Old 08-07-2006, 11:15 PM
dochummer's Avatar
Default Rear Sway Bar?
So, I've been hearing a clunking noise coming from the back-end of the rig for a few months now...usually when I go over a speed bump, or backing out of the driveway...I thought it was just fuel moving around in the fuel tank until i figured I'd check it out. I found that the bolt connecting the sway bar(?) was backed out about half way along the threads and I'm pretty sure that is what's been making the noise (#1). The other concern however was the connector on the right side, it looks like an 'O' but has an open end on it. On the left side, the ends are touching, on the right, it's actually opened a little - forming a 'C' (#2). Anybody know if it's normal to slightly open like that? And...do I need to lift the rear end before I tighten down the loose bolt on the left side?
'03 H2
Old 08-08-2006, 12:58 AM
dochummer's Avatar
Default Re: Rear Sway Bar?
Thanks Phil. I guess I'll crawl under there and check everything else out while I'm at it...
'03 H2
Old 08-08-2006, 01:01 AM
Check for empty baby bottles in the side compartment in the back, too.
Really
Old 08-08-2006, 04:22 AM
LoLo's Avatar
LoLo LoLo is offline
LoLo is off the scale
I have had a similar "clunk" noise from the back of my truck for some time, now... will have to look tomorrow (when it is light!) to see if that is my problem, too! Thanks for the info...
___________________
05 Desert Sand H2 Adv
Old 08-08-2006, 05:21 AM
dochummer's Avatar
Really
For your information, the little nook for the windshield wiper below the windshield, is NOT a good place to put a bottle. They tend to "fly" away from you.
'03 H2
Old 08-08-2006, 05:23 AM
dochummer's Avatar
Phil, you'll be running the Rubicon with us right? Maybe you can take a quick look then...
I just finished tightening the sway bar. Just used two crecent wrenches... I'll see if that takes care of the clunking tomorrow...
'03 H2
