Old 10-17-2006, 10:07 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
Default Now I'm Annoyed
So, I finally decided to hook up the lights on the rear of my Gobi rack. The one's that face backward. If nothing else, I will use them to see when I'm pulling the boat out at night. Anyway, I didn't buy the lights made for up there, piaa I think, just some cheap Pep Boys lights. 1st I hook them up to the reverse lights so they come on when backing. Numerous blown fuses later, I decide OK, I'll put in a switch. Get the switch, wire the entire thing up, blown fuse . This is where I get annoyed. I don't have the wiring schematic anymore for the lights but cumon, black to black and white to white. White being the neutral/ground, black being the load. Noooo, it's fricken backwards, the white is hot. WTF is this right? It works now, so I guess it's right, but it seems wrong. Thats all, shoulda spent the money on the piaas and would of saved some time. Or, I guess i coulda read the directions, whatever I'm a guy.
WWW.BCBI.COM
Old 10-17-2006, 10:09 PM
Desert Dan's Avatar
Default Re: Now I'm Annoyed
hmrlvr
How are you running the hot wire down from the roof rack?
Behind the plastic pillars and in behind the tail lights??
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-17-2006, 10:13 PM
hmrlvr's Avatar
Originally Posted by Desert Dan
hmrlvr
when I hooked it to the reverse light, yes. But now that they are switched, the wires run down the rack mount, through a small hole I drilled in the plastic, and down the front pillar to the engine compartment. I looked at my neighbors H2 and thats how his was done, I just matched it.
WWW.BCBI.COM
Old 10-17-2006, 11:36 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
I've always known black wiring to be ground/neg. at least you got it figured out.
Old 10-17-2006, 11:59 PM
hmrlvr's Avatar
I'm just thinking of wiring in a house I guess
WWW.BCBI.COM
Old 10-18-2006, 12:25 AM
Khoolhandz Khoolhandz is offline
Khoolhandz is on a distinguished road
Invest on a cheap voltmeter from Radioshack and you would not have had this problem.
Old 10-18-2006, 12:28 AM
Did you use a relay?
Old 10-18-2006, 12:39 AM
Big Z Big Z is offline
Know.it.all.CheapA$$ Back Yard Mechanics!
Old 10-18-2006, 11:42 AM
That is a common error. Cheap or expensive. Prefer Red =12v Black=ground
Old 10-18-2006, 04:00 PM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
Old 10-19-2006, 01:21 AM
H3PAC's Avatar
H3PAC H3PAC is offline
You may want to try less complex DIY mods on your vehicle. And even then, proceed with extreme caution.
