06-27-2006, 04:20 AM
Re: H3 OEM Lower Grill Lights (available)
Originally Posted by evldave
ahhh, now I understand! Thanks for setting me straight! I thought I was pregnant there for a second...
anytime
06-27-2006, 05:57 AM
Location: Northwest of Los Angeles, just outside all the traffic
That's nice that the H3 already has wires going through the firewall. When doing the wiring, so you have to do any cutting, crimping or splicing of wires, or does the package just a plug 'n play affair?
Thanks,
Michael
06-27-2006, 06:42 AM
Looks cool, do they help at night offroad or onroad?
S.
06-27-2006, 01:29 PM
There are three wires that you have to splice. three under dash, three on other end in engine compartment...comes with the good gm heat shrink splices.
'06 H3 Shadow Green, Adventure, 6 disk Monsoon, SMA brush guard w/PIAA lights, Rocky Road extreme rocker protection, roof lights(off road), lower grill lights(off road), Helo Maxx8 Black Wheels, 35" Cooper STT, Garmin I-Que M4 to get home.
06-28-2006, 04:16 AM
The new GM part number is 19159112.
I have them on order.
Yellow Lux H3, w/Adventure Pkg, Borla, K&N.
06-28-2006, 05:43 PM
sweet and stealth
06-28-2006, 06:42 PM
Looks great!  Hows the output?
06-29-2006, 07:57 PM
Do the grill lights come with a kit; for the bezel around the lights or does the grill have to be replaced. I would appreciate any help with this before I place my order.
07-03-2006, 08:21 AM
The light come as a complete kit....new lower grille with lights installed and all needed parts
07-04-2006, 06:40 AM
Cestwick, I appreciate the info.
07-04-2006, 07:14 AM
So have you tried them out yet? I'm curious about the output. Night pics would be great, of course.
07-04-2006, 03:37 PM
I have not had a chance to try them out off road yet but did use them on the highway in the middle of the night and they work great...they are twice as bright as head lights and they are a nice white light..not yellowish like headlights....
08-15-2006, 11:20 PM
Originally Posted by cestwick
these are off road lights...same lights as used in roof mounted assy..There are holes in the center dash at bottom for the roof mounted and grille mounted light switches...these are completely controled by the switch..High/low beam doesn't metter...
Can these be tapped/used for non GM lights? If so could you explain how to access and splice in?
08-16-2006, 04:02 AM
The switches and wiring all come in a kit from GM. I know you can get switches seperate but not wiring. If you bought switches you could wire something up yourself, if you are doing after market lights you could still use the prerun wires going through the firewall. These wires go through the firwall at the harness and are taped back onto harness. For a nice clean easy install I recommend the factory grille lights.
07-05-2007, 05:21 AM
Like the look of them. I just won a lower grill w/lights, in chrome, on eBay. Total cost $149.95.
2006 Slate Blue Metallic H3, FlowMaster exhaust, True Flow cold air intake system, Ground Force rear lowering kit, custom locking fuel door, chrome hood grill w/handle, US Speedo gauge kit (chrome and red numbers), Custom rear tire cover, chrome tail light guard, custom paint on skid plate, new pin stripping, USMC front license plate.  Semper Fi
07-08-2007, 04:35 PM
[quote=cestwick]The switches and wiring all come in a kit from GM. I know you can get switches seperate but not wiring. If you bought switches you could wire something up yourself, if you are doing after market lights you could still use the prerun wires going through the firewall. These wires go through the firwall at the harness and are taped back onto harness.
I need to hook up a pair of Whelen strob lights in the front. Tapping into the power wire I can do, I hope, and put in another switch. Where is the spot to run the three wire cable, thru the firewall, to my control panel in the rear? Can you help with info?
PM me if you can. Thanks.
07-10-2007, 01:04 AM
just saw these lights on ebay with chrome grill not black . the guy has 3 sets new for 75.00 ea. plus 21.40 shipping. he has the factory roof offroad light kit for 100.00,3 sets, no shipping on additional items
scott
