Old 01-24-2006, 10:30 PM
HummerB HummerB is offline
HummerB is off the scale
again............what is the difference between the two transfer cases.......i guess what i am asking is what do the numbers 2:56 and 4:1 mean??
Birch wht (black accents/anti-bling), auto lux, oem flat side steps, oem brush guard, silver crossbars, SMA exhaust, PIAA 520 offroad lights, Valentine One.
Old 01-24-2006, 10:39 PM
H3HUMVEE's Avatar
H3HUMVEE H3HUMVEE is offline
H3HUMVEE is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummerB:
again............what is the difference between the two transfer cases.......i guess what i am asking is what do the numbers 2:56 and 4:1 mean?? </div></BLOCKQUOTE>
Well, in simple terms with the 4:1 for every four revolutions of the input shaft of your transfer case you get one rotation of the output shaft ..So you can reduce your output ratio from your transmission by four to one...
_. __________
H /__________\
3[O][][][][][][O]
Old 01-25-2006, 01:40 AM
SledgeHummer SledgeHummer is offline
SledgeHummer is off the scale
hehehe H3HUMVEE you bad bad boy, that's the answer he's looking for
What HUMVEE is trying to tell you, the higher the T-case ratio is the stronger the case is. i.e. in rockcrawling condition or extreme offroading conditions the 4:1 case gives a lot more power than the 2.64:1
Old 01-25-2006, 05:25 AM
Huck BB62's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Steve-SanJose-H3:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by UNOMYFLO:
The adventure package comes as follows:
1) 33" tires
2) 4.56 gear ratio (probbaly due to the larger tire killing the stock gear setup) Plus more offroad ability gearing wise.
3) stiffer suspension and shocks.
4) different (lower) gearing in the transfer case.
UNO </div></BLOCKQUOTE>
I think all H3's have the 4.56 rear end ratio, only the granny gear ratio is different between base and adventure setups.
S. </div></BLOCKQUOTE>
Better check your build sheet. From what I saw at the dealer, 4.56 gears are found on the Adventure package.
Overview
Model:
HUMMER H3
Body style / driveline:
4-door, 5-passenger hard-top 4-wheel-drive
EPA vehicle class:
Midsize sport utility
Construction:
Welded steel frame, electro galvanized steel
Manufacturing location:
Shreveport, Louisiana
Key competitors:
Toyota 4Runner; Jeep Grand Cherokee, Nissan Xterra, BMW X3
Engine
Vortec 3500
Type:
3.5L inline 5-cylinder
Displacement (cu in / cc):
211 / 3460
Bore & stroke (in / mm):
3.66 x 4 / 93 x 102
Block material:
A356-T6 lost foam cast aluminum
Cylinder head material:
Valvetrain:
dual overhead camshafts, continuously variable exhaust valve timing, 4 valves-per-cylinder, with dual balance shafts
Ignition system:
distributorless electronic spark, coil-on-plug, platinum-tipped spark plugs
Fuel delivery:
multipoint sequential fuel injection
Compression ratio:
10.0:1
Horsepower (hp / kw @ rpm):
220 / 164 @ 5600 (estimated.)
Torque (lb-ft / Nm @ rpm):
225 / 305 @ 2800 (estimated.)
Recommended fuel:
87 octane
Maximum engine speed (rpm):
6300
Emissions controls:
dual "split converter" design; LEV II
Est. fuel economy (auto city):
16 mpg*
(auto hwy):
20 mpg*
*based on preliminary GM tests
Transmissions
MA5
Hydra-Matic 4L60-E
Type:
5-speed manual
4-speed automatic
Gear ratios (:1):
First:
3.75
3.06
Second:
2.20
1.63
Third:
1.37
1.00
Fourth:
1.00
0.70
Fifth:
0.73
Reverse:
3.67
2.29
Stall ratio:
N/A
1.90
Final drive axle ratio:
4.10
4.56
Low range lock gear reduction:
2.64
4.03
Crawl ratio (range):
33 to 69
33 to 69
Chassis/Suspension
Front:
independent SLA torsion bar, 46-mm mono-tube gas-charged shocks, 36-mm tubular stabilizer bar
Rear:
"Hotchkiss" design multileaf, semi-elliptical single-stage leaf spring, 46-mm mono-tube gas-charged shocks, 25-mm rear solid diameter stabilizer bar
Steering type:
power-assisted rack-and-pinion, with tri-bushing mount design
Steering ratio:
17:1
Steering wheel turns, lock-to-lock:
3.25
Turning circle, curb-to-curb (ft / m):
37 / 11.3
Brakes
Type:
electro-hydraulic power 4-wheel disc, 4-wheel anti-lock, four-piston opposed (fixed) front caliper/ single piston sliding rear caliper with Dynamic Rear Proportioning
Rotor diameter x thickness (in / mm):
Front:
12.4 x 1.1 / 315 x 28
Rear:
12.28 x 0.47 / 312 x 12
Total swept area (sq in / sq cm):
Front:
69.4 / 448
Rear:
51 / 328
Wheels/Tires
Wheel size & type:
16-inch x 7.5-inch aluminum
Tires:
std: P265/75R16 all terrain steel-belted Goodyear radials
opt: LT285/75R16C on-/off-road Bridgestone radials (with ZM6 Off-Road Adventure package)
Same full-size spare as the tires on the vehicle
Dimensions
Exterior:
Wheelbase (in / mm):
111.9 / 2842
Overall length w/ spare and 33-inch tires (in / mm):
186.7 / 4742
Overall width (in / mm):
85.5 / 2170.5
Overall height (in / mm):
74.5 / 1893
Track (in / mm):
Front:
65 / 1651
Rear:
65.5 / 1664
Minimum ground clearance front (in / mm):
9.1 / 231
Step-in height (in / mm):
Front:
w/ 32-inch tires: 24 / 609.2
w/ 33-inch tires: 24.7 / 609.2
Rear:
w/ 32-inch tires: 24.5 / 623.5
w/ 33-inch tires: 25.3 / 643.5
RTI
21.7
Approach angle (degrees):
w/ 32-inch tires: 38
w/ 33-inch tires: 40
Departure angle (degrees):
w/ 32-inch tires : 36
w/ 33-inch tires: 37
Breakover angle (degrees):
Grade capability (percent):
60
Side slope capability (degree):
40
Water fording capability (in/ mm):
(at 20 mph / 32 km/h):
16 / 407
(at 5 mph / 8 km/h):
24 / 610
Curb weight (auto trans) (lb/ kg):
4700 / 2132
Interior
Seating capacity:
5
Head room (in / mm):
Front:
w/ sunroof: 39.9 / 1013
w/o sunroof: 40.6 / 1032
Rear:
w/ sunroof: 37.9 / 963.5
w/o sunroof: 39.9 / 1013
Leg room (in / mm):
Front:
41.9 / 1063
Rear:
35 / 890
Shoulder room (in / mm):
Front:
54.4 / 1381.3
Rear:
53.5 / 1358
Hip room (in / mm):
Front:
53.9 / 1370
Rear:
53.5 / 1358
Capacities
Cargo capacity (rear seat up) (cu ft / L):
Rear seat up:
29.5 / 835.3
Rear seat down:
55.7 / 1577
Cargo area length (at floor) (in / mm):
Rear seat up:
32 / 810.5
Rear seat down:
63.5 / 1614
Cargo area height (rear floor to headliner) (in/mm):
37 / 939
Cargo area width between wheelhouses (in / mm):
42.1 / 1070
GVWR, standard (lb / kg):
5850 / 2654
Payload, base (lb / kg):
1150 / 521.6 (estimated)
Fuel tank (gal /L):
23 / 87
Engine oil (qt / L):
5-speed manual:
6 / 5.7
4-speed automatic:
6 / 5.7
Maximum trailer weight (lb / kg):
4500 / 2041 (estimated)
Maximum tongue weight (lb / kg):
Up to 400 / 182 (estimated)
Old 01-25-2006, 08:45 AM
last night was a bad night
Old 01-25-2006, 12:28 PM
HummerJim's Avatar
I agree with the previous posts and wish I would have gotten the Adventure package in June! It's a bargain for all they give you. I also believe the salesman told me the Adventure has one more leaf or thicker leafs?? They only had one at the dealer and I thought it rode a little stiffer, but have ridden in an Adventure H3 since, at the Ozark Offroad Bash I can now barely tell the difference in the ride with it and mine. I have added slightly larger offroad tires and with the stock gearing the acceleration has suffered a little, but perhaps the highway mpgs have improved, because I get consistent 17s on the highway. Go with the Adventure Package!
Old 01-25-2006, 04:51 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Huck BB62:
1) 33" tires
Overview
Model:
HUMMER H3
EPA vehicle class:
Construction:
Key competitors:
Engine
Vortec 3500
Type:
211 / 3460
3.66 x 4 / 93 x 102
Block material:
Valvetrain:
Ignition system:
Fuel delivery:
Compression ratio:
10.0:1
Recommended fuel:
87 octane
6300
Emissions controls:
16 mpg*
(auto hwy):
20 mpg*
Transmissions
MA5
Hydra-Matic 4L60-E
Type:
5-speed manual
4-speed automatic
Gear ratios (:1):
First:
3.75
3.06
Second:
2.20
1.63
Third:
1.37
1.00
Fourth:
1.00
0.70
Fifth:
0.73
Reverse:
3.67
2.29
Stall ratio:
N/A
1.90
4.10
4.56
2.64
4.03
33 to 69
33 to 69
Chassis/Suspension
Front:
Rear:
Steering type:
Steering ratio:
17:1
3.25
37 / 11.3
Brakes
Type:
Front:
Rear:
Front:
69.4 / 448
Rear:
51 / 328
Wheels/Tires
Wheel size & type:
Tires:
Dimensions
Exterior:
111.9 / 2842
186.7 / 4742
85.5 / 2170.5
74.5 / 1893
Track (in / mm):
Front:
65 / 1651
Rear:
65.5 / 1664
9.1 / 231
Front:
Rear:
RTI
21.7
60
40
16 / 407
24 / 610
4700 / 2132
Interior
Seating capacity:
5
Front:
Rear:
Leg room (in / mm):
Front:
41.9 / 1063
Rear:
35 / 890
Front:
54.4 / 1381.3
Rear:
53.5 / 1358
Hip room (in / mm):
Front:
53.9 / 1370
Rear:
53.5 / 1358
Capacities
Rear seat up:
29.5 / 835.3
Rear seat down:
55.7 / 1577
Rear seat up:
32 / 810.5
Rear seat down:
63.5 / 1614
37 / 939
42.1 / 1070
5850 / 2654
Fuel tank (gal /L):
23 / 87
5-speed manual:
6 / 5.7
4-speed automatic:
6 / 5.7
Up to 400 / 182 (estimated) </div></BLOCKQUOTE>
Wrong, read the sheet.
All automatics have 4:56 rear ends (both base and adventure). This chart is showing different gearing of AUTO vs. MANUAL tranny.
S.
Old 01-25-2006, 07:28 PM
Hate to tell all, but a few weeks ago this popped up in the tech section, and I confirmed with the engineer in charge of axles, and there is only ONE axle ratio offered on the 2006 H3 Hummer; and that is 4.56:1.
This is irregardless of what a marketing sheet has on it. Prior to calling, I had pulled vehicle information build sheets for autos, manuals with and without the off-road package, and found only 4.56 gear listed.
Old 01-25-2006, 07:41 PM
? so the only diff is the 33 in. tires, stiffer shocks, and 4:1 Tcase?
Then 33in. tire upgrade would not impact a lux package at all? The lux set up with 31 in tires should be getting better accl. than one with the adventure package?
Old 01-25-2006, 07:50 PM
fourfourto's Avatar
Front:
Rear:
There are no 31 inch tires You get the rear locker also.
Old 01-25-2006, 07:52 PM
Then 33in. tire upgrade would not impact a lux package at all? The lux set up with 31 in tires should be getting better accl. than one with the adventure package? </div></BLOCKQUOTE>
No, another difference is the Eaton Electronic Rear Locker in the axle differential.
Correct, upgrading to 33 in tirs is no problem. As for acceleration, not sure you would be able to tell the difference. Besides the standard tires are 32", off-road are 33." Biggest difference between the tires is the 33s are Bridgstone and are better for off-road than the Goodyear Wrattlers on the standard package.
Old 01-25-2006, 07:56 PM
This is irregardless of what a marketing sheet has on it. Prior to calling, I had pulled vehicle information build sheets for autos, manuals with and without the off-road package, and found only 4.56 gear listed. </div></BLOCKQUOTE>
Interesting on the auto vs. manual rear end ratio.
1. A little suspect though, since we are hearing that gearing in 5th gear on the manual tranny is considerably taller than 4th on the auto tranny. Based on the chart above 5th gear should be slightly lower given that rear end ratios are the same.
2. It's very normal for auto and manual setups to have different final drive ratios.
The engineer might be a little drowsy. Nudge him to recheck.
S.
Old 01-25-2006, 08:16 PM
acceleration and hummer in same sentence you guys are a riot . and whoever said lack of power dont you know what these were designed to do ? LOL you guys should get the 32's your trucks will be so fast
Old 01-25-2006, 08:31 PM
i am not interested in being fast, but i just dont want to hinder stock accl. ect....
Old 01-25-2006, 08:35 PM
Alan06SUT's Avatar
A 4:1 gearbox is like being in the lowest gear on a mountain bike (ie your pealing fast and not going very far, but you can make it up a very steep hill). A 2.56:1 gearbox is like being in a low to middle gear (ie your peading slower, and can't make it up a steep hill, you just dont have the power, so you switch to an easier gear). Same with a lower t case ratio. The 4:1 can crawl and climb better that a 2.56 box. That is why the h3 adventure has plent of power to climb steep ass hills without stalling, even though it has a relatively small motor.
Old 01-25-2006, 08:37 PM
I'm about ready to blow a gasket on this one, so I'll KEEP sitting this one out.
Old 01-25-2006, 08:49 PM
Yea Hummer and acceleration in the same sentence is a riot for sure All Hummers are slugs by road car standards, but they were engineered to meet offroad criteria that very few vehicles at any price can match.
But we keep reading about people complaining about the power on the road. Then they add 35" and 37" tires and complain even more as the auto tranny downshifts constantly trying to maintain any speed going up hills. In my opinion H3 power is adequate, but I'm not in a rush to make it even slower.
S.
Old 01-25-2006, 09:47 PM
thanx steve, that was my exact point/concern.
Old 01-25-2006, 10:38 PM
I should keep out, but I won't. The engineer in question is the head service engineer for this part, he is a manager, he is also in charge of the release of this part to service application. He assured me it was a 4:55:1 gear, and this went right along with all the vehicle history build sheets I pulled up in the system.
In my opinion, I don't need to nudge him. Maybe those with all their innuendos and assumptions should get nudged a bit.
Partial copy of my Build sheet, H3, auto, with off-road package:
G94 - LOCKING DIFFERENTIAL HC4 - REAR AXLE 4.56
JB9 - BRAKE LIGHT JJA - PT DRESS SUBASSEMBLY INSTALLED
JL4 - STABILITRAK-STABILITY CONTROL KA1 - FRONT HEATER SEAT
KG7 - 125 AMP GENERATOR K05 - ENGINE BLOCK HEATER
K34 - CRUISE CONTROL L52 - 3.5L DOHC 220HP ENGINE
M30 - 4-SPD AUTOMATIC TRANS W/ STABILITRAK-STABILITY CONTROL NP5 - LEATHER WRAPPED STEERING WHEEL
NR6 - 4:1 TRANSFER-CASE NT9 - FEDERAL EMISSION SYSTEM TIER 2
Build sheet of a H3, manual, off-road package:
FE9 - 50-STATE EMISSIONS HC4 - REAR AXLE 4.56
KG7 - 125 AMP GENERATOR K34 - CRUISE CONTROL
L52 - 3.5L DOHC 220HP ENGINE MA5 - MANUAL TRANSMISSION
NR4 - 4WD TRANSFER CASE NT9 - FEDERAL EMISSION SYSTEM TIER 2
These are the actual build sheets produced when the vehicle is run down the assembly line.
Old 01-25-2006, 10:53 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummBebe:
I'm about ready to blow a gasket on this one, so I'll KEEP sitting this one out. </div></BLOCKQUOTE> LOL cant wait to get my 35's mounted
