Old 08-29-2006, 11:51 PM
DURAMAX TIM is off the scale
Default fog lites on hi and low
On the GM trucks we soldier in some diodes to have all 6 lights on w/ the hi beams.
Any one here checked or done it on the 3?
I get some time I'm going to try and get the fogs it to work.
98 ZR-2 Blazer
Ex H2&3 owner
Old 08-30-2006, 12:43 AM
Default Re: fog lites on hi and low
Yes, it can be done, but could take some time to figure out. Both headlamps and Fog are BCM controlled.
BCM controls a relay to power the fogs, BCM controls the power circuit to the headlamps, and also controls the HI/LO beam relay to supply ground for the HI or LO beam.
Heading out of town, so I don't have time to really look right now.
Probably all you will need are some relays, maybe a few diodes, but you should be able to isolate the circuits with relays.
Old 08-30-2006, 01:58 AM
If you value your warrentee dont do it...
Old 08-30-2006, 02:13 AM
I'd add some lights before messing with the factory harness.
Old 08-30-2006, 03:19 AM
WHY?
on the GM trucks and SUVs I've done it to, it only takes 5 seconds or so to switch the relays back to stock.
Wife just said the hi beams aren't very bright.
98 ZR-2 Blazer
Ex H2&3 owner
Old 08-30-2006, 04:47 AM
marin8703's Avatar
why do they make the fogs turn of with highbeams anyways?
Old 08-30-2006, 06:59 AM
deserth3's Avatar
deserth3 deserth3 is offline
If it's all controled by the BCM you may be able to get the dealer to change it through software.
May be worth asking anyway.
Old 08-30-2006, 11:47 AM
Dealer can't change it via software. Reason is, GM is following state laws. Most states require the fog lamps to dim with the HI beams, so they conform to state laws. (Not that the police ever enforce this law.)
As long as you isolate the circuits to prevent feedback to the computer, the only warranty you would void is the warranty for wiring you cut into.
I have tapped into many wires in almost all my vehicles, and no one has blamed the wiring for a fault and refused warranty on any item.
Old 08-30-2006, 04:26 PM
BuzzH3's Avatar
BuzzH3 BuzzH3 is offline
BuzzH3 is off the scale
I used to own a GMC Sonoma and having the quadbeams (low and high beams at the same time) was a huge thing on their forums. I believe that it was Painless Wiring (I think that is their name) that actually has a kit to make this work at least on GM trucks. I don't know how different the headlight wiring is between GM trucks and the H3, but you might want to check them out. Here is a link to how it was done on the Sonoma without a kit. Again, I'm not sure if this will even work on the H3.
http://www.fmtc.com/~brule/quad.html
2006 H3 Black Luxury package; Off-Road package; Sunroof; AVIC-Z1/Monsoon; XMNavTraffic; iPod adapter; Rear view camera; Front bumper letters; Splash guards; Mudder floor mats; UC Protection
Old 08-30-2006, 08:46 PM
NOT RESPONSIBLE FOR THE RESULTS OF THIS SUGGESTION
All it takes is a $.50 diode and they are done.
took a few minutes and found the relays and figured where to put the doide in.
no soldiering just pull the relay, insert the correct diode leg and reinsert the relays.
98 ZR-2 Blazer
Ex H2&3 owner
Old 08-30-2006, 10:35 PM
Originally Posted by DURAMAX TIM
NOT RESPONSIBLE FOR THE RUSULTS OF THIS SUGGESTION
I like the disclaimer
Old 08-30-2006, 11:08 PM
works fine for me, don't want someone using a stick of dynamite for a diode and spreading hummer/human parts all over
Someone also said it'll void the warranty, don't know HOW but CMA just in case.
98 ZR-2 Blazer
Ex H2&3 owner
