Old 01-30-2004, 08:58 PM
I'm trying to find a way I can mount a 12" laptop for 2 reasons. First, I'd like to get a larger image of GPS from my Garmin. Second, long trips would be nice to play a DVD (not that I would watch while driving ) I've seen some really expensive ways to do this ($500) but that just seems silly to me. Anyone have a quick, easy, cheap install idea
Old 01-30-2004, 10:38 PM
Joe Joe is offline
Joe is off the scale
Funny but that would probably work.
Actually you might be able to craft some sort of boxed frame on top of the dog house that the lap top could sit in. Certainly would keep lateral moment safe, just need to worry about severe bounce depending on how deep the frame is. Just a thought.
I have the iQue from Garmin. Find that with voice commands I can keep having to look at it down. On the trail, again mainly for reference at times.
I think I have seen someone selling a metal mount that attaches to the windshield pillar as well. This might be the $500 solution your talking about though. Not sure on cost.
Oops found it... http://www.bluehummer.com/radiotray.html actually for radios but perhaps they could fabricate one for a laptop. $140
2001 H1 Opentop
Former 03 H2 Adventure Series
Homepage:
http://www.hummerh1.net
2001 H1 Opentop
2003 H2
Homepage:
Old 01-31-2004, 01:31 AM
Joe,
Thanks, I checked the mount and it looks like it will block my view through the passenger window. I was trying to keep that from happening, good idea though!
Alec, Yeah, I use velcro for everything too. I just figured there would be something more permanent but maybe not. My concern again is that with the laptop open it will block too much of my view. I guess I just need to give it a try.
Old 01-31-2004, 06:41 PM
JSA_3 JSA_3 is offline
JSA_3 is off the scale
Jason, I've been trying to come up with a way to do this too.
I've been toying w/the idea of more temporary solution. A "bean bag" type of cushion that would be heavy enough to stay put in stops/starts and turns, that could be positioned whereever you wanted on the doghouse. You could stick the laptop to it with velcro.
Just thinking
John
'02 HMCO
\'02 HMCO
Old 01-31-2004, 07:39 PM
John,
That's what I do with my GPS, which works just fine. I'll give something a try and post a pic.
Old 02-02-2004, 01:55 AM
BAMFH2 BAMFH2 is offline
BAMFH2 is off the scale
Hey Buckeye,
Drop me your address and I'll send you a couple of catalogs that I have. There are quite a few laptop mounts out there - usually for police vehicles etc.
The base mount screws right into your center console and then the staff is made from flex tubing. The laptop acutally slides into a metal frame. I recently mounted this unit into a real estate's client car - worked out very good and is extremely solid. I really liked the flex tubing so you could adjust the tilt and placement at will.
Prices run from 300-600 bucks.
Blake
Help Computers
www.helpcomputers.net
Member of the Denver Chapter of the S&B since 2003
Help Computers
Old 02-02-2004, 02:36 AM
Thanks Blake, check your PM.
Jason
Old 02-02-2004, 04:06 AM
Hey Buckeye,
Here is one online source that also has a pretty good selection:
http://www.jottodesk.com/dept.asp?id=1
Help Computers
Help Computers
Old 04-14-2004, 04:36 PM
ckhagman ckhagman is offline
ckhagman is off the scale
http://www.autocareequipment.com/images/CompMount1.JPG
http://www.autocareequipment.com/images/CompMount2.JPG
This is what I did. I used a mount from Havis Shields. www.havis.com
I have actually upgraded it recently and have not took a new picture. I actually bolted a piece of 1/2" stock square tubing to the mount and extended it to above the drivers side ashtrap and bolted it to that.
The mount does not swivel anymore but my passengers do look at the computer.
http://www.penta-nut.com
The Most Sirius Off-Road Vehicle
Old 04-14-2004, 04:42 PM
They have some pictures of a Hummer install in their photo gallery section.
Old 08-04-2004, 12:02 AM
It\'s a Dry Heat's Avatar
This is what I did. Eye glasses with a built-in monitor. http://www.4hiddenspycameras.com/eyeglmo.html I'm trying to help! I bet you didn't think of it.
Old 10-08-2004, 09:46 AM
hountzl hountzl is offline
hountzl is off the scale
I mounted my Sony VAIO TR3A on the dash with one of those sticky pads - Fit perfect - Best Buys has them - they are great for any thing sunglasses cellphone etc.
Old 11-02-2005, 09:39 PM
David J David J is offline
David J is off the scale
I was on Ebay the other day looking for this exact idea. They have a number of different types of mounts that appear to made from plumbers pipe and various other things. I think my search was for "laptop mounts". That place is a great source for DYI'rs.
Old 11-07-2005, 04:21 AM
HUMMERDOGG HUMMERDOGG is offline
HUMMERDOGG is an unknown quantity at this point
http://www.ergotron.com/3_products/f...ms/default.asp
Expensive but talk about all the adjustment capabilities you could ever want. You'd have to fab a laptop base mount but you could incorporate that with the RubberDuck Laptop Mount...
http://www.rubberduck4x4.com/laptopmount.htm
-HUMMERDOGG
