09-24-2004, 02:31 PM
I have an annoying squeek from the driver side somewhere outside. Recent lube job...cant find it. Random....Ideas???
People Who Annoy Me...NAGGERS
09-24-2004, 02:34 PM
Suspension?
There have been posts about the weather stripping causing sgueeks. Lubricate the stripping.
Suspension?
09-24-2004, 02:50 PM
I had a Squeek on the driver side, I thought it was on the out side. It turn out that the Jack Holding Mount was loose.
09-24-2004, 03:14 PM
Mice?
Ric-H2
www.meatspin.com
Mice?
Ric-H2
www.meatspin.com
09-24-2004, 04:07 PM
Hey James...Will you be coming out to the Texas Ski Ranch with "The Max" this weekend. Give me a call if you do so Gage and Rory can play!
Ric-H2
www.meatspin.com
Ric-H2
www.meatspin.com
09-24-2004, 05:00 PM
Had a sqeek also. The back driver's side door was rubbing against the weather stripping at the top. It sqeeked whenever the rear door was opened and when driving. Put some WD40 on the weather strip and it went away.
2003 Yellow H2 LUX (Sold)
09-24-2004, 06:59 PM
09-24-2004, 08:19 PM
brake sqealer hitting rotor? how many miles are on it?
09-25-2004, 02:51 AM
If it is a suspension squeak that you hear when the front suspension goes over bumps, check the front lower control arm nuts for looseining up. I've seen several do this. Put a wrench on it. It may look tight, but actually be a full turn or two loose.
09-26-2004, 04:10 PM
I've found the seatbelts on the passenger sides rub on the door pillars and sqeak and rattle. I make sure the seatbelts stay on the seats and don't fall to the sides before driving.
05 SUT Lux
05 SUT Lux
