Old 11-24-2005, 02:19 PM
va_redneck va_redneck is offline
va_redneck is off the scale
The speedometer in the wife’s H2 started to jitter for several weeks and then it worked for a few days off and on then when dead. All of the other instrument work fine. I and leaning toward replacing the PCM. I have toyed with replacing the OSS sending unit on the transmission but the cruse control still works. From my understanding they both use the same speed pick up module. I have heard that a weak signal may work for the cruse but the speedometer needs a stronger signal.
Does anyone have any ideas if I should replace the sending unit first or will that just be throwing good money after bad?
Jeff / aka: Jethro / aka: Redneck
H1 - 95 NA (My HMCS)
H2 - 03 (Wife\'s)
Freedom does not come free...
Thanks to all that have served and to those who are actively protecting the freedom that we take for granted!
H2 - 03 (Wife\'s)
Old 11-24-2005, 02:47 PM
VernB VernB is offline
VernB is off the scale
I thought cruse control uses engine vacuum for its sensor, don't no for sure.
Old 11-28-2005, 03:21 PM
4churchill is off the scale
went through speedo preob on my 2003....just had it replaced when i couldnt take it any more
www.HUMMERNut.net
Old 11-28-2005, 03:28 PM
Hummertech is off the scale
Replace the PCM if you like wasting money.
Replace the IPC if you want to fix your problem.
Old 11-28-2005, 04:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hummertech:
Replace the IPC if you want to fix your problem. </div></BLOCKQUOTE>x2
Old 12-02-2005, 12:58 AM
Thanks. I will look intothe IPC.
I wish it did not rack up miles but the odometer and cruse both still function. My dealer recomended the PCM. I could not see how this would be the problem without other issues in shifting or performance.
H2 - 03 (Wife\'s)
