Old 12-24-2005, 06:26 PM
Dave Compson Dave Compson is offline
Dave Compson is off the scale
Ok, need some advise. I did a search and couldnt find anything about this. I noticed there is a seeping type of leak from both sides of the front differential. (where the diff meets the axles) Also, there seems to be a tire type of howl at speed. When the speed is low, there is no noise. Also, there is no clunking noise, or vibration in the wheel or near the front of the truck. I cant figure out if the truck has loud tires, and a little leak in the front end? Or what? It is a 03 h2 with 63k on it. Never off road, (not my fault) and always serviced at the dealer. There are no error messages and again no noises or thumps from that area.
Dave
Dave
Old 12-26-2005, 01:27 AM
TXSUT's Avatar
TXSUT TXSUT is offline
Seems like a trip to a mechanic is in order. You gotta get those leaks fixed.
Old 12-26-2005, 01:52 AM
VTSTOMPER is off the scale
"howl" = worn front end in most cases. Does it do it less under a load?
Might have to replace ring and pinion or more. Could be all the gear oil is gonzo, or low. If I remember right the 03's had a TSB on the front end.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 12-26-2005, 03:55 PM
Im taking it in this afternoon to have it checked out and an estimate. The sound dosent change under load, and it dosent get louder. Its just steady. After further inspection it appears the leak is not getting bigger, its just there. Kinda like seapage.
Old 12-26-2005, 04:28 PM
It\'s a Dry Heat's Avatar
I don't like my diffs checked when I get oil changed. They seem to always leak from that point on. But at least it's a simple fix. The area where you say yours leak, could it be coming from some where else?
Old 12-26-2005, 05:18 PM
Big Z Big Z is offline
look anything like this!
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/9...356070783#9356070783
Old 12-26-2005, 05:26 PM
-its a dry heat- I am not really sure where exactlly the leak is comming from. I am hoping i am missing something simple like seapage from a past oil change, dryed up stuff. you know... something easy to explain.
-Big Z- Mine is not that bad! Wow that sucks, and the fluid looks dry and is not leaking down the lower control arm. Thanks for the thread to look at, makes me feel better.
Dave
Old 12-26-2005, 07:05 PM
if the sounds is not changing under load it sounds less like the front end to me. Have you tried it in 4X4-high?
Old 12-26-2005, 07:14 PM
H2Finally's Avatar
Dave, in 2 years I've had "front diff leak" like 5 times. All were minor leaks fixed under warranty. I wouldn't worry too much.
Can BLING Get You Home?
Old 12-26-2005, 07:20 PM
Well, the hummer dealership is closed today (for service only...) And i am way out of warranty.. So, ill crawl under there and take some photos to attach to this thread.. standby..
and thanks for watching..
Old 12-26-2005, 07:32 PM
I have not tried the 4x4 settings yet, just got the truck last week. So here you all go.
Drivers side 1
Old 12-26-2005, 07:34 PM
And for drivers side 2
Old 12-26-2005, 07:35 PM
Drivers side 3
And just for reference, heres the passenger side.
Old 12-26-2005, 07:36 PM
Pass side 2
And finally number 3, thanks for all the advise in advance.
Old 12-26-2005, 07:52 PM
could be a seal by the looks to me...
Old 12-26-2005, 08:38 PM
A seal is better than a whole new differential. Any idea on cost estimation? And, does it look like its just the drivers side, or both?
Old 12-27-2005, 12:36 PM
Dan Dan is offline
Mine looks like that too. Taking it in next week. One of the techs here said he could change both in about an hour which should help you get an idea on cost.
