Old 09-02-2004, 04:33 PM
So, when you go off- road, what does everyone do with their gear? I take the dogs with me almost every time, so I was worried about the gear sliding around and into them. And if for some reason I was to top over, than all of that gear is loose also.
So my questions is, what does everyone elso do with their gear? I made a boz and carpeted in and through some basic hand tools and receovery gear and first aide gear.
Old 09-02-2004, 04:34 PM
One more... and the box is secured to the floor too.
Old 09-02-2004, 04:39 PM
Hey, that looks nice Tim. Good job. Probably better then most you could buy.
Old 09-02-2004, 04:49 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I was also looking for more storage so I cut the bottom off a Poland Spring Water bottle and stuck it on the bottom of the ash tray. Then I put it in the rear drink holder
I gained few square inches of space!
Old 09-02-2004, 05:13 PM
Dan Dan is offline
Nice! What did you use to cut out the foam shapes for the tools? Looks like nice cuts.
Old 09-02-2004, 05:16 PM
Seth, it is anchored to the floor. If you look at the foam, their is a white small first aide kit. to the top left corner their is a pillar in the middle. On the floor is where the third seat used to clip into the foor. I placed to hooks ans crewed them into the pillar, the pillar is screwed to the box. it doesn't move at all. as far as tie downs on top, I have four pull rings I have not put in yet. i want to have them flush mount with the carpet. than I can mount my H2O tank and tool box in there too.
BTW, anyone have instructions on how to change out the tie rod. I would like to print that out and laminate it and throw it in the box too.
With carpet and materials it was about a thousand dollars cheaper than the truck vault.
Old 09-02-2004, 06:59 PM
GulfWarToy GulfWarToy is offline
GulfWarToy is off the scale
If it's to protect your dogs, you might want some sort of latch to make sure the hatch stays shut if you have the misfortune of rolling over.
