Old 08-28-2006, 03:43 AM
Alan06SUT's Avatar
Default Just finished installing the cognito seering kit
It wasn't too bad. It took two hours. Most of that time was getting the idler arm off, and removing and strightening my fubared skidplates (thanks to Tellico x2)! The only reason you have to move/take off the idler arm is due to lack of clearance between the idler arm bolt and crossmember.
It drives basically the same, but on the higway, I did notice it not wanting to follow the grooves as much as it did. It seems to center itself a little better also. I just had GM put new pitman/idler arms on uner warranty, so this setup should keep them from wearing out like the originals did.
After putting it on, I can see the design will keep the pittman/idler arm ends from wearing out. With out the kit the arms connect only to the top of the center link. With the kit they are connected to the center link as original (on top), plus on the underside. Stock, all of the turning force is transferred to the drag link from the top, now its from the top and bottom.
Anyone who wheels often or tows should get this kit IMO.
Old 08-28-2006, 05:44 AM
Default Re: Just finished installing the cognito seering kit
Old 08-28-2006, 06:08 PM
Alan06SUT's Avatar
Here...
Here is the pitman arm:
Old 08-28-2006, 06:27 PM
ree's Avatar
ree ree is offline
Those pictures, the ones Cognito makes available suck. Here are some pictures from when I put them on. I got my camera up high enough from in between the arms to see the entire brace assembly. With these before and after your average joe can see a lot better how they're supposed to help.
'03 pewter base H2
Old 08-28-2006, 06:29 PM
ree's Avatar
ree ree is offline
This is pitman before:
'03 pewter base H2
Old 08-28-2006, 06:30 PM
ree's Avatar
ree ree is offline
Pitman after:
'03 pewter base H2
Old 08-28-2006, 06:31 PM
ree's Avatar
ree ree is offline
Idler before:
'03 pewter base H2
Old 08-28-2006, 06:32 PM
ree's Avatar
ree ree is offline
Idler after:
'03 pewter base H2
Old 08-28-2006, 07:17 PM
Alan06SUT's Avatar
Thanks. I smashed my camera in Tellico on the last day last obstacle. Its still getting fixed, so I was unable to take the pics.
How long have you had them on...Have you had to tighten them back up?
Old 08-28-2006, 07:33 PM
ree's Avatar
ree ree is offline
Since April. I checked about two weeks ago and they're still tight.
'03 pewter base H2
