Old 06-22-2006, 09:48 PM
Mr. I - Man's Avatar
Default Re: Lift kits
Dont forget to pack the diffs with a 9.88 gear ratio and titanium super atomic mind-controlled lockers front and rear.
Old 06-23-2006, 06:42 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
you can save money by going with a Canadian diff. The rear differential conversion rate is 0.89, so you can actually go with 8.79 Canadian gears and get the same overall gear ratio, but cheaper.
Old 06-23-2006, 05:05 PM
That's GREAT info, but everything from Canada is crooked and missing parts.
Old 06-23-2006, 06:43 PM
That pleases me.
MDimitri's Avatar
MDimitri MDimitri is offline
What do you mean Canada?!?!? We all know you buy your parts from China, which is in turn shipped to Mexico for assembly and then retailed in the Southern States by Mexican border crossers... Yaahooo!! to job losses and free market economies!!
Old 06-23-2006, 07:51 PM
I should have said Vancouver.
Old 06-24-2006, 02:38 PM
HGW HGW is offline
HGW is off the scale
Ken:
You should call me on a kift kit. No one does them better.
Old 01-29-2007, 04:12 PM
thaidoggs thaidoggs is offline
thaidoggs is on a distinguished road
I tell ya some of these guys are really funny.... almost like they are short a few bricks! Back to the original question. I am in the same situation as you.... and after reading many treads I have decided to go with the Fabtech 6" lift with 18x10 rims, 4.5" back space, with -25mm offset and 38x15.5 tires. Also I am adding the Fabtech tie rods and pitman/idler support and the Cognito steering support. You will need these to help when running the larger tires. The only problem with this set-up is if you plan to do some heavy off-road the tires will rub something fierce. Going with a 38x13.5 will eliminate this to some degree but you may still rub on the sway bar a bit a full wheel. Hope this helps.
P.S. thanks to the rest of you.......your a great help
Old 01-30-2007, 12:14 AM
We are going with the solid axle. Next time in Moab we're planning to jump the second dip on Escalator and maybe try to fly off the top of Tip Over.
I'm really looking forward to seeing this.
