Old 12-19-2005, 10:54 PM
Thanks PhilD for the removeable steps. These are a royal PITA to install. I'm not kidding.
Start by removing the factory running boards because they're going to get bent up and rust anyway. There's 8 nuts and bolts. Start on the outside and work to the center. Piece of cake.
Now for the difficult part, installing the removeable steps. Sit on the ground. Hold step and line up alignment bungs to holes under rock rail and slide on. I said, "align the bungs... ALIGN THE BUNGS!"
Ok, so that's the real problem, aligning those damn things did take a few minutes.
Run the bolt through after aligning the bungs and holes, screw bolt in and insert cotter pin.
I only installed two because I got tired of f**king with it and it was cold.
P.S. I just wanted to say "bung" and "hole" in the same sentence.
Thanks again, Phil.
Thanks again, Phil.
Old 12-19-2005, 11:00 PM
4churchill is off the scale
gonna look good ken
Im definately going to get a set for my rig....let me know if anyone has a set they want to part
www.HUMMERNut.net
Old 12-19-2005, 11:04 PM
I'll talk to the woman. If she doesn't care about the rear two, I'll send you the front one's if you want them.
What is up with the bung holes not easily lining up. And which way do you install the bungs to the holes F to R or R to F
Old 12-19-2005, 11:06 PM
GLBLWARMR's Avatar
That is definetly a better look than the stock running boards.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 12-19-2005, 11:19 PM
What is up with the bung holes not easily lining up. And which way do you install the bungs to the holes F to R or R to F </div></BLOCKQUOTE>I did R to F. Oh, they lined up fine, I just had to get them in the holes and one wouldn't be right, then the other....
And here's the BIG thing. They came off PhilD's truck. Ok? There's no telling what these things have been through.
Seriously, I was joking about lining them up... some.
Thanks again Phil. CP REALLY appreciates them.
Old 12-19-2005, 11:26 PM
These are a royal PITA to install. I'm not kidding. </div></BLOCKQUOTE>It gets easier. The first few times I put them on I cursed a bit, but after a while it becomes real easy. You'll enjoy taking them off, as that is real easy. </div></BLOCKQUOTE>Thanks for the support on this major, giant, life and death issue, Phil.
See, I told you guys it was a PITA.
Thanks again Phil.
Old 12-19-2005, 11:27 PM
These are a royal PITA to install. I'm not kidding. </div></BLOCKQUOTE>It gets easier. The first few times I put them on I cursed a bit, but after a while it becomes real easy. You'll enjoy taking them off, as that is real easy. </div></BLOCKQUOTE>Not only is it easy, it usually means you're headed for a trail somewhere.
Old 12-19-2005, 11:29 PM
These are a royal PITA to install. I'm not kidding. </div></BLOCKQUOTE>It gets easier. The first few times I put them on I cursed a bit, but after a while it becomes real easy. You'll enjoy taking them off, as that is real easy. </div></BLOCKQUOTE>Not only is it easy, it usually means you're headed for a trail somewhere. </div></BLOCKQUOTE>Or trying to keep the wife out.
Old 12-19-2005, 11:30 PM
These are a royal PITA to install. I'm not kidding. </div></BLOCKQUOTE>It gets easier. The first few times I put them on I cursed a bit, but after a while it becomes real easy. You'll enjoy taking them off, as that is real easy. </div></BLOCKQUOTE>Not only is it easy, it usually means you're headed for a trail somewhere. </div></BLOCKQUOTE>Or trying to keep the wife out. </div></BLOCKQUOTE>
Old 12-19-2005, 11:31 PM
Paragon:
Nice location.
A complete lack of respect for the law.
Old 12-19-2005, 11:37 PM
Paragon:
Nice location.
A complete lack of respect for the law. </div></BLOCKQUOTE>Mine follows Klaus'
Old 12-20-2005, 12:04 AM
Paragon:
Nice location.
A complete lack of respect for the law. </div></BLOCKQUOTE>Mine follows Klaus' </div></BLOCKQUOTE>Not Smokey and the Bandit?
Old 12-20-2005, 12:17 AM
I'll talk to the woman. If she doesn't care about the rear two, I'll send you the front one's if you want them. </div></BLOCKQUOTE>
What about the MIL, don't you need them for her? </div></BLOCKQUOTE>NO.
Old 12-20-2005, 12:22 AM
Paragon:
Nice location.
A complete lack of respect for the law. </div></BLOCKQUOTE>Mine follows Klaus' </div></BLOCKQUOTE>Not Smokey and the Bandit? </div></BLOCKQUOTE>It can't be both?
Old 12-20-2005, 12:29 AM
My MIL emailed me pictures of this furniture, remember?
