  #41
Old 07-23-2006, 08:33 PM
Default Re: Buying new pistol, need advice
Originally Posted by evldave
Dude, you need to calm the fuk down. I'm looking for advice, not an ass-reaming. I've got friends, who know what they are talking about, saying small caliber w/many rounds, with low recoil, is good for home defense (keep pulling the trigger, most will hit). People I know who are willing to have a rational conversation about it sure outweigh some dickwad on the internet who obviously can't have a normal conversation without throwing insults around.
When you would like to have a "rational conversation" feel free to join in.
There's nothing rational about your logic. You want the "stopping power" for a bear, but not a person in your house?
"keep pulling the trigger, most will hit"!?!?!?!??!?! This is the type of ignorance I am referring to. It's simply not the case. If you would seek a professional's advice you would realize that most do not "hit", moreover with the trained such as SWAT or other LEOs you seem to subscribe to. Many times magazines are emptied at 10 feet without a single hit. You DO NOT have friends who know what they are talking about if they tell you to utilize a small caliber handgun for home defense in deference to other handguns.
Again, how do you rationalize wanting something that will "stop a bear", but say that you think a .22 is the best for home defense? Caliber size makes sense for the bear but doesn't for human? Saying you are ignorant is not an "insult." If you continue defending your stance, then you will be in the realm of stupid, which is insulting. Being ignorant is OK, but not attempting to learn and find out the facts from those who know is stupid.
And FWIW, I have not once told you to rely on anyone on this forum's advice. There are individuals and groups that are in the industry specifically for home defense. I have suggested you seek their advice. I provided a couple of links to two of some of the most notable ones.
Old 07-23-2006, 08:55 PM
GeorgeSSSS's Avatar
GeorgeSSSS is off the scale
Originally Posted by Big Z
... I've harvested Bear with Rifle and bow and arrow, never with pistol. I carry a 44 redhawk in bear country. I also handload, and make some serious thumpers! ...
Big Z: What weight and type of bullet do you handload for bear in your 44 redhawk? I was thinking of 270 grain JSP. What's your opinion?
George SSSS
Old 07-23-2006, 09:51 PM
Big Z Big Z is offline
George SSSS
This sums up my opnion! -----BIG!
Your 300 grain with 19 gr of H110 is about right, I use 20.0 of H110 with my 300gr cast.
The reason for cast, hard cast bullets is that it is a solid that we don't want or expect to expand. At 44 or 45 caliber, we already have a big hole. Any expansion in a hand gun bullet, at handgun velocities, is so uncertain and also limits (stops) penetration and therefore killing power. It is far better to punch a 44 caliber hole all the way through than a 76 caliber hole a few inches. There is only so much energy available and if it is used up destroying the bullet and making wide shallow wounds it is of little use. We do not want a big bore revolver bullet to expand but just perform like a solid.
Cast Performance makes very good LBT style hard (BHN 21) cast heat treated solids. The heat treatment makes them hard but not brittle. In the old days we cast our own and to make them very hard we would add so much antimony that they would get brittle and actuall crumble around the edges at impact, almost as bad as expansion. Also Bear Tooth Bullets makes these hard cast heat treated solids. There are three basic styles, Long Flat Nose (LFN), Wide Long Nose (WLN), and Wide Flat Nose (WFN). Each having some advantage for certain application over the other. The LFN is the long range bullet (200-300 yds) and offers the best profile for long shots. The WFN gives the best terminal performance and likely the best choice for most hunting applications at normal handgun range (0-75yds) and the WLN is a compromise between the two and often the most accurate. Note, they all have flat noses. That adds to the wounding capability and impact stability for straight line penetration, hits like a hammer. Cast bullets can be had sized to .429", .430" or .431" (for the 44) as needed to fit the cylinder throats, (CP's normally come sized .430")which will give better accuracy and velocity. The WFN's have a full diameter band that loads touching the throats, if the bullets are too big you will have to push hard to get them in the cylinder. Normally throats of the cylinders will accept up .431". Only Freedom Arms makes very tight, uniform cylinders. My 5 1/2" barrel Ruger SBH will shoot the 290 gr LFN Bear Tooth into about an inch and a half at fifty yards, and that is as good as I can do with the iron sights. This load is 20.0 grains of Vihta N110, a better powder than the ball powders, and velocity is 1294 fps. That's about all I can get from the little 5 1/2" 44 Mag. I use the same powder charge for the CP 300 WFN and velocity is 1289 fps. Pressure is about 36,000 psi and it burns very clean, no smoke, no unburned powder. And the best part, same velocity at -20F or +70F.
Snowwolfe is using a solid bullet made of copper. I have very limited experience with them and can't say how well they will do, my concern is do they fit the throats of the cylinder as well as my custom cast bullets can. If Brooks made them for him I guess they could be sized to the throats of his revolver. Also a lighter bullet will not carry as much momentum so, even though energy is higher with the increased velocity, your performance may vary. I'll tip my hat to him since he has the good experience with them and I'm sure he's right about the penetration and killing power. There is a limit at which cast bullets can be driven and not break up at impact (about 1800 fps) and that limit will be higher for copper. I will say that a cast bullet is almost always faster at less pressure than a jacketed and I would think solid copper, due to the lower friction of the lead vs copper. We would have to do some checks on that, grain for grain of powder and bullet, and chronograph everything. More work!
Check out Laser Cast Bullets @ Oregon trail
Old 07-24-2006, 04:07 AM
Originally Posted by Alec W
Para is an ******* on elcova. All he does is insult people. Hey but if I was that fat I would have a huge chip on my shoulder too.
I'm sure your contribution is duly noted
Old 07-24-2006, 05:03 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
OK...After all the jumping back and forth, acusations and banter, what it really comes down to is, how to increase your odds of hitting an intruder(ie. recoil) with out endangering your children (ie, ricochets or sheetrock penetrations).
My recommendation FWIW is, get yourself a decent 357 revolver, when it home keep it loaded with 38cal. Glaser Blue (minimal ricochet), and when you get out and about load it with alternating 357 FMJ and Black Talons, this way if you must shoot through glass, the 1st shot will shatter and the follow-up with damage.
You can always bring along a speedloader if you need more, but odds are, you wont!
My Colt King Cobra has never let me down...
Hell... just the site of a big revolver has an intimidation factor.
Good luck in your search, but no matter what you get...Practice, Practice, Practice!!!
www.meatspin.com
Old 07-24-2006, 05:24 AM
GeorgeSSSS's Avatar
EvlDave: Big Z is making some good points at post #43 about using a solid 300 grain bullet instead of a 270 grain jsp. I've heard variations of this theme before regarding pistols and grizzley bears. I'm not certain I agree, but I'm not certain I disagree either.
Like I said, get some other opinions.
George SSSS
Old 07-24-2006, 05:50 AM
Mr. I - Man's Avatar
Originally Posted by Mr. I - Man
Fvck it go with a Wildey .475 Mag
This will knock down any thing period. Good shooting technique or not!
Old 07-24-2006, 06:04 AM
.r.e.r.e.d.r.u.m.o.e.n .r.e.r.e.d.r.u.m.o.e.n is offline
.r.e.r.e.d.r.u.m.o.e.n is on a distinguished road
But instead your a POS that either intentionally killed your kid or are guilty of negligent homicide. Which is it? You POS.
Have you melted that hottun into a piece of slag or at least removed it?
Old 07-24-2006, 06:15 AM
I think he murdered his son. But let's let the courts decide that.
Soon people are going to look at you differently Alec. The truth is coming soon.
Your pal,
Dennis
Old 07-24-2006, 06:44 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
WTF? Seems like no thread is safe.
From the looks of things, for what I'm looking for (bear safety, don't care about home defense, I have a shotgun) a minimum .40 or .45 w/large load or larger caliber, maybe .44 w/ a smaller load. Since I'm going to be backpacking, seems like a smaller caliber with larger load would be better from a weight perpective. Now at least I have someplace to start when looking. Next step will be (ignore this insanity) to hit a gunshow or two, maybe some stores, and get a feel. Then borrow/rent guns and shoot to see how they feel. Thanks to all for their constructive comments on my original question. To all the rest, hope you have something better to do with your time.
Old 07-24-2006, 06:46 AM
evldave's Avatar
way more than I understand, but I can print and take w/me to call BS at a gunshow. Thanks for the help!
The Juice's Avatar
The Juice The Juice is offline
The Juice is an unknown quantity at this point
Didn't you hear? AlecW might have mudered his son and he might be going away for awhile.
I'll be keeping an eye on the papers man.
Old 07-24-2006, 07:32 AM
Donkey_Kong's Avatar
Donkey_Kong Donkey_Kong is offline
Donkey_Kong is an unknown quantity at this point
Alec??? Any comments???
***Crickets***
Find another forum. This one won't be so forgiving soon.
Old 07-24-2006, 07:49 AM
The Juice's Avatar
He'll have a better shot at running from the po po in a Hummer than me in ma Bronco.
Old 07-24-2006, 04:15 PM
Originally Posted by The Juice
....... a better shot at running from the po po in a Hummer than me in ma Bronco.
LMFAO that funny
Old 07-24-2006, 06:04 PM
MarineHawk's Avatar
As far as Redhawk's go, I have and love the 5-1/2" blued one ( http://www.ruger-firearms.com/Firearms/FAProdResults?function=famid&famid=6&variation=Blu ed&bct=Yes&type=Revolver ). If I was going to potentially encounter Grizzlies, I would probably get a heavier load, but I just carry the fire-breathing 1,610 fps/1,036fpe 180 gr loads. I'm pretty sure that that will stop a black bear.
As far as the .22 LR rimfire round goes, it's the worst possible choice for personal defense. Go to the Federal Cartidge Company and please show me the .22 LR load that is recommended for personal defense. There are none. They are only recomended for varmints and target shooting. There is a reason for that. Actually several.
As a matter of physics, it's the energy of a projectile that damages, disrupts, and kills. Some bullets are better constructed for a particular purpose and, thus, distribute the energy on impact in a more deadly manner. However, assuming you have an appropriate bullet type, it's the energy that disrupts the recipient of the projectile. .40 S&W or .45 ACP = upwards of 500 fpe in certain loads. The .22 = about 115 fpe.
Another relevant concept is that the likelihood of KILLING an animal is proportional to the square of the times you shoot it. Thus, if you shoot a person 5 times with a .22, you are 25 times more likely to kill him than if you merely shot him once. You are also probably more likely to kill someone by shooting him 3-5 times with a .22 than you are by shooting him once with a .40, but it will probably take a while and won't impede his ability to continue aggresive conduct nearly as much as a single shot from a .40 or .45. This is because, while the five .22s are more likely to strike a vital artery in the areas where they create a permanent cavity, the temporary cavities are much, much smaller than those created by real personal defense loads. Thus, you can shoot some aggressor five times with a .22 and he likely will ultimately bleed to death, but won't shut down immediately. Someone hit with a 500 ft-lb bullet will be much more likey to experience immediate disruption due to both the permanent and temporary cavities created by the round. He will likely shut down immediately. That's why the 155 gr .40 produces "one shot stops" of a person shot in the torso 96% of the time and a .22 produces one stop shots about 32% of the time. Even some .380 loads get up to almost 70%. The .22 does not cause enough shock to reliably stop a human-sized target. I would say this failure is even more pronounced when dealing with a person on certain amphetamines or narcotics.
Of course, there's nothing wrong with shooting a threatening individual multiple times with a .40 or a .45, which really seals the deal.
Further, firing your handgun madly like a machine gun is not the way to win a gun fight. Shooting with a decent caliber and making every shot count is the way to go. Trust me, you won't feel the recoil of a 9mm, .40, or .45 when someone is shooting back at you. Not one bit.
Even if you want to attack someone Machine Gun Kelly style, you can get a Glock 35 with a that holds 18 rounds (17+1) in .40. If you want to less recoil, get a 9mm Glock 18 with a 31-round magazine.
Using a .22 for home defense is like bow hunting Grizzlies. It's great if you want a tough challlenge. But, if you want to make your like easier, go with a real caliber.
Old 07-24-2006, 07:01 PM
RIC-H0's Avatar
Very Well Put!
I completely agree with all you have mentioned!!!
So lets go Bow hunting for Grizzlies or atleast a Black Bear! Soon!
Ric
www.meatspin.com
Old 07-24-2006, 07:16 PM
ok, here's my deal. I have a shotgun, which I use mostly for hunting, but w/slug & 0000 shot works well for home defense (behind the locks and my 2 75# dogs).
What I'm looking for now, is a pistol, something I can carry w/me. I used to have Karr .40 cal w/3.5" barrel. Honestly, I hated it - too short barrel, plus a trigger/double-pull safety. I'm not too interested in home safety, with the dogs & shotgun. If I was, I've but a 15 round .22 w/hollow points - about a good as a home defense pistol as you can find (behind the shotgun).
What I need is a pistol (not revolver, hate 'em), with >6 round clip, with a real safety, with a >4" barrel, that can stop a bear/wolf/cougar/etc. I'll use it mostly for personal protection in my car, but want a single gun for both traveling protection + camping/outdoors. I was in Alaska a couple years ago and ended up 10' from a black bear. Everything worked out, but I have had a run-in w/the shotgun where my brother and I dumped 6 rounds of 4 shot into a small black bear while pheasant hunting near Yakima WA. I never want to be that freaked out again - I want a pistol I trust to take care of that for me. Pull it and shoot, no worries.
Without a bunch of BS about gun safety (I'm comfortable w/guns, been shooting them for 15 years), what's the best gun for my needs under $700? I don't mind used, don't need a laser sight, won't use it for target practice, can shoot quite well under pressure, and just need something with stopping power. Thanks.
K, I read your post but I'm going to say it anyway. REVOLVER. No parts to get jammed up. .44 magnum (or .50). Get a nice one and you will like it. That is all.
