Old 11-08-2006, 09:22 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
Default Mirror swap write up.
I traded wpage my chrome mirrors for a set of black ones he had and thought I would do a write up real quick for anyone that hasn't done it. I haven't seen a how-to so here is a how-to. It wasn't NEARLY as difficult or time consuming as i thought it'd be. It took me about 20-25 minutes. Here are some quick instructions:
1) take out the 3 screws holding on the door panel. 1 is behind the door handle latch 2 are behind the grab handle trim piece.
2) pull gently from the lower corners to pop off the door panel and then lift up to get it out of the window channel.
3) roll the window down
4) unplug the harness and wire holder
5) remove the 4 screws hold in the mirror and try not to drop any, also hold the mirror through the window when taking out the last screw just to make sure it doesn't fall and scratch up your door.
6) move to the outside and pull the mirror off and then remove the rubber grommet.
7) put the new mirrors on and reverse the steps.
ALL DONE!
Old 11-08-2006, 09:52 PM
SR1355's Avatar
SR1355 SR1355 is offline
Default Re: Mirror swap write up.
Cool, I was looking to get into doors for other reasons and was wondering how many and where screws where. Thanks
Paul M
SR1355
Old 11-08-2006, 10:31 PM
Here are some pictures to help as well.
Old 11-09-2006, 12:47 AM
Like aetherH3 description best. Good Show
Old 11-17-2006, 12:34 AM
Got them thanks
Old 11-17-2006, 12:37 AM
Thumbs up Re: Mirror swap write up.
Goin in tommorrow thanks for the demo
Old 11-17-2006, 08:08 PM
sweet!
Old 11-17-2006, 08:21 PM
Desert Dan's Avatar
Thanks for the info
I was backing up through some willow trees for some broken Jeep to get towed out and snapped of my right side mirror. They fold back but don't like to fold forward. I Gerry rigged it back on with a hose clamp but it will need to be replaced soon. The electric controls still work.
I bet the whole mirror will be expensive$$
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 11-20-2006, 07:29 PM
wpage has some black ones for sale in the Classifieds.
