Old 07-16-2006, 02:00 PM
Exclamation Need some help and effort
Since day one we've noticed some trucks exhibit more tire rub (in stock form) and some won't rub anywhere even after upgrading to 37" tires. I am running with a theory that some of this tire rub, severe toe in, front end problems, can be tied back to one thing on the truck. It might not mean very much except to those that wheel their trucks pretty hard and I might be way off on a tangent, but it has some merit (in my feeble mind anyway).
At your convenience please get your truck and straighten out the tires, and take a picture of the tie rods where they pass just under the frame. Do this on both sides of the truck. In your post, please also note any rubbing or front driveline/steering issues you might have had.
Here are two examples of the pictures I am going for:
Old 07-16-2006, 03:47 PM
Big Z Big Z is offline
Default Re: Need some help and effort
pass side
Driver
Old 07-16-2006, 04:11 PM
thanks BigZ, following my theory, yours is similar to mine and doesn't exhibit the problem I'm looking for.
Old 07-16-2006, 04:21 PM
I just had an alignment week before last after installing the tie rods.
Old 07-17-2006, 01:29 AM
Yo Paragon,
Took a picture in the garage but the bulbs have to be replaced and my flash is broken.
If you squint hard enough you can make out the tie rod.
Old 07-17-2006, 01:47 AM
Here ye go.
Old 07-17-2006, 04:00 AM
Here ye go.
Canasians have small tierods.
Old 07-17-2006, 04:49 AM
D, I had look pretty damn hard to see that rod. I can't believe you haven't snapped one yet.
Old 07-17-2006, 04:59 AM
Still the original.
3 tours in Moab and first Stock H2 up Potato Salad......And still the same tie-rods.
......But I feel my number is up soon.
Old 07-17-2006, 05:00 AM
Still the original.
I bet your idler and pitman arms are shot. You better check you lower ball joint, too.
Old 07-18-2006, 09:47 PM
I think he checks that often enough
Old 07-19-2006, 01:36 AM
ree's Avatar
ree ree is offline
Here are mine. I started getting a little rubbing on the PS after tightening torsion bars. Not enough to notice from the drivers seat though.
'03 pewter base H2
Old 07-19-2006, 05:45 PM
ree's Avatar
ree ree is offline
Originally Posted by PARAGON
...I am running with a theory that some of this tire rub, severe toe in, front end problems, can be tied back to one thing on the truck. ...
So...what is the feeble minded theory?
'03 pewter base H2
Old 07-21-2006, 03:16 AM
Passenger side.
Old 07-21-2006, 03:17 AM
Drivers side.
Old 07-21-2006, 03:21 AM
Originally Posted by H2 Rocks
Passenger side.
Rocks, have Trent take a look at the frame rail just above the PS tie rod.
There's a good chance it shows some old rub marks where the centerlink and tie rod made contact.
Old 07-21-2006, 04:24 AM
Ok. Here's a pic of the passenger side at a different angle. Trent said it has hit the frame before. The DS isn't as bad but has hit before.
edit; the wheels are straight in this pic
Old 07-21-2006, 04:34 AM
Nice new shocks.... Rocks.
Old 07-24-2006, 06:12 PM
Thanks! I like the way they adjust for maximum overloadage of luggage on long trips.
Paragon, what theory.?
