Old 05-09-2003, 03:09 AM
JPrusinowski JPrusinowski is offline
JPrusinowski is off the scale
Wow! Air conditioning system really struggling down here in Mississipi. Anyone having problems with cooling? Just seems to run forever at high fan levels trying to compete with our mild 95 degree weather. Any suggestions or info appreciated.
As if milage wasn't bad enough.
Jeff
Jeff
Old 05-09-2003, 05:40 AM
Detonate Detonate is offline
Detonate is off the scale
Do you have the recurculating air button on?
Mine works fine down here in Texas.
-Jim March
Arlington TX
2003 Red H2
Beauty is in the eye of the Beer Holder
</center><hr>
Old 05-09-2003, 10:07 AM
OUSUCKS OUSUCKS is offline
OUSUCKS is off the scale
I seem to have to push the ricirculation button everytime I start the rig. Is there a way to have it stay on all the time?
Old 05-09-2003, 10:35 AM
Jeff,
I too live in MS and have had my H2 since Aug and the air is something you'll have to live with. I haven't thought again about it not cooling very well until I saw your post. The air system is just not up to par compared to other vehicles.
I will say also to check the little knobs in the center of your vents. These knobs twist and open and close the vents and it took me a week or so before I figured out that 2 of my vents were partly closed.
Old 05-09-2003, 11:02 AM
JCJ JCJ is offline
JCJ is off the scale
I too am annoyed by having to turn on the AC recirc button every time I start the car.
Recirc is the only way to cool the car sufficiently (quick) and without letting outside fumes in in our climate.
Even so the recirc mode does not "filter" all exhaust smells of cars in front.
The Jeep GC(Overland)'s recirc button stays on permanently once hit.
Old 05-09-2003, 12:35 PM
noahald noahald is offline
noahald is off the scale
JPrusinowski, check the classified ads section and read the post titled "3rd Row Heat and Air Conditioning".
ProAir has designed, manufactured, and installed air and heat systems for over 25 years. We have found that by adding a rear system it is possible to improve the overall performance of the entire A/C system. Extensive testing will be performed prior to launching our system to verify this is the case with the H2.
If you have any questions you may email me at marcd@proairllc.com or post a reply. Visit the ProAir website- www.proairllc.com
Old 05-09-2003, 12:37 PM
JSA_3 JSA_3 is offline
JSA_3 is off the scale
Everyone has a point, and I agree. I don't think we should have to "fiddle" w/settings especially in auto mode to cool the truck. I have experienced all of this after our 1st 2 weeks of 95+ and high humidity (white w/sunroof). Short city hops are the worst.
Phil is correct that the A/C should cycle in and out of recirc on its own in auto mode to deal with the heat. I try to help the A/C out a bit by selecting recirc mode at red lights and stops, and deselecting it once under way. Also, closing the sunshade on the "sky roof" helps tons.
I don't know about the H2 but on previous vehicles I've owned the A/C compressor cycles off below a certain engine rpm. I have found while in park or neutral that if I increase the idle to between 900-1000rpm the A/C seems to blow colder air. (don't know how good this is on things though)
Is it me, or does it seem like the newer R-134 systems just don't cool like the older R-12 systems?
\'02 HMCO
Old 05-09-2003, 01:12 PM
JSA_3,
By increasing the engine idle you are 1. moving more refrigerant through the compressor, and 2. moving more air across the condenser at the front of the vehicle. The result is cooler air from the vents.
Generally speaking, R134a produces higher head pressures than R12. Higher head pressure equates to higher system temperature and diminished cooling.
Old 05-09-2003, 07:09 PM
Glad to know it's not my imagination.
\'02 HMCO
Old 05-11-2003, 08:41 AM
AL MOORE AL  MOORE is offline
AL  MOORE is off the scale
JEFF,
On a recent trip to William Carey in Hattiesburg, the 3rd row set was almost "un-stay-able". However, most teenagers will hang in there for a ride in an H2! We have had no problems up front.
AL
"I come back to you now; at the turn of the tide." Gandalf 2002
\"Follow the white rabbit...\" Morpheus 1999....... It is finished.
Old 05-12-2003, 03:56 PM
8MYROVER 8MYROVER is offline
8MYROVER is off the scale
A friend of my complained about the A/C with his Chevy 2500 HD. Dealer in Calif. could not fix it, so he took it back to AZ where he bought it. Apparently, the A/C systems are really "picky" and turned out his was "over charged" Dealer said the pressure has to be exactly as specified or won't work correctly. Once the system was set at the correct pressures, it worked perfectly in Palm Springs, CA. Might have your dealer check your system.
Old 05-18-2003, 01:55 PM
Circuitguy
An a/c system will blow colder faster if the fan speed is at a lower setting. It takes time for the evaporator to chill after you first turn it on. Blowing a fast stream of hot air threw it right after you turn it on will make it take even longer to cool the car. If the car is very hot when you get in roll the windows down first as you will drop the temp greatly just by doing that. Then turn on the a/c with the fan at a low speed for 30 to 60 secs or so then roll up the windows and turn up the fan speed. It should get very cold quickly. Try this yourself and you will find it works. C
First American Properties Inc. 916-858-2383
White 03-H2-LUX
Old 05-18-2003, 02:01 PM
Hummer Man is off the scale
Great advice CIRCUIT GUY. I'm never in the 3rd Row but they tell me it's warm back there !
"FORUM FOUNDING MEMBER 11/03/02 - #1 H2 SITE"
Old 05-19-2003, 02:41 PM
H2 Bill H2 Bill is offline
I went through part of July, August and September last summer with 100+ (up to 117) temps and we had 100 degree temps this weekend and mine would freeze you out. I'm thinking that 8myrover could be right! Have your dealer check out the freon level.
2003 H2 Hummer, Yellow,Polished Whipple Supercharged, Edelbrock ceramics, catback,18" Ambush w/mudders,lots of goodies!
Y2K Corvette Millennium Yellow Convert/Blk/Blk, B&B headers, B&B Tri-Flo's, H-Tech MAG,GMS MAF, RM Racing TwinFlow, CLB, Window Commander, Euro Tail lights.
www.4swimwear.com
1994 Chev Suburban Blown
Old 05-19-2003, 02:51 PM
DURAMAX TIM is off the scale
Not to sound racist but color makes a BIG difference.
Black ones will have a harder time cooling than white H2s.
98 ZR-2 Blazer
Ex H2&3 owner
Old 05-19-2003, 03:12 PM
Tucson Beast
DURAMAX TIM
How right you are - in Arizona you learn about car color real fast - this is why I always state - "White is Right"
Three white and cool Tucson Beast
Old 05-19-2003, 03:14 PM
Tucson Beast
Sorry for typo - hit Post button to fast - "Three = The"
Tucson Beast
Old 05-19-2003, 03:31 PM
Circuitguy
White is grrrrrreat!!! White is right! And because my H2 is white that also helps... C
White 03-H2-LUX
