Old 02-09-2006, 05:34 PM
This is a quiz. See if you can figure out the problem from the symptoms. I haven't even told CP about this so she can try also (We know that won't happen because she doesn't read this section, but....).
When first accelerating I get a shudder throughout the truck that lasts just a second. If I accelerate very slowly, nothing.
When slowing down I get a shudder as soon as I hit the brakes. However, if I stop extremely slowly, as in coasting, nothing.
Sometimes I get the shudder when turning on residential streets.
Please remember we're talking about BigNasty with big tires and a lift.
It took me two days to find the problem. Let's see if you can do better.
Old 02-09-2006, 05:35 PM
Forgot to say that I'll give you the answer tonight.
Old 02-09-2006, 07:13 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
I'm guessing your rear u-bolts are loose, and causing the rear end to shift(axle wrap) and bind on the rear drive shaft. Because you are not directing as much torque and h/p when you are taking off slowly, it doesn't shudder as much. But when you stomp on it, it places lots of strain and movement on your rear axle and places strain on the drive shaft. The shuddering while turning is due to the driveshaft letting up in the other direction, when the axel wrap occurs while slowing down.
Or maybe Pea-Pie is stuck in the grooves of your tire causing it to be unbalanced!
Ric-H0
www.meatspin.com
Old 02-09-2006, 07:30 PM
tomp's Avatar
tomp tomp is offline
Need more info. Too many variables. Tell us now!
Old 02-09-2006, 10:09 PM
Assuming we're not talking about lugs on a tire....
I'm going to say that you either have a ujoint problem or an incorrect pinion angle. Hitting the brakes will unload the rear end and hitting the gas will give a shudder if the pinion angle is off when you torque the rearend.
Nonetheless, I'm guessing something in the drivetrain. Ujoint, driveshaft, etc ,etc..
What's the answer?
Mark
Old 02-09-2006, 10:20 PM
My guess is somebody duct taped Pee-Pad to the rear drive line
Okay Ken, its tonight now....what's the answer? Enquiring minds want to know
Old 02-10-2006, 12:21 AM
something rolling around in the bed of the truck
tire rub
CV joint
lack of supercharger
blueberry pancakes for breakfast
Old 02-10-2006, 12:30 AM
Klaus's Avatar
Klaus Klaus is offline
</div></BLOCKQUOTE>
Old 02-10-2006, 01:27 AM
Fubar's Avatar
Fubar Fubar is offline
X2-LMAO
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Klaus:
</div></BLOCKQUOTE>
</div></BLOCKQUOTE>
Old 02-10-2006, 02:43 AM
Easy Ed Easy Ed is offline
CV style front driveshaft
Old 02-10-2006, 02:44 AM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
rear u-joint... my guess!
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 02-10-2006, 02:48 AM
H2Finally's Avatar
Loose wheel?
Can BLING Get You Home?
Old 02-10-2006, 04:20 AM
NO, NO, NO!!!! Damn you all. Let's get things working...
Here's the answer that took me two days to figure out... Without your help because you all suck!!!!!!
The rear tire carrier was not fully closed, thus the lock was not engaged. Hit the gas and the tire swings out and catches the safety cable. Slow down and the tire rack BANGS back into place. You all bring the suck!!!
Sheeze..... Good thing I know my sheat.
Old 02-10-2006, 04:21 AM
Notice CP didn't respond here.
Old 02-10-2006, 07:09 AM
HummBob's Avatar
HummBob HummBob is offline
OH
You see, this NEVER WOULD HAPPEN ON A BLACK H2, that's why I couldn't figure it out
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 02-10-2006, 09:34 AM
Sheeze..... Good thing I know my sheat. </div></BLOCKQUOTE>
AND IT TOOK YOU TWO DAYS TO FIGURE THAT OUT????
Mark
Old 02-10-2006, 11:04 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">It took me two days to find the problem. Let's see if you can do better. </div></BLOCKQUOTE>
Would have taken five minutes to figure that out while actually driving it around versus the misleading discription given <BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> Please remember we're talking about BigNasty with big tires and a lift. </div></BLOCKQUOTE>
I just wonder what the folks driving behind you thought while watching it happening, damn is that big tire going to come loose and hurt us.
Old 02-10-2006, 11:08 AM
shipbldr shipbldr is offline
shipbldr is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by OrangeCrush:
Mark </div></BLOCKQUOTE>
No... It took him 2 days to get a chance to drive the truck....
