Old 06-25-2003, 12:51 AM
H2 Daddy H2 Daddy is offline
H2 Daddy is off the scale
I had the same problem with my frame when my truck was new. The coating on the frame was coming off and the frame was starting to rust. The area in question was by the rear wheel on the driver's side. I wouldn't have cared if it wasn't in such a visable location.
I took mine H2 back to the dealer. The service manager contacted Hummer about the problem. He told me that others also had the same problem. The factory told him that the coating material was not yet available for the public and would send the dealership the product when it became available. A couple weeks later the service manager called me and I brought my H2 in for recoating. I looks ok but they could have done a better job of cleaning the loose and flaking material off, but I am happy they took care of the problem with no questions asked.
The service manager gave me the rest of the can to touch-up any areas in the future. The product is called "NOX RUST X-121B" made by the Daubert Chemical Company. The lable says "one coat rust preventive coating for vehicle chassis parts". The lable on the back states the product "meets or exceed the following OEM vehicle manufacturer performance requirements: GM Spec 998-5404, GM Spec 998-6089.
Tell you dealer to order this material and recoat your frame.
Old 06-25-2003, 08:40 AM
MisterEd MisterEd is offline
MisterEd is off the scale
Great info!
THANKS!! I will do so!
Age is a state of mind, if you don't mind, it doesn't matter.
If you\'re following me, you won\'t make it!
Old 06-28-2003, 03:07 PM
Klaus's Avatar
Klaus Klaus is offline
TSB:
http://www.elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=212600585 3&r=2126005853#2126005853
Klaus
Old 06-28-2003, 03:49 PM
Thanks!!
Old 07-01-2003, 01:51 AM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
did buckeye ever write what happened at the dealship
