06-12-2006, 03:00 AM
Intimidated by Engine Compartment
I just opened the engine compartment of my 2006 Hummer for the first time. I had planned on doing the coolant bypass at the throttle body....just as I had on my 2003 Suburban..
I just shut the hood and said f*** it!
Obviously, you can't work on the engine from the front, and it's a long reach from the side........I guess you need a stepladder too. Maybe I'll get used to this, but I never thought it would be so difficult to get in there.
Do H2 mechanics climb up into the engine compartment? I have new respect for the people working on their H2s!!
06-12-2006, 04:14 PM
Re: Intimidated by Engine Compartment
intimidated?????
06-12-2006, 04:29 PM
Be thankful for so much room in the engine compartment. There are many cars out there that have no room and leave your knuckles begging for the larger compartment.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
06-13-2006, 01:15 AM
May I ask, what is a coolant bypass? And what does it do for the car?
05 Lux Suv
95 Ducati 916
06-13-2006, 01:20 AM
06-13-2006, 01:48 AM
Thank for the reply, but does it really work or help?
05 Lux Suv
95 Ducati 916
06-13-2006, 01:50 AM
I have absolutely no idea. It makes sence, but idunno!
06-13-2006, 02:16 AM
i would love to know if that works as advertised, it seems to good to be true
06-13-2006, 04:17 AM
Beware that those gains on the dyno chart also were contributed by a ported throttle body and EGR mod as noted on the dyno chart.
06-13-2006, 05:11 AM
Anything to get the air temp down is a good thing. I use it even on 99 Silverado. It should in theory work. It is hard for Me to tell as I did not take a temp reading of throttle body with hot water running through it and one after.
If You are up north I would not recommend eliminating it. It helps with real cold starts.
06-13-2006, 06:07 AM
06-13-2006, 06:14 AM
