Old 01-16-2006, 11:19 AM
working Hummer's Avatar
Here's a question, I went out to a mud hill, (pretty steep) about 30 feet long from bottom to top, I put it in 4 high and gunned it, about half way up the Hummer really started to bog down, I expected a rooster tail of mud to be shooting out the rear, I eventually crawed to the top which no other 4 wheeler could but I expected more power, of all the button options would of there been a better one to go up a mud hill? (4 low, lock the rear end?) like I said it really bogged down.
Old 01-16-2006, 11:38 AM
Ernie Italy is off the scale
Tires ?????
Old 01-16-2006, 11:42 AM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
did you have it in 1st gear?
Old 01-16-2006, 02:32 PM
You probably broke a tie rod. Sometimes that slows you down a bit.
Old 01-16-2006, 02:37 PM
Put it in 4Hi Locked and hit the TC2 button.
Old 01-16-2006, 03:08 PM
Put it in 4Hi Locked and hit the TC2 button. </div></BLOCKQUOTE>
And go slow...but not too much...
Tires ????? Super Swamper!!!!
Old 01-16-2006, 03:52 PM
Elcova Newbie = 35x12.50x17 BFG AT
Old 01-16-2006, 04:46 PM
I already had it in 4 high and just gunned it, have stock bfg's on it. the question I have is does the tranny system on the Hummer keep the wheels from spinning somehow, so it would seem to bog down since I was in mud?
Old 01-16-2006, 04:48 PM
Oh I forgot to say I had it in 4Hi locked
Old 01-16-2006, 06:26 PM
shipbldr shipbldr is offline
shipbldr is off the scale
Before you went up the hill was the alignment checked?
Smart assed comments aside... Towards the top of the hill it shouldn't be crawling. I have no trouble spinning wheels the whole way up to the top....
Something doesn't sound right if it was barely crawling along.
Old 01-16-2006, 06:30 PM
ShaggyX ShaggyX is offline
Doesn't "Steep Hill" generally mean that 4-Lo is ideal? Extra power to haul that heavy ass truck up a hill?
Old 01-16-2006, 06:34 PM
4 low is probably the ideal yes... but even in first I'd be surprised if the truck was struggling at a crawl.
I guess we're just going to have to do some field testing.
Paragon anyone?
Old 01-16-2006, 06:54 PM
BlueTJCO's Avatar
BlueTJCO BlueTJCO is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ShaggyZr2:
Doesn't "Steep Hill" generally mean that 4-Lo is ideal? Extra power to haul that heavy ass truck up a hill? </div></BLOCKQUOTE>
X2
"moonie"
Old 01-16-2006, 10:43 PM
Traction control.
Mark
Old 01-17-2006, 10:23 PM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
If you did not have the TC2 button on then the traction control (as OrangeCrush stated) would have taken over and applied brake pressure to the spinning tire(s) thus it would seem to 'crawl'.
Next time use either 4H lock, or 4L lock and select TC2 button..
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 01-18-2006, 12:11 AM
Dewi2005's Avatar
Thanks for this Info Phil... I was unaware that the brake activated slightly would deactivate the TC... EXCELLENT info, Thanks!
Old 01-18-2006, 12:43 AM
Alan06SUT's Avatar
The traction control will barely let the tires spin. TC 2 will let them spin more. The locker will help you crawl up the hill with even less effort (the button with the X between the wheels).
