Old 01-05-2004, 10:41 PM
prplprowlr's Avatar
prplprowlr prplprowlr is offline
prplprowlr is off the scale
Klaus, I spoke with my dealer this afternoon and he can get me one for $1650.00 including tax and shipping. However he told me the unit is not returnable because GM told him it would not work. I told him to give me a few days, I was going to wait to see how your's worked when you got your Disc. However for the most part if I just use for the Radio & Cd player I should be fine. Have yoo had any problems with it so far?
2006 H2 Desert Sand SUT (blacked out)
2007 H2 Slate Blue Metallic SUV (chromed out)
Old 01-05-2004, 11:01 PM
Klaus's Avatar
Klaus Klaus is offline
So far no problems at all. But I understand the hesitation to buy with no way to return it. It was a big gamble for me, but now I'm glad I risked it!
I contacted GMPartsDirect about my NAV DVD order today, and they replied that my Dec 30 order didn't get processed until Jan 1. I find it hard to believe anything happened on the 1st, but that is what they said.
Klaus
Old 01-05-2004, 11:04 PM
prplprowlr's Avatar
Did you do the swap out yourself? How long did it take? I appreciate all the time and info you have given to this subject.
Old 01-05-2004, 11:13 PM
Klaus's Avatar
I did it in 2 leisurely days. Day 1 I used to disassemble the dash. Day 2 I went to Sears and bought metal sheers so I could modify the GPS antenna mount to bolt it to the dash of the Hummer. I then reassembled the H2, while taking pictures.
If you are in good with your dealer, see if they can find out if the GPS antenna made for the 2004 H2 can be purchased. I have not been able to get any info about it, so I bought the GPS antenna for what I think is the Escalade and modified the antenna mount.
Klaus
Old 01-06-2004, 06:05 AM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
Hope it all works out. I am happy with mine and I am sure you will like it. Just now if we can use it above 8mph.
Craig
04 Pewter H2- Lux,nav, air suspension
Craig
Old 01-07-2004, 03:22 PM
Klaus's Avatar
I received an email from GMPartsDirect that my NAV DVD shipped today!
Klaus
Skull & Bones Member since 2003
Old 01-07-2004, 04:40 PM
Congrats... To bad I did not live closer I would let you try mine.
Craig
Craig
Old 01-09-2004, 08:03 PM
Klaus's Avatar
Well guys, I got my DVD NAV disc, and I have some bad news... You're going to want to spend some money!
Klaus
Old 01-10-2004, 12:40 AM
Klaus's Avatar
Just to confirm, my navigation system is working perfectly.
This system is really cool.
DING... CONTINUE ON I-EIGHTY-FIVE NORTH.
Klaus
Old 01-10-2004, 09:50 AM
Bevo Bevo is offline
Bevo is off the scale
Pictures and write up please ! But first, let me thank you for all the info and work so far.
Yellow 03 Adventure w/black Grill, UM8 Touch Screen Navigation Radio, U2K XM Digital Radio, Remote 6-CD Changer, JBA Titanium Headers, Corsa Off-Road Sport, Airaid Filter & MIT, Nology Wires & Plugs, S&P Pro-Flash, Warn 9.5ti w/X-Line, Toyo Open Country M/T 37x13.5.
Old 01-10-2004, 12:01 PM
Detonate Detonate is offline
Detonate is off the scale
North Texas Hummer Team Member
2003 Red H2 equipped with Tough Country Heavy Duty Armor Series Front End with Winch, Rear Bumper, Brush Guard, and Roof Rack.
</center><hr>
Old 01-10-2004, 08:11 PM
Klaus's Avatar
I have a rough copy of instructions/pictures in an Adobe PDF format. I have sent it to Jason to post.
If you want it, send me your email address, and I'll send it to you. 4MB.
Klaus
Old 01-12-2004, 09:34 AM
drouke drouke is offline
drouke is off the scale
As much as I want it, I can't justify all that dough.
Old 01-12-2004, 11:25 PM
Klaus's Avatar
Ladies and Gentlemen,
Jason has added a link to the Navigation Installation Document on the "FAQ" page. Check out question 6 in the "For H2 Owners" section.
http://www.elcova.com/h2/faqs.html
Thanks Jason!
Klaus
Old 01-13-2004, 03:04 AM
hummer17 hummer17 is offline
hummer17 is off the scale
Hey Klaus,
Thanks for all of the great information. As I had earlier suggested, it is possible.
In your document - is that rust on the metal support structure behind your dash?
Does GM know about this problem? I have taken apart plenty of dashboards in my time to install radios and I've never seen that much rust on the metal underneath in a car that is only 1-2 years old.
Someone should submit your picture to GM.
That much rust is no good for the long term.
Thanks,
Old 01-13-2004, 03:09 AM
Klaus's Avatar
Yep, it's rust. I think it is a required factory option for H2s.
Klaus
Old 01-14-2004, 02:53 PM
HappyJack HappyJack is offline
HappyJack is off the scale
Great write up Klaus. Thanks.
I think I may have to get this nav unit for my truck too.
Have you noticed what the so called Bose amp incompatibility is? Does the sound system sound different? Do you play your system loud?
Cheers
Cheers
Old 01-14-2004, 08:12 PM
Klaus's Avatar
HappyJack,
I have no idea what Bose incompatibility that they are talking about. The audio sounds the same to me as it did with the 6-CD changer installed.
What can I say? Mine works. Yours may or may not work, and mine might burn up tomorrow - But so far, so good!
Klaus
Old 01-17-2004, 02:41 AM
Pbuilder Pbuilder is offline
Pbuilder is off the scale
Hi
I am an avalanche owner who just installed a UM8 in it. I will say it is kick. My install needed a diffrent bose amp and mic for it to work . my question is which bose amp is in the H2. the part # is Amp #15199992.. this is the one with the UM8 needs can any one verify this #
Scott
Old 01-17-2004, 02:49 AM
by the way this is the incompatibility problem, we avalanchers have the cheep shi_ bose amp and it won't work untill you change to the above part#.
also if any else needs a UM8 I can get them also.
Scott
