Old 02-19-2003, 04:51 PM
JohnnyBoy JohnnyBoy is offline
JohnnyBoy is off the scale
I did not get the grill mounted off road lights with my H2. I want to get some, but not the factory and/or dealer installed ones. Does someone make a bracket for the aftermarket lights that can be bolted to the holes in the stock brush gaurd?
'03 Hummer H2 Adv./Lux. Pkgs. Sunset Orange W/Sunroof
Air Spring Susp. Pkg. + 3rd. row seat & DVD System.
CompuStar Auto Security/Remote Starter.
http://www.haugens.com
\'03 Hummer H2 Adv./Lux. Pkgs. Sunset Orange W/Sunroof
Old 02-19-2003, 07:17 PM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
I will be drilling a 7/16" hole in the existing square spot on the brush guard, and mounting there. That way I don't end up with a "UMME"
I am also having a friend look at making a box that replaces the trapezodial plastic wingy things and mount lights there as well.
I have mounted rectangular lights to my roof-rack base...the lights extend up 2 1/2" above the roof rack, so the lights are able to clear the garage opening.
Ric
OMAHOG/IHOG
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 02-19-2003, 07:40 PM
TBarrow TBarrow is offline
TBarrow is off the scale
Yeah , I was at my dealer the other day and asked him when they decided to sell the swedish knock-offs. He said what do you mean I told him he was trying to pass an "UMME" off as the new H2. He had a good laugh.
Old 02-21-2003, 03:35 AM
TonkaH2 TonkaH2 is offline
TonkaH2 is off the scale
I'm planning on mounting my extra lights UNDER the bar, where the two plastic squares are outboard the lower grill. I notice that there are two plugs on the plastic molding above the bumper -I haven't pulled them yet to see what they're for. I am tempted to replace all the plastic, including those flimsy winglets above the tires, with a steel or aluminum piece.
That would allow me to replace the driving lights with larger ones, and use any style size I choose. Has anyone else considered this?
-Jack
Yellow H2 adv. IN MY HANDS!!!
Alaska to ??? June '03
www.sunspotnatural.com
yellow H2 adv.
Old 02-21-2003, 05:51 PM
Hum2's Avatar
Search for/See posts by Auburn:
H2Black H2 w/ Light Brackets installed
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 02-21-2003, 05:55 PM
Hum2's Avatar
The plastic plugs cover up bolts that hold the lower bumer on. No good for mounting anything.
Also, you can't hang anything down from the brush guard, unless you remove the lights everytime you open the hood.
Ric
OMAHOG/IHOG
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
