Old 06-10-2003, 11:30 AM
Bad Dawg Bad Dawg is offline
Bad Dawg is off the scale
Got some pics of our lifted H2 from the dealer. They aren't very good ones and I will have to take some better ones myself, but here is what I have so far. The Rancho Kit says it's a 4" lift however I measure a 6.5" difference between mine and the stock H2 sitting next to it. I realize that I gain an inch from the 37" Goodyears so that makes the lift over 5".
You can never have enough horsepower!
Used to be an H2 owner
Old 06-10-2003, 11:31 AM
Next.
Old 06-10-2003, 11:32 AM
Old 06-10-2003, 02:47 PM
Grim_Smoker Grim_Smoker is offline
Grim_Smoker is off the scale
Bad Dawg - Looks GREAT! I can't wait to lift mine, I was thinking about the rancho, but after seeing it I think I may go with the Skyjacker for a little more lift. But it looks really good. Hows it ride now? Please fill me in on you're impressions!
-Grim
2003 Sunset Metalic Orange H2 - Breathless Stage 2B, HID's, Gobi Rack & Ladder.
2003 Millenium Yellow Z06
2004 Black Silverado SS
Old 06-11-2003, 10:54 AM
Grim,
We (my wife and I) really debated which to go with...4" or 6" kit. I have the Rancho 4" on our 1 ton dually duramax and like how it's built and handles. I don't know that much about the Skyjacker but the Rancho does have the one piece welded main carrier as opposed to the multipiece kits other folks have. As for the height, I was nervious about going too high because we really do go off road a lot and with the rack and all the stuff we carry on top we figured it was tall enough. We already have two other rigs with 8+" of lift on them. Besides, the Rancho lift really is closer to 5.5" of lift not counting the tires.
A question for you: You have the stage 2B from Breathless, I have already put on the Airforce intake, headers(SMA), and exhaust for about a 40hp gain. Do you think the remaining upgrades (reflash and throttle body, etc.) make a big difference? I'm not looking to turn it into a sports car but with the larger tires it might help it a bit more.
I am attaching a pic of one of our other rigs...our Land Cruiser we mud and sand drag with.
Old 06-11-2003, 03:25 PM
I too have the Gobi Rack, and have been thinking the 6" might be too much with the rack and all. The one piece main carrier is really why I wanted the Rancho, but I still want little more lift too. And I haven't gotten off road yet, but I can't wait to! Theres really just nowhere around here What rigs do you have the 8"+ of lift on? Heck, tell me about all your toys! And whats with the bowtie on the front of the landcruiser, do you have a small block in there?
As for your questions concerning the computer reflash and the throttle body, yes I think it's worth it. I do feel a bit more power, and my economy did increase a tad bit, but I just never see it because I like to listen to my corsa sport exhaust With the reflash, the H2 shifts much firmer like it should, almost gives you a little kick in the pants. You might also want to check out the Predator programmers, I've been hearing more and more good things about them. If you have any other questions, just ask.
If you can, post pics of your toys
-Grim
Old 06-11-2003, 04:56 PM
Grim,
The Land Cruiser is out of control. We run a 541c.i. Chevy (Merlin block) dyno'd at 830+hp. A 2" suspension lift added to a spring over axel conversion when sitting on the 38.5" boggers gives it about 12+" of lift over stock. We are almost done with a frame-off restoration of our 1972 1/2 ton Short box GMC. It has a 4" lift, 2" body lift sitting on 39" Super Swampers putting it at about 11" over stock.The GMC is running our old race engine out of the Land Cruiser that's a stroker 383c.i. in the 500 hp range (not dyno'd).Don't have any shots of the GMC saved on the computer yet. Our tow rig is a 2001 1 ton Chevy Dually Duramax with a Rancho 4" lift only in the front and Air bags in the rear to help with the weight of the 11.5 ft. cab over camper. We have added the "Edge" juice box to the Duramax to bring the HP up to about 390. We run around in the race pits on our Polaris 700 ATV.
Old 06-11-2003, 04:57 PM
The Dawg's 541ci engine on the dyno
Old 06-11-2003, 04:59 PM
Try again.
Old 06-11-2003, 05:01 PM
Too big of picture I guess.
Old 06-11-2003, 05:06 PM
One more of the Dawg sitting next to our LC wagon we just sold to show relative size.
Old 06-12-2003, 12:33 PM
kdio kdio is offline
kdio is off the scale
Bad Dawg,
Did you notice any change in ride quality when the lift kit was installed. I'm on the fence of installing this kit on my H2, because I love the way this truck rides. I lifted many vehicles in the past and some rode as well or better than stock and some were stiff and wandered all over the place. Any input would be appreciated.
Kirk
03 H2 Sunset Orange Polished Magna Charger w headers & cold air intake, 37" MTRs w Weld Mountain Crushers, GPS Nav. & 2 rear LCD TVs w DVD, Extreme Tube steps
Old 06-12-2003, 05:23 PM
Kdio,
Because everything is basically still stock, just moved down, the ride remains the same. The only exception is that the new 9000 series shocks that I got with the kit were dialed in at a higher level because of the higher center of gravity. The H2 is heavy and tends to lean in the turns. The wider wheels and tires help but stiffening the shocks up helps a lot more. Make sure you get the 9000's with the kit and not the 5000's so that you can have the ability to adjust them. I personally like my rigs to be a bit on the stiff side if they sit somewhat high. I assume that you already know that you are required to replace your stock wheels according to Rancho, although I didn't go with the backspacing they suggested.
Old 06-12-2003, 05:25 PM
OOps! I just read your signiture and see that you already have different wheels.
Old 06-13-2003, 12:44 AM
Mike97ZJ Mike97ZJ is offline
Mike97ZJ is off the scale
Bad Dawg, that looks KILLER!!
I think that is the PERFECT height for an H2. Tall, but not TOO tall. I think they start to look a bit silly when they are jacked up too high, but yours looks the way it should have come from the factory.
Nice wheels, too. I really like them.
And you ROCK, btw. Over 6" taller than stock, and STILL no sidesteps!
1997 Grand Cherokee TSi
It\'s got some lift, skids, and rock rails, among other things.
*member of the \"No Hummer Krew\"*
Old 06-13-2003, 04:05 AM
Sidesteps are for wussies
-Grim
Old 06-17-2003, 02:51 PM
Mike, Thanks. We like these wheels because they seem to match the "chiseled" look of the H2.
We took off the side steps as soon as I got the time to do so. It's a stretch getting in, especially for my wife, but we both like the looks and usability of the rig much better. I like the idea of a retractable type but that would be just more stuff to get broken.
You can never have enough horsepower! Yellow LUX, Airforce intake, stainless headers and exhaust, Gobi rack and ladder, roof mounted off road lights, full wrap brush guard, rear light guards, outside tire carrier, Rancho 4" suspension lift, Ultra "EN4CER" 17x9 wheels, Goodyear 37/12.50R17 MT/R tires, removed side-step bars.
