Old 09-18-2005, 05:28 AM
ASJ ASJ is offline
ASJ is off the scale
Hi,
I'm a little concerned when my dealer checked up
the noise coming from the front of my H3.
In order to test out the noise, they would
press the gas pedal up to 3000 rpm while pressing on the brake pedal so the H3 won't
shoot forward. Is this bad for the engine/transmission?
ASJ ASJ is offline
Hi,
Old 09-18-2005, 08:23 AM
bparker's Avatar
bparker bparker is offline
LOL, not really. If you are stressing anything (notice I didnt say damage) it would be the breaks and torque converter.
People in hot rods do this all the time to flash the converter to get a better launch or doa burn out to heat the tires up.
http://www.tahoeforum.com
http://www.motoforum.com
Old 09-18-2005, 11:12 AM
ASJ ASJ is offline
How do I know if my brakes or torque converter is damaged?
Old 09-18-2005, 12:11 PM
VTSTOMPER is off the scale
They are not...that load it not something that will ruin anything.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-18-2005, 04:03 PM
ASJ ASJ is offline
at what RPM would you guess the brakes or torque converter would get damaged?
Old 09-18-2005, 05:56 PM
MyxH3 MyxH3 is offline
MyxH3 is off the scale
ROFLMAO
May the next exit offroad be anywhere you want it to be.
Old 09-18-2005, 06:37 PM
bparker's Avatar
ASJ, listen you woulld have to mash the brakes all the way down and then floor it and I mean FLOOR IT! and let the TQ from the motor over power the brakes and roll forward for like 30 mins straight to do any "damage" and then and only then you would most likely be looking at replacing break pads and rotors.
R E L A X
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ASJ:
at what RPM would you guess the brakes or torque converter would get damaged? </div></BLOCKQUOTE>
