Old 04-03-2006, 04:35 PM
working Hummer's Avatar
I went to the Rhino lining guy here, which is the same as Line-x and he told me he couldn't do the grill and mirrors because they are plastic. I told him I've seen others do this and he said it wouldn't stick very good. Is this true? Anyone having a problem with it or is this guy lazy? I've seen pictures of some of you guys doing this.
Old 04-03-2006, 04:41 PM
It sticks great! They have to sand the grill, then "mist" the product on for the first application. After that they apply as normal.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/9...441078741#3441078741
Old 04-03-2006, 04:50 PM
bigolH2 bigolH2 is offline
bigolH2 is off the scale
Nah, youll be fine like Ken said. They guy here with linex has done it a few times to grilles and said it turned out great. Im about to get mine done with linex.
03 White H2 with Banks exhaust, Volant intake, 4\" Rancho lift, 18\" black Rockstars, 37\" ProComp Xterrains, Roof Rack and lights and a lot of turning heads!
Old 04-05-2006, 12:14 AM
Lext Lext is offline
Lext is off the scale
If its Not properly prepped, It Will Peel. but if done right, no worries..
Old 04-05-2006, 12:20 PM
TXSUT's Avatar
TXSUT TXSUT is offline
I'm not sure if I understand you correctly, but Rhino is NOT the same as Line-X.
Old 04-05-2006, 12:51 PM
For grills and such, I would think you would want Line-X. It ends up being a hard surfaced product. Rhino is applied cold under low pressure and it feels more rubbery after it is applied.
I like Rhino better in pickup beds and whatnot only because I personally like that rubbery texture. But I'm not sure how well that would do on a grill and such.
Old 04-05-2006, 10:01 PM
you know I guess I just assumed they were the same product just a different name. Hmmmmm I guess I'll have to check into that. Thanks
Old 04-05-2006, 10:34 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I knew it!!
Old 04-06-2006, 12:23 AM
I knew it!! </div></BLOCKQUOTE> I resisted the temptation of saying anything about latex gimp masks </div></BLOCKQUOTE>I haven't been shy about my rubber fetish. I thought I posted photos of me in my rubber suits..... where . are . they
Old 04-06-2006, 02:46 AM
tomp's Avatar
tomp tomp is offline
Line-X uses a primer that is made for plastic surfaces. I had to wait on a new local Mine-X shop to order this special primer, since I was the first to request plastic to be sprayed. They had just opened that new location at the time and didn't have nay yet.
I would not use Rhino on the grill. Not only is is more rubbery, but it also appears to be applied much thicker than Line-X for some reason.
Old 04-06-2006, 10:15 AM
thank you guys for the info, I'll have to see if there is a Line-x guy here.
Old 04-06-2006, 11:07 AM
HIHUMMER's Avatar
HIHUMMER HIHUMMER is offline
http://www2.line-x.com/ns/FindFranchise.html
here u go. Line-X is goooooood!
South Dakota
Rapid City
Black Hills Line-X
2843 Samco Rd, Unit E 605-343-5323 grizzlytruck@rushmore.com
Sioux Falls
Midwest LINE-X
519 N. Kiwanis Ave.
605-332-0455 info@midwestline-x.com
