  #41
Old 01-03-2006, 12:11 AM
Fubar's Avatar
Fubar Fubar is offline
don't know.
I would suspect the answer would be yes.
The brush guard doesn't attach anywhere near the cut outs for the lamps and the vallance is a direct replacement for the stock one so why wouldn't it.
Contact Jason and ask.
Old 01-03-2006, 01:24 AM
Bondage Bondage is offline
Bondage is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Fubar:
don't know.
Contact Jason and ask. </div></BLOCKQUOTE>
Good point - I'll do that. It just states in the blurb, "SMA has designed a replacement valance for use with the Heavy Duty Brushguard." I would not be using the SMA Heavy Duty Brushguard, so it made me wonder if it would work.
Sean
Old 01-03-2006, 02:33 AM
H2Finally's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
You beg and grovel.
There will be an ad here sometime in the (relatively) near future. </div></BLOCKQUOTE>
DRTY,
Other than the fact that your winch bumper looks cooler, and it DOES what are the differences between yours and the one from Warn?
Sean </div></BLOCKQUOTE>* NO DRILLING * 12,000lb winch vs Warn's 9000lb * NO DRILLING * oem look * NO DRILLING * heavier gauge steel * NO DRILLING * oh yeah, did I mention, NO DRILLING install?
Caveat: I don't own one -- no chrome model available (YET!)
Can BLING Get You Home?
Old 01-03-2006, 03:03 AM
You beg and grovel.
DRTY,
Caveat: I don't own one -- no chrome model available (YET!) </div></BLOCKQUOTE>
Okay, okay, so it looks more OEM, has a heavier duty winch, uses better steel, etc. But how much drilling is required to install one?
Sean
Old 01-03-2006, 07:50 PM
Field Rat's Avatar
Field Rat Field Rat is offline
Field Rat is off the scale
It looks to me that the main difference between the DRTYFN setup and the WARN setup is -- You can get the WARN system.
\'97 H1 Green Soft Top SOLD
\'03 H2 Pewter SUV= SOLD
\'05 H2 Desert Sand SUV
\'05 H2 Stealth Gray SUV
Old 01-03-2006, 08:46 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Field Rat:
It looks to me that the main difference between the DRTYFN setup and the WARN setup is -- You can get the WARN system. </div></BLOCKQUOTE>
Sort of like everybody can get the drunk party girl.
Old 01-03-2006, 09:35 PM
Kevin B Kevin B is offline
Kevin B is off the scale
Field Rat, I went with the Warn setup and I love it. As for having to drill 4 holes (if I remember correctly) I had no issues with that. As a matter of fact, it makes me feel a little better when using a snatch block knowing there are 12 fastening points as opposed to 8.
It's kind of hard to see how you get to the line in/line out lever with the drty setup. The lever on the 9.5k winch is mounted on the other side (driver side) and very accessible in the Warn setup. It would also be interesting to see how the remote plugs in on drtys setup as that is an "ease of operation" thing. As I recall he was going to use a Mile Marker Winch as well so that might be a personal preference thing, a difference none the less.
As for looks I would say drtys has Warn beat. It looks like his is actually made using the stock piece and modifying it.
Having said that, you seem to have a good point with regards to availability. When I was in the market for a winch bumper (a year or so ago it seems) the only one ready for market was the one Warn offered. Either way you go I doubt you can go wrong.
