Old 12-24-2005, 02:02 AM
StarsnBars's Avatar
StarsnBars is off the scale
timgco,,, You probably saved alot of peeps a bunch of grief posting the problems with the Rancho lift. Hats off to ya bro. Really sux you had to go thru the mess. I was thinking about getting that lift and your posts stopped me cold. Some pics of those new meats would be nice. Thanks ,, Happy Holidays
Old 12-24-2005, 03:22 AM
HummerB HummerB is offline
HummerB is off the scale
timgco if they rub "a bit" that doesn't fit. sorry to sound like johnny cockrin with the ryhme. i mean i dont really like the idea of any rub on a brand new expensive tire. they look awesome but i dont want any damage. do you plan on adding wheel spacers to correct? i want to keep my wheels or atleast the size and add 35's but i would like to be comfortable with the clearance in the fender wheels.
Birch wht (black accents/anti-bling), auto lux, oem flat side steps, oem brush guard, silver crossbars, SMA exhaust, PIAA 520 offroad lights, Valentine One.
Old 12-24-2005, 05:50 AM
cherokeekid cherokeekid is offline
cherokeekid is off the scale
when you bump the tire size it's pretty tough not to touch a tad here and there, especially if you twist the suspension up. with these the fonrt doesn't flex much so you avoid alot of contact.
I would expect to trim a bit here and there. remember every manufacturers tire is going to have a differnt actual size from the one listed, wheel width/air press etc can also affect the actual size and your backspacing/width will affect contact
Old 12-24-2005, 08:06 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummerB:
timgco if they rub "a bit" that doesn't fit. sorry to sound like johnny cockrin with the ryhme. i mean i dont really like the idea of any rub on a brand new expensive tire. they look awesome but i dont want any damage. do you plan on adding wheel spacers to correct? i want to keep my wheels or atleast the size and add 35's but i would like to be comfortable with the clearance in the fender wheels. </div></BLOCKQUOTE>
LMAO at your avatar.
Ok,
Defenition of rubbing on my truck: It only touches on the dr sd sway bar at full lock and you cannot even feel it in the steering column/ wheel. It is so minor that it won't mess up your tire. The only reason I even mentioned it, was so that owners wanting to MT's on there with larger lugs than my tires will expect a little more rubbing on the swaybar.
the H2 I had with 35's rubbed more than the H3 with 35's. the 37's on the H2 polished the swaybar on both sides at full lock and never showed wear that it was damaging the tire. I only had about 14,000 miles of wear on them though.
Old 12-24-2005, 10:17 PM
crop000s crop000s is offline
crop000s is off the scale
Cool, glad it worked out even though you had to take one for the team. If your ever down this way the beer is on me. Would love to see some pic's when you get time, maybe front, rear and side shots?
Dallas Stars Green, adventure package, 5 speed, sunroof, xm, mp3,grill guard, tranny guard, rocker guard, rubber mats, GOBI rack, PIAA lights.
Old 12-24-2005, 10:33 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
OK tire guys you seem to know what your talking about. I'm thinking of going with a 17 or 18 inch wheel. I know the extra rubber is needed at the sidewall when airing down, but will the slightly larger wheels get f-ed up when offroad or will there still be enough rubber. Obviously, if I'm too hard on it, any wheel will be damaged but I'm just talking trailing, hill climbing, and nothing too crazy. Thanks for the input.
WWW.BCBI.COM
Old 12-24-2005, 11:11 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by hmrlvr:
OK tire guys you seem to know what your talking about. I'm thinking of going with a 17 or 18 inch wheel. I know the extra rubber is needed at the sidewall when airing down, but will the slightly larger wheels get f-ed up when offroad or will there still be enough rubber. Obviously, if I'm too hard on it, any wheel will be damaged but I'm just talking trailing, hill climbing, and nothing too crazy. Thanks for the input. </div></BLOCKQUOTE>
You'll still be fine with 17's. 18's would still be good too, but you will find the price starts to jump up there too.
Old 12-25-2005, 03:22 PM
the wheels i wanted wont fit in a 16 so now thinking 17's with these http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf in a 315 70 r17 they measure 34.5" overall the wheels are 17 x 9 with 4.5" bs offset is -12 how will these work thanks
Old 12-26-2005, 12:24 AM
Humm3r Humm3r is offline
Humm3r is off the scale
Mathematically, they should work....but they'll stick out quite a bit. Let us know how it works out.
Old 12-26-2005, 01:16 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by NEOCON1:
the wheels i wanted wont fit in a 16 so now thinking 17's with these http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf in a 315 70 r17 they measure 34.5" overall the wheels are 17 x 9 with 4.5" bs offset is -12 how will these work thanks </div></BLOCKQUOTE>
They will stick waaaaaaayyyyyy out! If you go look at my post inthe photos section with the lift, those were 4.5" of backspace. I hated it so bad becasue you drive through on puddle or rain/ snow and your rig is trashed! If that's the look you want, great, it looks good. But as a daily driver, I am happy they are back in!
Old 12-26-2005, 01:32 AM
hmrlvr's Avatar
Neocon, which wheels were you looking at?
WWW.BCBI.COM
Old 12-26-2005, 02:18 AM
Neocon, which wheels were you looking at? </div></BLOCKQUOTE> I really like these and wanted them in a 16 x 8 but they wont fit so was thinking 17x9
Old 12-26-2005, 02:47 AM
timgco , thanks for being our rancho guinne pig and letting us know about problems you had . not sure if i want that wide of a look but maybe with truck at stock height it will look good . the 315's should really fill up the wheel wells
humm3r i will post pics if i go with this setup.
Old 12-26-2005, 03:05 AM
hmrlvr's Avatar
Those will look good on the green rig.
WWW.BCBI.COM
Old 12-26-2005, 03:40 AM
NEOCON1....
I was playing around with the numbers and this is what I'm figuring. The 17x9's should stick out about 3" farther with the 35's, than the stock rims with 33's. Even with a wider tire & rim, the interior of the 35's will be out about an inch from where the 33's sit now. Rubbing shouldn't be an issue. Looking forward to the pics.
Old 12-26-2005, 03:45 AM
thanks for crunchin those #'s i think i will go for it should give an agressive stance
Old 12-27-2005, 07:20 PM
just went to big O on my lunch tires 315 70 17 will be there tomorrow but 2 to 3 weeks for my 17x9 chambers . now i have to get grill line-x'd before wheels arrive . i will keep you all posted as it progresses
Old 12-27-2005, 09:09 PM
just went to big O on my lunch tires 315 70 17 will be there tomorrow but 2 to 3 weeks for my 17x9 chambers . now i have to get grill line-x'd before wheels arrive . i will keep you all posted as it progresses </div></BLOCKQUOTE>
what offset/ backspace did you order?
Old 12-27-2005, 10:12 PM
hey timgco 17x9 with 4.5 bs they will stick out about 2 in more than stock should be ok i like the stomper look and so cal not as many puddles and stuff to splash sides. not sure how they will tuck up in wheel wells in serious flex situations ? hopefully the tires wont rip my fenders off if problem with serious flex will throw the 33's back on for hardcore wheelin just until the rough country is ready for us . thanks again for all the info on your experience with the rancho kit
Old 01-18-2006, 11:43 AM
Bruce Bruce is offline
Bruce is off the scale
OK>>>>>> so basically I have stock suspension adventure package with the 33' tires and stock wheels. I want 35's on my stock wheels. What 35' will fit the best. without rubbing.
and just for curiosity how big can i get the tire on stock wheels without rubbing
thanks guys
Bruce
2006 H3 Yellow
Adventure Package
Onstar
XM Radio
33\' Tires
Stainless Steel Brush Guard
Stainless Steel Side Tubs
LOVE IT.
!993 Corvette Red Pushing 400HP
Perfect Condition.
