Old 11-28-2003, 06:51 PM
H2Dude H2Dude is offline
H2Dude is off the scale
cmb31078,
I appreciate the link but it covers the center counsel and not the dash where the radio is. Is there another post covering that?
Thanks again.
Old 11-28-2003, 07:15 PM
Patriot Patriot is offline
Patriot is off the scale
H2Dude,
When you take out the center console there are two screws in the front of it that attach the center console to the radio bezel. They are hard to see in the post by Happy Jack but they are there...up under the console lip a bit. The two hex bolts you see in the radio bezel are the other two item you need to remove. From there, there are only pressure clips that hold the top of the radio bezel level with the dash board.
To recap:
1) Remove center console. Make sure you get the two foward most screws that attach the console to the radio bezel.
2) Pull center console back about 1-2 inches.
3) Remove two hex bolts in radio bezel.
4) Pull straight back on radio bezel.
Once this is done you will easily see three screws that hold in the radio.
I removed the glove compartment to allow room to route the IP-Bus wire up under dash.
Hope this helps!!
Old 11-28-2003, 10:07 PM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
I got mine and I am trying to install it. There is a yellow and black wire off of the PIOGM1 Harness from soundgate... Where do those go to.. Are we suppose to hook those up to power and ground or leave them alone. Mine is not working and I am trying to figure out why. Thanks for a quick response anyone.
Craig
04 Pewter H2- Lux,nav, air suspension
Craig
Old 11-28-2003, 10:49 PM
Craig,
Didn't you get instructions with yours??
Yes, the Yellow and Black wires are for power and ground. They recommend also putting an in-line fuse (5amp) with the power line.
Make sure the power is "continueous" and not "inginition-on-only".
Old 11-28-2003, 10:54 PM
That is what I thought. Mine is still not working.. I am trying to add a cd changer as I am getting xm soon. I do not think the changer is compatiable. They said any on soundgates site then I get the device and it sasy the 1270 and I have the 1280. I guess time to order the next one.
Craig
Craig
Old 11-28-2003, 11:18 PM
So is the yellow and black off of the adapter harness power for the pioneer device or does that need to be hooked up for power to the Soundgate adapter? Thanks in advance.
Craig
Craig
Old 11-29-2003, 12:07 AM
I got it working... Thanks for the help Patriot. It works with the 04 with facotry Nav for all those wondering.
Craig
Craig
Old 11-29-2003, 12:33 AM
Good to hear...enjoy
Old 11-29-2003, 01:50 AM
It works great with the 04 with Nav I will post some pics tomorrow. I am off to work now.
Craig
Craig
Old 11-29-2003, 07:20 PM
Good job cmb31078. Im just waiting for my PIOGM2 to arrive from UPS and I will be tearing out the dash. Thanks for the updated info on the center counsel and dash Patriot.
