Old 07-24-2005, 11:35 AM
H3Lady H3Lady is offline
H3Lady is off the scale
Hi
Does anyone know the bolt pattern and offset required for aftermarket wheels.
thanks
Hi
thanks
Old 07-25-2005, 03:31 PM
Webb70 Webb70 is offline
Webb70 is off the scale
The bolt pattern is standard chevy 6-bolt, with a standard off-set(depending on rim width).
Old 07-26-2005, 01:23 PM
FormerJeeper FormerJeeper is offline
FormerJeeper is off the scale
A standard offset.
What the hell is that
I think she wants the offset of the stock rim so she can calculate the offset of a 16x10 rim.
Anyone know what it is?
-C
Old 07-26-2005, 09:35 PM
BB BB is offline
BB is an unknown quantity at this point
6 lug 5.5" bolt pattern +30mm offset
Old 07-26-2005, 09:37 PM
thanks
Old 07-28-2005, 03:33 AM
Offset doesn't really factor into things for most people.
Backspacing is the most important if you are fitting wider tires, because you want to fit a new wheel that will be spaced out from the body of the vehicle. You will get a wider track doing this whcih will increase offroad stability but lessen turning radius, but you wont foul the inside or the control arms/springs.
If the tire sticks out too much you may need wider flares, but there are some avialable for the H2 now, so it wont be long.
The stock 33" tire is around 9" wide.
I'm going to fit 33x12.50 Super Swampers on mine , which wont fit the stock rims, so I'll go to a 16x10 with less backspacing, moving the wheels outwards relative to the mounting point.
I think 5" backsapcing will be about right.
-C
Old 08-03-2005, 03:25 AM
Fabtech's lift for a H2 puts 37x12.50 tires on a 4 5/8" backspaced 16x10 rim, so I was odd by 3/8 of an inch
-C
Old 09-27-2005, 06:26 PM
kram kram is offline
kram is an unknown quantity at this point
I've been fighting the Bolt Pattern/offset problem, but the biggest problem with aftermarket wheels is that the centerbore on the H3 is much larger than other GM products. The bolt pattern is the same as the Escalade and the offset is close (+30mm H3 : +20mm for the Esc), but the big problem is the centerbore for the H3 is 100.6 while most GM (Esc, Tahoe...) is 87. Most aftermarket wheels will not fit the H3. You have to use the foreign vehicle wheels to accept the larger centerbore, but then the offset is off by over an inch. There are only a handful of wheels made that will work on the H3 correctly or close........... or you can have the centerbore "milled" to to fit the H3. I kept being told if I waited 4-6 months there should be multiple wheels for this application. I didn't want to wait.
Old 09-27-2005, 06:30 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by kram:
I've been fighting the Bolt Pattern/offset problem, but the biggest problem with aftermarket wheels is that the centerbore on the H3 is much larger than other GM products. The bolt pattern is the same as the Escalade and the offset is close (+30mm H3 : +20mm for the Esc), but the big problem is the centerbore for the H3 is 100.6 while most GM (Esc, Tahoe...) is 87. Most aftermarket wheels will not fit the H3. You have to use the foreign vehicle wheels to accept the larger centerbore, but then the offset is off by over an inch. There are only a handful of wheels made that will work on the H3 correctly or close........... or you can have the centerbore "milled" to to fit the H3. I kept being told if I waited 4-6 months there should be multiple wheels for this application. I didn't want to wait. </div></BLOCKQUOTE>
What rims have you been looking at that will owrk and what size?
Old 09-27-2005, 06:38 PM
Keep in mind that I bought this for my son, but he wanted 20+" rims for the vehicle. I was limited to a selection of 2 wheels that would "fit" as tried by the installer. I didn't like either (SMA also has a couple). I have a thing for MOMO wheels so we picked a wheel that that they make for both the GM products and the foreign vehicles........... that way MOMO guaranteed there was enough material to mill the centerbore on the "GM Version" to fit the H3. This was a very time consuming process and momousa.com (cust service number) was very helpful in getting me a wheel to fit........... PS We ended up going with 22's.........
Old 09-28-2005, 11:45 AM
jsw029 jsw029 is offline
jsw029 is off the scale
Can you post some pics of your new wheels?
Old 11-27-2005, 12:25 AM
Here is one......................
Old 11-27-2005, 12:26 AM
Here is another.............
Old 11-27-2005, 12:28 AM
It is actually my son's Christmas present...... just arrived this week. Wheels are on, need the chrome side steps. I got some really nice Katzkin leather seats off of ebay. They get installed this week.
Old 11-27-2005, 10:01 PM
TA8088 TA8088 is offline
TA8088 is off the scale
Want to adopt another son?? JK. Looks cool, though I'm probably not going with anything bigger than 18" on mine. This is one of the better looking H3/big rim set-ups that I have seen.
Old 11-28-2005, 02:32 AM
I actually have a thing for the MOMO wheels. They have some of the best quality out there! I have had them before and swear by them. I went to several of the larger tire/wheel locations here in Houston and tried to find wheels, but all anybody could show me was a couple "off-brand" wheels and the couple that were on SMA. But He was not looking for an "off-road" looking tire. Anyway, the milling was easy and at least there won't be any/many people with the same wheels on their H3!!! There should be a lot more coming onto the market in the first quarter of '06 as a lot of the H3's are hitting the street.
Old 11-28-2005, 02:42 AM
Close-up of the wheel.
Old 11-29-2005, 01:48 AM
these will fit if you want an offroad tire
Old 11-29-2005, 03:51 AM
BABHUMV's Avatar
BABHUMV BABHUMV is offline
BABHUMV is off the scale
I had to mill for another one of my vehicles. It is one way to know you may have one if not the only wheels on the specific vehicle. These look great by the way !!
