blitzsafe Micro antenna DOES WORK with the Alpine TUA-T020XM reciever. The antenna works without it, but it complains about ANTENNA on the display of the HU non-stop. putting the splitter in place works just like my sharkfin did. Thanks XM guru's for the great idea of using the splitter. I think we can now confirm the Blitzsafe can be used on ANY reciever with the $20.00 splitter. EXCELLENT! XMFanStore--- you should DEFINATLY Start carrying this product!
http://www.xmfan.com/viewtopic.php?t=10841&start=0&postdays=0&postorder =asc&highlight=sirsp%20pioneer%20blitzsafe%20anten na&sid=1530e73b664f2dc2fe525ea7e1a0734b
<HR></BLOCKQUOTE>
Klaus
Old 11-23-2003, 06:46 PM
Klaus,
Sounds good. I can't wait to here how your hookup turns out. Try and take some pics of your install so we can check it out.
Old 11-24-2003, 05:09 AM
Hummer17 I will know if the factory Nav works with the cd changer via the Soundgate adapter as soon as UPS visits me which should be within 2 days. Hopeully Wednesday I will have it all working. I will post as soon as I do.
Craig
Craig
