Old 10-07-2003, 09:03 PM
TonkaH2 TonkaH2 is offline
TonkaH2 is off the scale
It just started about 500 miles ago, but it's really annoying. No cracks visible. Anyone else experience this?
-Jack
Yellow H2 adv. Warn winch
Can't go traveling yet
www.sunspotnatural.com
yellow H2 adv.
-Jack
yellow H2 adv.
Old 10-07-2003, 09:09 PM
Patriot Patriot is offline
Patriot is off the scale
Tonka,
I just passed 5000 miles and have picked up something similar. It may be the antennae's or...the covers for the running lights up top are a bit loose. I checked the screws and they are tight but the light covers are a bit loose. Almost like the screw holes are not deep enough. Check it out and see if your are the same. The base is tight and water proof but the light covers seems to be a bit loose.
Old 10-07-2003, 09:10 PM
crash crash is offline
crash is off the scale
How many miles on the rig?
certified H2 tech.
certified H2 tech. troll
ZeroTolerance ZeroTolerance is offline
ZeroTolerance is off the scale
I know someone that had this same issue a while back, all you need to do it take it in and have the seal around the front windshield inspected, I think that they will find that it is not sealed properly and they can fix it... Should be easy....
Old 10-07-2003, 09:15 PM
Tonka,
Have you or did you have your windsheild replace before?
Sometimes they will use the wrong RTV to seal the winshield and it will get brittle. Thus the crackling sound during body flex.
Happened to my Jeep a few years back.
Or it could be your dash?
He ain't heavy.....
He's ma HUMMER baby!
03 NUDE Pewter Lux H2
03 Dressed Range Rover
"Give a guy a Civic, he thinks he has a Ferrari.
So is true with yours...Give it up! It`s not a Hummer."
Old 10-07-2003, 09:59 PM
Paul L Paul L is offline
Paul L is off the scale
I stated in a past post that the wind noise coming from the right side of the glass was moving across the glass to the left side. NOW the crackling from around the windhsheild above 50 MPH has started.
Oh I don't want to go back to the dealer. This meen I have to clean the h2 (just got back from the woods................ it is covered from head to toe w/mud)
http://www.carpentryasanart.com
Old 10-07-2003, 10:29 PM
Circuitguy
My H2, Denali and GMC truck all make the same cracking sound. The dealer said that it’s the pillar molding vibrating against the window and remounted it. The noise stopped for a month or so then it came back. I think the windshield is mounted too close to the metal frame around it. There should be a bead of sealer/glue between the windshield and the trucks metal frame. I think it’s very thin and under high wind pressure against the windshield its causing the cracking sound as it is hitting the metal. As we know H2's are known for cracked front windshields when you drop the hood too hard. I may be right or wrong but I hope this helps a bit. BIG-C
White 03-H2-LUX
</a>
Old 10-07-2003, 11:20 PM
27K on 'er, pretty rough use, but never replaced the shield. I'll be careful lowering the hood...
-Jack
yellow H2 adv.
Old 10-07-2003, 11:59 PM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
I got a pit in my windsheild with 20 miles . I was alittle hurt... but things are all better.
Old 10-08-2003, 02:44 AM
MAC MAC is offline
MAC is off the scale
18,000 miles, 1 year +, no strange noise from the windshield, no strange noise from anywhere in or on my Hummer, ever.
It is not easy NOT to drop the hood, and if you drop it too gently, it will not engage, must double check to make sure your hood is engaged. I am much more careful now since I read about the potential problem here. But before that, I dropped the hood many times with full weight and free fall, plus a little extra push, the windshield has been fine.
Old 10-08-2003, 03:28 AM
hognose hognose is offline
hognose is off the scale
~25k on mine and the noise is driving me nuts! Anyone who doesn't ride in it all the time just thinks it's normal "wind noise". I have not pinned down the exact location yet but it sounds like a wind causing some form of vibration. I am hearing it from the top left and top right area of the winshield and suspect the running lights in the respective positions on top of the cab?
Chris
Old 10-08-2003, 01:32 PM
RonB RonB is offline
RonB is off the scale
I think the flapping noise is caused by the rubber weather stipping above the windshield. When I first started hearing it I was freaked -- I thought pieces would come flying off. I've had it in to the dealer a few times to address the issue, but it hasn't really got that much better. I guess that's what we get for driving a square truck 75 mph.
At least it doesn't make the noise doing what it does best.
btw - just turned 10,000 miles last night and the minor flapping noise is the only uninvited noise I've heard in the truck. Friends that go off-roading with me always comment how comfy and quiet/rattle-free the truck is while bouncing around.
Ron B
Old 10-08-2003, 03:03 PM
ANGELO D. ANGELO D. is offline
ANGELO D. is off the scale
I have 24,000 miles and I have the same noise coming mostly from the passenger side right hand corner above windshields. I have to go about70MPH, for the noise to start. Now I have noticed the noise started on driver side to. The noise sounds like something under the headliner flopping around. also sounds like something on the roof flopping. The sound is quite annoying.
Old 10-08-2003, 03:07 PM
Detonate Detonate is offline
Detonate is off the scale
Wow. This is weird. We heard the same thing on my truck this weekend driving down to Mason.
Of course mine doesn't happen till around 90 MPH. :/
I didn't notice the noise on the way home.
-Jim March
Arlington TX
2003 Red H2
Beauty is in the eye of the Beer Holder
</center><hr>
Old 10-08-2003, 08:12 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Detonate:
-Jim March
Arlington TX
2003 Red H2
_Beauty is in the eye of the Beer Holder_<HR></BLOCKQUOTE>
90, wowzers..
Thats alot of force against that windshield...
certified H2 tech.
Old 10-09-2003, 02:10 AM
H2Girl H2Girl is offline
H2Girl is off the scale
I've had 2 similar noises by the top of the windshield fixed by my dealer. The first time it was a loose moonroof drain bouncing around at speeds above 40. Second time they tightened the plastic wind deflector for the moonroof. 40K miles later..no more noises.
Old 10-10-2003, 08:09 PM
ratesguy ratesguy is offline
ratesguy is off the scale
I just started to get the same noise, only above 70 mph. Will have the dealer check
Old 10-14-2003, 12:19 AM
TBarrow TBarrow is offline
TBarrow is off the scale
I had a leak from the center marker lights. I had the same noise that was corrected today. The center marker lights have a sponge type seal and move rather easily. The dealer secured them with a bead of urethane. Try runniing electrical tape over the top to secure the lights and drive to see if this fixes it. I have the Gobi Rack and had thought it was the lights, wires, shield etc. but sealing the center lights fiked it.. Good Luck, I know how much squeaks and rattles bug me.
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Xenarc HID, Alcoa Wheels, Goodyear 37x12.50x17 MT/R, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, 2-7" screens in headrests with DVD player and TV Tuner.
