Old 01-14-2006, 04:41 PM
Intercooled's Avatar
Intercooled is off the scale
Just turn 3,200 on my 05. Just had the oil changed for the first time!
2006 H2 SUT Fusion Orange LE
Old 01-15-2006, 03:00 AM
Efrain's Avatar
Efrain Efrain is offline
Efrain is off the scale
Got 12,000 on my 05. Bought it on New Year's Eve 2004. Use it mostly on the highway, very little in the city.
Old 01-16-2006, 02:42 PM
OLE YLLR OLE YLLR is offline
OLE YLLR is an unknown quantity at this point
I've got 60,000 on my 03 and still going strong.
Old 01-18-2006, 07:58 PM
ratesguy ratesguy is offline
ratesguy is off the scale
65000k on my 03 and no complaints. Just put on new tires. Also had all four doors repainted(from burglary damage) and new upholstery on passenger seat(same burglary). No mechanical issues at all. Did replace battery twice(once under warranty).
Old 01-18-2006, 08:56 PM
Racer-X's Avatar
Racer-X Racer-X is offline
Racer-X is off the scale
03 bought in Dec 02. It's not really a daily driver and only has 42K miles. List of things replaced:
rear license plate and rear door assembly
radiator, coolant overflow and all hoses
transmission (changed when radiator blew into tranny cooler cross contaminating all fluids, I raised hell until they changed it all)
windshield wiper motor
windshield wiper pulse wiper control
some steering components due to sloppy steering
evap emmision canister (changed when check engine light came on)
two cigarette lighters
been in 3 times to eliminate squeeks/rattles
front differential
Never had any front suspension or tie rod issues. Though I have seen others break them.
Edited to add: Forgot my AC went out once. Filter installed backwards from the factory.
Old 01-20-2006, 01:03 PM
md_sailor's Avatar
md_sailor is off the scale
37,650 miles on my '03 only Major issue was with my Catalytic converter which was replaced @36,001 miles. + all of the other trivial bull**** things.... trans slip, mirror folding ect...
Old 01-20-2006, 05:53 PM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
37,905 miles on my 03. Since around 24,000 miles I have had the following done. Nothing huge, but many annoying things
1. Driver door light fell inside the door
2. Driver seat heater bad, replaced entire seat
3. Passenger A-pillar warped due to heat from sun
4. Cat converter replaced due to Check Engine light
5. Antifreeze smell, replaced water pump
6. window tint replaced on drivers door - damaged by tech when replacing drivers seat
7. Oil leak on xfer case, replaced 1/2 of xfer-case casing
8. Roof markers replaced due to water leak
9. Rear door/hatch handle assembly replaced
10. Under hood mat replaced after Tech saturated it with Transmission oil during a transmission service.
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 01-20-2006, 08:00 PM
MUH_HUM MUH_HUM is offline
MUH_HUM is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dug3x3:
85,000 on 03 and still have two of the original tires on it. (with decent tread) Would still have all four on if i didnt burn them off when i was stuck. Havent had any major problems with it and havent really taken to much care of it . It pulled a 32' camper way overloaded around the eastcoast. Pulled boat in and out of salt water, pulled bobcat on trailer. This thing has been tougher than nails. </div></BLOCKQUOTE>
Remember this folk when Dug is sellin his beast. He beat the hell out of it!
Old 01-20-2006, 08:01 PM
Oh 3885 on my '05. Had it 8 months. I don't drive much....
Old 01-27-2006, 01:17 AM
Denny Crane Denny Crane is offline
Denny Crane is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by dochummer:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Texas Red:
I just went over 40,000 in my '03. No problems except mirror folding, battery (of course), and recent front differential leaky seal replacement. Still on original tires and brakes. </div></BLOCKQUOTE>
Same here...except for the problems....Actually, I haven't checked the front diff..... </div></BLOCKQUOTE>
I get my 03 back tomorrow w/53K on the clock back from the Stealer for a leaky front right axel bearing.....365.00 out of warranty.
D
