Old 11-11-2005, 03:01 AM
You are obviously just looking for a fight. If you stood in front of me, I highly doubt you run run your lip service in my face </div></BLOCKQUOTE>
Lets see, I disagree with you about a winch post a month ago and call you a fool (your tech. on this subject as it relates to an H2 is false so you really are). That was weeks ago then out of the blue you call me a racist and tell me I should be banned. Humm..... I' m thinking your little e-pussy is really hurting boy.
As for standing face to face, good grief little boy </div></BLOCKQUOTE>fight.... fight.... fight... fight
Old 11-11-2005, 03:04 AM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
Ah now I understand all the alingment posts by Alec in the other threads
Old 11-11-2005, 03:08 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
The only fool here is Alec. Before making accusations about something you know nothing about, you might try searching the internet for "winch weight alignment front" and you will see that there are many out there with problems doing this on vehicles with much stonger suspension than on our Hummers.
I can back up my claims with lots of links to others having issues with adding extra weight to the front end of their vehicles. Yet, you have nothing but a blabber mouth that continues to run people away. You seem to never learn... </div></BLOCKQUOTE>
Okay, I tried your suggested search. Tried it on two seperate search engines. There were no links to any such problem. So now you need to make good on your boast - back up your claimn with some specific links?
Thanks,
Sean </div></BLOCKQUOTE>Like this:
http://www.google.com/search?sourceid=navclient&ie=UTF-...ight+alignment+front
Old 11-11-2005, 03:09 AM
CslRkH2's Avatar
Hmmm
I know. His damn name kept adding up over on the right.
Old 11-11-2005, 03:10 AM
CslRkH2's Avatar
Huh?
Old 11-11-2005, 03:16 AM
CslRkH2's Avatar
Get 'em!
Old 11-11-2005, 03:28 AM
Some of you may or may not remember my little capstan winch brainfart idea. I said then that synthetic line was going to change winching in more ways than one and thought up a possible plausible scenario.
A year or 2 ago I had to winch a county-leased ditch witch that weighed roughly 7K lbs out. Not only was it stuck but it was buried in a remote easement. It had been raining forever, the DW was at the bottom of a muddy hill that was too far for me to winch. I had to drive down the hill, winch it out of the hole, turn it around, winch myself part way up the hill, turn around and winch it part way up, winch myself to the top and then turn around and winch it up. Each time I had to tie the rear of the truck off to a tree and, at the top, the bottom of a power distribution line pole. I had wire rope on at the time, not sythetic.
So, all this talk about winches again and it's going to start getting muddy around here again and sometimes we get stuff stuck that is bigger than my truck and I got to thinking. If I had synthetic line when I was winching the DW out, I could have had a 250' rope and used my winch like a capstan style winch. I could have strapped off my truck to the bottom of the pole and then ran several rounds of line around the winch drum and let the free end fall to the ground. Snatch block it on the DW and had a much easier time of pulling him out. Instead of having to go to him I could have pulled from afar. Yeah I could have used my extension line too!
But what about longer runs of synthetic line in other situations. Having a long line, 3 or 4 snatch blocks and some straps and a little jeep would be able to easily retrieve us, if his frame would hold together and there was something he could tie off to. Not to memtion you are pulling at maximum pull during the entire pull since the line is not spooling up on the winch drum.
One could go around with a longer line in their kit and easily unspool their regular line and use this setup should the need arise. I think.
