04-10-2005, 05:10 PM
After Waxing my H2 this morning, I noticed a crack in the windshield. It started below the molding and continued upwards. Anyone else had this problem? Mo signs of impact
Black 04 H2
Black 04 H2
04-10-2005, 05:15 PM
I had to go get my glasses, No sign of impact on the molding>
Black 04 H2
04-10-2005, 05:31 PM
Is this the original windshield? I have found that the first one is weak for some odd reason. and with the windshield being so vertical it tends to catch everything. I think I'm going on # 6
04-10-2005, 05:42 PM
Start looking for someone that will get you glass cheap! I went through three on my 03 in less tahn a year, and am ready for my two month old 05.
04-10-2005, 05:56 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by xonxoff:
I had to go get my glasses, No sign of impact on the molding> </div></BLOCKQUOTE>When I had mine replaced it had no sign of impact either and the crack started below the molding. The only reason I know it was a rock was I DUCKED when the bastard came at me.  You know the other drivers were laughing when they saw some fool driving down the highway all-of-a-sudden BAIL under the dash. Makes me laugh at myself.
04-10-2005, 06:46 PM
This is my first one. I guess I should feel lucky. Does warranty cover these? I was wondering if there was a bad prep on the install.
Black 04 H2
04-11-2005, 12:08 AM
It's worth taking it to the dealer, and claiming it's a stress crack that began on the lower outer edge of the glass. If not, you insurance should cover the glass. I know mine is a $100 deductible, but I'm sure it varies per policy.
Good Luck!
Ric
P.S. If you don't plan on replacing it, have some one stop the run, by drilling and filling the crack. Until then, place a piece of clear vinyl repair tape on the ends of the cracks so they won't travel as fast!
www.meatspin.com
04-11-2005, 02:36 AM
There's a thread on this subject somewhere. One of my minion shall find it.
There are two stress points along the base of the windshield, if I remember correctly, and if you have a windshield replaced and those points aren't covered right the windshield is prone to crack.
04-11-2005, 03:00 AM
DRTY's right. There are two rubber pieces that go on the bottom of the windshield at the two points.
04-11-2005, 03:17 AM
wow, i just had a crack appear in my windshield within the last week. Similar situation, it started from the molding, but from the top in my case. I'm going to investigate it closely, but it really doesn't look like I took on some rock damage. If indeed it is a "stress fracture" then warranty coverage is definatley in the discussion. Xonxoff, if you get anywhere with your windshield problem, let me know.
-Jigga
Sig lines are overrated.
04-11-2005, 03:24 AM
Jigga, good luck. Mine started at the top under the molding also.
04-11-2005, 07:08 AM
We have seen some windshields come in with cracks starting below the lower moldings with no sign of impact. If so your dealership should warranty it. But beware, they will look it over good for the slightest sign of damage. If they find the slightest chip you can probably forget about it. Just be prepared to tell them that you've talked with other owners with similar problems and their dealerships warrantied it. That will put the pressure on them.
04-11-2005, 11:32 PM
Thanks for all the posts, I talked to the dealer this morning.....Well they need to see it. I am going to go there next week. I will keep you posted. I have called hummer, they said they were not aware of any issues with the windshields, Maybe we should all call them to let them know that they might have a problem
Thanks again
Black 04 H2
04-12-2005, 05:14 AM
Last summer, i was washing the rig. As soon as i rinsed water on the windshield, it cracked right in front of me. From the lower molding to the top within seconds  I thought for sure it was a defective windshield because i couldn't find any stone chip. So i brought it to the dealer trying to get it fix under warranty. And the GM rep just happens to be there that day. First he look and couldn't find any visible damage then he used a ball point pen and traced the chip at the very bottom of the windshield, right on top of the lower molding  Then told me sorry pal, can't cover it under warranty...
Also, beware dealer doesn't always use genuine GM parts. This dealer charged me $500+ (which i thought wasn't too bad at first for a genuine GM part and the fact it was the dealer so i expect to pay more) but when i pick up the H, the new windshield had a big old PPG logo right in the middle! Long story short, had them take it out and put a genuine GM windshield on it. Final bill was $900+
04-13-2005, 02:14 AM
There is a TSB on windshields that sounds like the exact scenario you all are describing. I'd take them to task if it were me. XONXOFF...your windshield crack is right where this TSB refers to. You need to refer to this when you go to the dealer.
Body - Windshield Replacement Precautions
Bulletin No.: 03-08-48-004
Date: August 01, 2003
INFORMATION
Subject:
Guidelines to Prevent Cracks in Replacement Windshields
Models:
2003 HUMMER H2
This bulletin is being issued to advise dealers regarding correct replacement of the windshield.
After removing the windshield, there will be two plastic blocks visible along the lower edge of the windshield opening, each located near the windshield wiper arm transmission spline. These blocks are assembly aids used only when installing the windshield at the plant. They must stay in place so as not to open a hole where they mount. However, upon installation of a replacement windshield, care must be taken to assure that the glass does not come in contact with the blocks.
After applying the urethane and positioning the windshield, leaving an air gap (3) of 1 mm (0.040 in) between the block (4) and the windshield (2), compress the urethane only as much as necessary. This will assure that the glass does not come into contact with the blocks. <span class="ev_code_RED">If contact is made with the block, body flexing may cause the replacement windshield to crack. Cracks along the bottom of the glass are an indication that the glass is contacting the blocks.</span>
Tape (1) the windshield in place. Do not remove the tape until the adhesive cures.
Important: When subletting a windshield replacement, provide a copy of this bulletin to the persons involved in the replacement.
Jonahs
04-13-2005, 02:26 AM
That's interesting to see Jonahs. When mine was replaced the installer was VERY cautious and called his Super several times during the install. He was concerned about those blocks. It also took him many times longer to get it right.
04-13-2005, 02:32 AM
That's interesting to see Jonahs. When mine was replaced the installer was VERY cautious and called his Super several times during the install. He was concerned about those blocks. It also took him many times longer to get it right. </div></BLOCKQUOTE>Yeah. Although this TSB refers to "replacing" the windshield who's to say it wasn't installed incorrectly at the factory. That's my best guess anyway.
Jonahs
04-25-2005, 08:48 PM
Well I took it to the dealer today and they are going to cover it under warranty. I was pleased about this. Mine was the first one they had seen do this.
I was ready with some facts. I did call hummer and tell them about this problem.
Black 04 H2
